BCD Assembly
22 posts / 0 new
Could i have assembly codes about  1) BCD to binary
(Atmega 32A AVR studio 4.19)        2) binary to BCD
                                                    3) addition and subtraction of numbers in BCD code
Yes.
1) you do realise that's just "split the nibbles" and multiply the high one by 10 don't you?
2) that one is a bit more complex as it involves a divide by 10 but I'm pretty sure Atmel have an app note for that (maybe the entire bin->BCD thing)
3) Again that's just separate the nibbles and do it just like you did in school:
  37
+ 54
In that you add the 7 and the 4 in the right columns and if there is a carry (there is) you add that in along with the 3 and 5 in the right most columns. Again it's just a question of splitting 37 into 3 and 7 and 54 into 5 and 4.
Presumably this is a school assignment? Didn't your course tutor already explain all about separating the digits? At the very least (though there may be more efficient ways) the lower (right) nibble can be extracted with "AND 0x0F" and the upper nibble with 4 logical shifts to the right.
Yes, AVR204 with code example in assembly!
When sample codes are discussed, will we finally see a useful use for the H bit in SREG?
x86 had/has the seldom-used AAM opcode, right?
Is this one of those "representation" threads, where OP has e.g. an AVR register and wants to see the value in different ways?  Or really a BCD number, as an RTC chip might return?
Regarding the nibble addition:
If sum is 9 or less, for example:
  0x05
+ 0x02
  0x07
Result is already correct BCD, you don't need to do anything;
If result is > 9, for example:
  0x08
+ 0x09
  0x11
You need to add 6 to convert to BCD, and a carry results to add to the next nibble.
Useful instructions that you'll need: swap, andi.
edit: about the H flag, it might be useful for more optimized code, perhaps. But the OP will probably want to keep it simple, after all you should not present code you don't really understand.
Which stems from 8080 and Z80 which had DAA (Decimal Adjust Accumulator). I guess this is the kind of thing that differentiates CISC from RISC?
The 6502 could do all arithmetic in BCD. Very seldom used. It worked with the same number of cycles as binary arithmetic.
The Burroughs "Medium Systems" mainframes were [almost?] completely decimal machines.  In fact IIRC it was only in the x7xx and later that there were binary accumulators.  PIC 99V99 COMP. anyone?
From distant memory, BCD was useful for some calculations. But you certainly did not want to use it in address lookup. You would need the binary value in X or Y registers for doing indexed addressing.
Don't (or didn't) most calculators (used to) work internally in BCD ... ?
Indeed - I'm pretty sure that's why your 6502's and Z80s etc. principally had these DAA type opcodes to ease the implementation of BCD arithmetic.
A 6502 (at least the original one) don't have BCD instructions, it can have carry set at 100 or 256 (0) and that is the only one I remember.
Yes it did. The arithmetic was done in BCD.
The 6502 had the instructions CLD - Clear Decimal Mode and SED - Set Decimal Mode which only cleared or set the D flag in the Status (P register) and affected no other flags or registers other than an increment of the Program Counter (PC) .
The D flag determined the mode, binary or decimal,  of the instructions ADC - Add Memory with Carry to Accumulator and SBC - Subtract Memory from Accumulator with Borrow.
Loved using the 6502, it was my first learned microprocessor.
I stay corrected I only remembered that the carry came at 100.
And the 6502 computers I have had (PET, oric and c64) it was a no go with the decimal flag set.
From memory,  the PET would CLD when entering an ISR().   And the RTI would restore P afterwards.
In other words there was no problem with BCD mode.   But as I said earlier,   few people used it.
The processor technology BASIC interpreter, that I have been playing about with has an extended floating point package that is BCD based.  For 40 years I have wanted to know how this works.  The code is pure 8080 as Z80 opcodes are verboten in the emulator.
IEE-754 includes a BCD format.
I believe that the only place that BCD is seen today is in the time-keeping registers of the RTC chips: DS1307 and DS3231.   That, and homework assignments.
I'll bet that COBOL programs still have BCD data types.  And I would strongly suspect that there are "financial coding standards" that require their use.
There's a guy who posts relatively frequently on the Arduino forums, is a teacher, and has a liking for BCD.  Perhaps this is one of his students.
