atmege168pa and atmega328p
10 posts / 0 new
Hello forum users,
Could you share your experience with me?
How to convert code from atmega 328p to atmega 168pa?
sadf
Does your code use more than 16k of flash, 512 bytes of EEPROM or 1k of RAM?
My code is 6 kb. I am going to adjust to from atmega328p to atmega168pa.
sadf
At the hardware level, other than memory sizes, they are the same chip. So change the processor type selected in your compiler and you should have no problems.
[E2A]
From the datasheet...
2.2 Comparison Between Processors
The ATmega48A/PA/88A/PA/168A/PA/328/P differ only in memory sizes, boot loader support, and interrupt vector
sizes. Table 2-1 summarizes the different memory and interrupt vector sizes for the devices.
I know that they are same chips. MCU is not working after compiling, but it received code. That's why I asked forum.
sadf
But Brian pointed you to the datasheet section which details the differences.
Did you look at the mentioned "Table 2-1" ?
Have you paid careful attention to all those differences?
Have you checked all your Fuse settings?
Both chips have on-chip debug - use it to see where things go wrong ...
Have you simply tried recompiling the 328 code for the 168? The transition is really just 328p to 168p, the "a" is incidental, that just means a change in fabrication process.
So what is your RAM needs?
Assuming Atmel Studio, i.e. avr-gcc tool chain: Show your build output:
  • Do a Rebuild
  • Switch to the Output tab in Studio
  • Mark everything
  • Copy it
  • Paste in a post here
Can you define "not working" (a pointless phrase that means nothing)
