Failed communication over IP
4 posts / 0 new
I work with SAM3S and J-link to program it. It performs well when J-link connected to USB of my PC. But now I need to debug my mcu connected to another PC which has local connection to mine. My projects are in AS7 so i tried Tools -> Add target -> J-link over IP; I entered server IP into "address". Then it appears in "Availible Tools" menu with the status "Connected".
J-link has two Server-Client: RemoteServer and GDBServer. We used the first one on the host PC and the window waited to connection appears. I can connect to host PC with J-link applications, read memory of mcu and so on. But i need to debug. I start AS, Availible Tools -> Device programming, choose Device, click "Apply" and error pops up:
Unable to connect to tool J-Link over IP (192.168.0.33:)
Timestamp:    2018-01-11 13:48:58.321
Severity:        ERROR
ComponentId:    20000
StatusCode:    0
Failed to set-up tool (no context id returned).
Is there any suggestions what has gone wrong? Also Remote debug works in the Eclipse with GDB SEGGER J-link Debugging. Moreover i used it with both RemoteServer and GDBServer running on the host PC.
Will be very thankful
Although you seem to have established that the fault is not with the J-Link itself,  have you tried contacting Segger?
They might be able to offer guidance on how to get the J-Link to work with Atmel Studio ... ?
Both atmel and segger provide a guidance to work with them (e.g. http://www.microchip.com/webdoc/... ). But it says nothing about what should be done at the host PC, should I write host ports anywhere at Atmel Studio or run segger client etc. I didn't find any solutions in the google either. And Eclipse did not asked any questions about it what is weird. From it i can program my mcu over ip and debug with all those breakpoints.
So, the remote side needs to have Remoteserver running. It should give you a port number that it is listening to (which I think you should add to the setup in Studio)
:: Morten
