missing stk600 from atmel site
5 posts / 0 new
Hello
I have buy stk600 ,used, I try to download the pdf ,manual from microchip site but when i click todownload the  manual always come the home site of microchip.
I search to download it from other sources and i didn't find it.
Can some one help on this?
See: https://www.avrfreaks.net/forum/s...
EDIT
But simply putting "stk600" into the 'Search' box at https://www.microchip.com/ does find it.
yes i find it but i can not download it
It downloads just fine for me. What happens when you try to download it?
finally I download it.Thank you
Happen that i search for stk600 then on results i click on stk600 manual and after that redirect me to home page of microchip
I download it by browsing the site first i choose mc,atmega1284 then go to tools then go to stk600 and then i get the manual :)
I try it from different pc so it is not bug from broswer cookies etc
