Xmega a1u + ksz8851
14 posts / 0 new
I'm a novice. Please, help. плач
I have XMEGA A1U Xplained pro and expansion board Ethernet1 Xpained pro (ksz8851snl).
But I do not understand how to work with the expansion board?
Maybe someone has examples?
I would start with the data sheet for the ksz8851snl. It can be found at http://ww1.microchip.com/downloa...  I would also check to see whether or not there are Arduino examples. If there are, those examples should show you how to do various things, even if you do not directly use the code.
By the way, XMega chips are relatively complex for an 8 bit micro. They are not a particularly easy way for a beginner to start.
http://www.avrfreaks.net/forum/example-project-ethernet1-xplained-pro-modul-solved
Have you followed the instructions in the user manual for the ethernet board?
YES, I have the same problem
Surely, when you plug it into the PC, Atmel Studio recognises it (both the XMEGA A1U Xplained pro and the Ethernet1 Xpained pro) - and you get the full list of available examples ?
EDIT
SEE: http://www.microchip.com/webdoc/asf/asf.GettingStarted.CreateNewExampleProject.html
https://youtu.be/_ADg1cIWRWg?t=26 - for AS6, but 7 is the same in this respect. The list should automatically be filtered by the detected boards ...
Unfortunately, this does not happen. Atmel discovers the board, but the module sees but can not recognize.
And so I do not have one. The module is working.
What, exactly, "does not happen" ?
Show your working.
Sorry, what do you mean by that?
Which "one" are you referring to here?
and which "module" are you referring to here?
How have you verified that it is "working" ?
Posting screenshots may help - instructions here: https://www.avrfreaks.net/comment...
When I plug an Ethernet1 Xplained Pro into a SAM D21 Xplained Pro, AS only sees the SAM D21, not the Ethernet1.  It still functions though.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
Hmm - that's a bug, then!
Does it (still) correctly detect & identify other Xplained Pro extension boards ?
EDIT
The first few google hits for "Ethernet1 Xplained Pro" were dead links, but eventually got to:
So it definitely should work ...
Have you accidentally enabled saxophone mode ... ?
<rolls-eyes>
Sorry for my English.
I have the same thing.
When I plug an Ethernet1 Xplained Pro into a XMEGA A1U Xplained Pro, AS only sees the SAM D21, not the Ethernet1.
Amazing!
You can turn an XMEGA into a SAM D21!!
cheeky
But, anyhow, even if the auto-detection doesn't work you should now know where to search manually ...
That's a bug, then.
So one (or both) of you should report this to Microchip ...
Done: Case 00269606
Greg Muth
Portland, OR, US
From Microchip:
**** Proposed Resolution Begin ****
Issue might be due to missing Ethernet1 Xpro in board database.
This does not affect extension's functionality and can be ignored until it is updated by our team.
**** Proposed Resolution End ******
Greg Muth
Portland, OR, US
