#define undeclared error
14 posts / 0 new
Hi guys,
I'm actually starting with Atmel Studio programming an ATMEGA 328 and made a header file for globals_bexx.h, where I'm doing global declaration according to Deans TUT.
Everything is fine, but using the #define command for setting up my spi lcd-display I got an undeclared error only on 'DDRB1'
// #define PORT_SPI    PORTB
#define SPI_LCD_PORT		PORTB	    // SPI Display SS_ Port B1
#define SPI_LCD_PORT_CS		PORTB1	    // SPI Display SS_ Port B1
#define SPI_LCD_DDR		DDRB	    // SPI Display SS_ Port B1
#define SPI_LCD_DDR_BIT		DDRB1	    // SPI Display SS_ Port B1
Isn't it, that #define only replaces the first text by the second one?
Why does it say 'DDRB1' undeclared (frist use in this function) , as ther is no funtion at all?
Many thanks!
Bexx
That is correct. It will replace
SPI_LCD_DDR_BIT
with
DDRB1
But now there is a requirement that DDRB1 is defined somewhere. Is it?
There is no such symbold defined in Atmels header files.
There is a symbol
DDB1
in the header for mega328.
Now, you might ask why they named it such - breaking the pattern that holds for e.g. PORTB/PORTBn and PINB/PINBn. I don't know. It doesn't make sense to me either.
On the other hand, all those pin numbers just equate to integer literals  between 0 and 8 anyway so you might as well skip that extra "layer and go for
#define SPI_LCD_PORT_CS		1
and use
SPI_LCD_PORT_CS
to manipulate the bit in both the PORTB and DDRB register. It's always the same bit number so it makes no sense to have two different defines. If you move the CS signal to another pin you should just need to change in one place.
Not even in the "mop up" header? I'm too sick and not near enough to a PC to check right now.
EDIT so I had to check and it just proves how ill  I am...
http://svn.savannah.gnu.org/view...
It "mops up" the PORTxn symbols but not DDRxn
Never heard of the "mop up" header before (neither the header as such, nor the specific expression).
Anyway, I'll stand by my statement above. Having the specific port as part of the name for something that "just" represents a pin number within a port is redundancy in code and should be avoided.
To try to make my thinking clear to the OP:
If something is on PORTB pin 2 then that should be stated separately and neither fact should be "doubled". I.e.
#define PORT_SOMETHING PORTB
#define PIN_SOMETHING 2
Having the port stated as part of the pin stuff just risks a missed update if something is moved to another port but same pin number within that port. i.e.
#define PIN_SOMETHING PORTB2
and then moving to PORTD but still pin 2 within that could end up
#define PORT_SOMETHING PORTD
which will work just fine - but someone reading the code might be very confused. Is something on PORTB or PORTD? E.g. that someone might want to measure a signal between the AVR and something and happens to see the PORTB2 first and attaches his oscilloscope to that pin. Nothing! No signal at all. Depending on luck, experience and phase of the moon it can take that person 10 seconds or several hours to discover what is the truth.
Using the style I prefer (first code snippet above) this ambiguity will never occur. And you get to use the same symbolic name for the pin number regardless of if you're accessing the PORT, PIN or DDR register.
Nice. Clean. Less risk for bugs and/or confusion.
Having the port name as part of the pin number symbolic name does not make anything clearer. Just say "no". ;-)
Totally agree. Never really understood all this need for PB2 or PORTB2 or whatever. The code is surely just clearer and easier to read if you simply use 2 to mean "bit 2".
I like the generic bit masks and bit positions as these defined in iotn1616.h.  Have often seen, and used, similar in ARM code.
// Generic Port Pins
#define PIN0_bm 0x01
#define PIN0_bp 0
#define PIN1_bm 0x02
#define PIN1_bp 1
#define PIN2_bm 0x04
#define PIN2_bp 2
#define PIN3_bm 0x08
#define PIN3_bp 3
#define PIN4_bm 0x10
#define PIN4_bp 4
#define PIN5_bm 0x20
#define PIN5_bp 5
#define PIN6_bm 0x40
#define PIN6_bp 6
#define PIN7_bm 0x80
#define PIN7_bp 7
Many thanks for your input!
Johans suggestion sound quite fine for me.
So I tried to use this in the header file:
#define SPI_LCD_PORT_CS		1	    // SPI Display SS_ Port B1
and this in the code (I hope i got this right):
// DDRB |= (1 << DDB1);        // original, sets bit DDB1 to 1 within register DDRB
SPI_LCD_DDR |= (1 << SPI_LCD_DDR SPI_LCD_PORT_CS);        // should set bit DDB1 to 1 within register DDRB
...now  there comes up an error : expected ')' before numeric constant    (on:  #define SPI_LCD_PORT_CS        1 )
Does it really make "DDB1" using "SPI_LCD_DDR SPI_LCD_PORT_CS" ?
Many thanks!
...btw...
using:
#define SPI_LCD_PORT_CS		ABC			// SPI Display SS_ Port B1
there again comes up the error from the beginning of this thread:  'ABC' undeclared (first use in this function)
....I'm quite confused!
No. This should:
SPI_LCD_DDR |= (1 << SPI_LCD_DDR);        // should set bit DDB1 to 1 within register DDRB
BEXX wrote:
...btw...
using:
So, show us the definition of ABC. (Is there one?)
But where, exactly, is the error reported?
I think it would be a safe bet that it is reported where the macro is used - not where it is defined ...
Because avr-libc did before we started to generate the header files. So, we keep the compatibility (even though as you and Cliff says, doesn't make much sense in the greater picture).
:: Morten
Look at the .i file.
See: https://www.avrfreaks.net/comment... for further details ...
