Split from: AS5 simulator support for ATmega2560
10 posts / 0 new
Is there any chance of AS for linux ?  Using an Arduino2650, I am currently stumped by possible interrupt/counter conflicts for a personal project that also has commercial applications. Writes to OCR3B seem to cause the interrupt to be set on alternate cycles of TCNT3 in fast PWM mode 14. Channel A is working OK.  I am trying to generate in interleaved 3-phase PWM.
SBKenn_ie
Not a hope.
But see: https://www.avrfreaks.net/comment... - although that is about AVR32, the fact that it's GCC still applies ...
The is also the possibility (has been discussed here not so long ago) that Microchip might bring it all into their IDE - which might be cross-platform ...
awneil wrote:
... Microchip might bring it all into their IDE - which might be cross-platform ...
That effort may be underway :
http://packs.download.atmel.com/#collapse-Atmel-XMEGAE-DFP-pdsc
1.2.51 (2017-04-06)
Added linux simulator models.
The MPLAB IDE is cross platform.
Can you post a small complete program that demos this?
Maybe as a separate thread - as this one seems to be focussing on "toolsets for linux"
and maybe re-title this one appropriately...
The linux simulator models can be used wth this: https://github.com/avrsimulator/...
See https://www.avrfreaks.net/forum/a... .
because of #7
