Split from: Atmel Studio 7.0.1416/7.0.1417
6 posts / 0 new
How about having a port of the next version of Atmel Studio to linux?
I am stuck  with use WIndows 10 under virtual box within a Debian 9 environment if I need  to run AS7...
Which I do... To help friends debig their systems.
Mi¢ro$oft Visual Studio is such a bloatware!
Within the Linux environment, Eclipse is doing quite a good job.
Well... If only it wasn't written in java, it would be 5 times as fast!
Yeah sorry, can't help there.
0xA
Microsoft Visual Studio Code is relatively lightweight.
https://www.avrfreaks.net/forum/avr-studio-mac-linux
Seriously ?
I'd have thought that the "bloatedness" of  both Eclipse and VS was pretty much comparable ... ?
As I see it...
Short version
Nobody knows.
Longish version
Facts:
  • Atmel has recently-ish been bought up by Microchip.
  • Microchip has a development IDE for PIC micocontrollers - MPLAB-X
  • Atmel brought their Atmel Studio to the table.
  • As always when merging companies there's a lot of integration to be done.
Speculations:
I would expect an effort to merge the functionality of MPLAB-X and Atmel Studio into one IDE eventually. Before that I would not expect any new major version of Atmel Studio, and certainly not a change of platform it is based on.
Since some work on integrating Atmel SAM (ARM) development into MPLAB-X seems to have been started it seems to me to be less likely that a merged IDE for PICs, AVRs and SAMs will be based on Visual Studio. AVR development might be integrated into MPLAB-X, which is based on NetBeans.
That's my $.02..
