More devices in one project
6 posts / 0 new
for my project I have two ATMegas communicating wirelessly. So far I have one project for TX side and one project for RX side. When I want to change some definitions for the protocol used (i.e. some timing constants) I need to update it in both files manually. What it the best way to have a common file with defines shared by two "mains"? Should I make some library included in both project or is it possible to have two different programs for two devices in one project? I am using AS7
2 simple ways:
  1. Just have a common header file shared by both projects - that will work for any IDE, or none.
  2. Atmel Studio allows multiple Projects within a single Solution
I'd probably for (1).
Surely you make one solution with both projects. You have them share a .h file with the common settings then you simply "build solution" (which will build both projects) after editing the header.
EDIT: too late, so I'm voting for Andy's option 2.
Thanks for help, since I have little programming education I struggle with complicated IDEs - learning ASM is easy but learning how to use AS (or any other IDE) properly to force it to do what I want seems impossible. (2) I will do simply by File -> New -> Project and choose "Add to solution" and then I will hopefully see what needs to be done? How can I do (1)? When I was including something before I copied it into the project's directory which would not work to share one file between two projects.
Smajdalf wrote:
How can I do (1)?
Are you asking in general, or specifically for AS?
1. Specifically for Atmel Studio
You have the option to 'Add As Link'
Because Atmel Studio is built on Visual Studio, it is the same:
https://docs.microsoft.com/en-us/previous-versions/windows/apps/jj714082(v=vs.105)
2. In General
Just put your shared file(s) in some convenient folder, and have your 2 projects refer to it/them in that folder
eg,
system-root-folder --+-- tx-project-root-folder ... etc
                     +-- rx-project-root-folder ... etc
                     +-- common-folder ... etc
EDIT
MS link
That's probbly the source of your problem.
You need to take the time to learn the way that the IDE works - trying to force it to work against that is just going to be frustrating.
The same applies to any tool - trying to use a screwdriver like a hammer will be frustrating!
