SPLIT: Defining an Instant
25 posts / 0 new
awneil wrote:
Increase wrote:
I didn't realize I can destroy the sensor in an instant
(almost?) any electronic component will be destroyed "in an instant" by gross abuse like connecting its power supply backwards!
Is a resistor a component? :P
EDIT:
Split from: https://www.avrfreaks.net/forum/r...
Ha ha - yes, of course!
Although resistors are not sensitive to polarity (ie, have no sense of "backwards"), they will still be damaged - if not destroyed - by "gross abuse".
Probably not "in an instant" - but still probably wise to discard one that has been "insanely hot"...
It's semiconductor components that are most likely to be destroyed "in an instant".
I thought I'd said that before in this thread, but it was actually the OP's other thread: https://www.avrfreaks.net/comment...
Define "instant".  A fuse blows quite quickly.  You tell me whether the time satisfies your definition of "instant".
  https://www.youtube.com/watch?v=... [note that there is beer involved]
DC lamps ("light bulbs") aren't that common in the LED age.  But IIRC, the filament would blow "instantly" given too many watts.
I am just quoting the the OP's words of #26:
Increase wrote:
I didn't realize I can destroy the sensor in an instant.
So, basically, "sooner than you can realise that something's going wrong, and turn the power off".
Yes, you could probably destroy an average 1k, 1/8W resistor "in an instant" by connecting it directly to 240V mains - but, please, don't try this at home!
surprise
You'll be wanting me to define "gross" (sic) abuse next ...
cheeky
Generally, fuses are useless for protecting semiconductors - because the semiconductor will blow first.
So, yes - I guess that would qualify as "instant"
Did you read the quotes I was responding to?  It had to do with "is a resistor a component".  I gave two examples (or maybe one, as both are generally filaments) that I think would qualify for components.  Indeed, you define "instant" and "gross".
Maybe the thread should be split as its now a squabble about what an "Instant" is as opposed to the topic of the thread.
JIm
or what a "component" is ?
cheeky
cheeky
Oh for **** sake knock it off......angrylaugh
Back to the question posed in the topic title...
"Defining an Instant"
See 'Planck Time'
https://en.wikipedia.org/wiki/Pl...
Probably related to the definition of, "split second": https://www.avrfreaks.net/comment...
INSTANT:Time required to go from fully functional to fully useless....
Before Andy and Lee post it:
awneil and theusch would probably write:
Define time
Define  required
Define fully
Define functional
Define useless
Define define. smiley
No recursion allowed. devil
Recursive - see: recursive.
From my old signature and added anew.
void transmigratus(void) {transmigratus();} // recursio infinitus
You've taken quite some time to try to define "instant"..
Does it take less than a microsecond to make ‘instant’ coffee?
ISTR that "instant" photos actually took several minutes ...
It's all relative
Lunchtime doubly so.
larryvc wrote:
It's all relative
Absolutely!
JohanEkdahl wrote:
larryvc wrote:
It's all relative
Absolutely!
It's all Relative.....
Kinda like there being an Instance in an Instant?
Define 'is'.
BTW, nice avatar, Jim.  I see you're continuing the theme ;-)
I don't recognize East Coast Jim anymore.
I would have sworn all that hair would be pulled out by now!wink
David (aka frog_jr)
Yes, Jims avatar is traveling backwards in time. First he pulled his hair out and now his hair stands on end.
Or else he has a miracle cure for regaining hair - that I'd like to know of since, unfortunately, my scull has decided to traverse the time dimension in the forward direction.
Keeps the shampoo budget at near minimum though.. ;-)
