megaAVR 0-series
173 posts / 0 new
http://packs.download.atmel.com/#collapse-Atmel-ATmega-DFP-pdsc
1.2.203 (2017-12-15)
Corrected register names for ATmega4809, ATmega4808, ATmega3209 and ATmega3208.
1.2.150
Added ATmega4809, ATmega4808, ATmega3209 and ATmega3208.
Two-level (plus NMI) interrupt controller
32KB and 48KB flash (likely unified memory)
28/32 pins for 8, 48 pins for 9
oooh...  Looks like there might even be a DIP-28 !
Certainly gives the impression that the ATtiny's (xtiny's) are limiting out at 16KB and that 32KB, and larger?, will be classified as ATMega, though that conflicts with what Jan (je_ruud) wrote here.  It would be nice to see an actual roadmap!  Microchip|Atmel, are you listening?
Seems to also confirm comments in other threads, made by Microchip|Atmel personnel, that indicated there would be no Xplained Pro based on an ATtiny1616 as they are most likely going to produce an Xplained Pro 32xx or 42xx instead.
EDIT: je_ruud
So, 3 levels of interrupt priority now - nice!
Two years ago the plans were completely different (, and we also had other owners...). Earth spins, plans change and we just have to compensate and make the best out of it.
Currently it seems to me (Marketing people are rather unpredictable at times. Or predictably unpredictable...) that what differs the new tiny's from the new mega's is pin count. But you won't find tiny's with >32kb flash. (.. ... Yet? Marketing, you know.)
I'll go with your "predictably unpredictable" assessment.  Guess we will just have to wait and see what pans out.
Or, maybe, what pins out?
Microchip
AN2515 Low-Power Techniques
http://ww1.microchip.com/downloads/en/appnotes/00002515b.pdf
(page 17)
10. Revision History
B
01/2018
Added some new sections:
• tinyAVR 0-series
• megaAVR 0-series
• Execution of the Sleep Instruction and Shared Variables Between ISR and Main
via https://www.microchip.com/search/searchapp/searchhome.aspx?q=atmega3209&resperpage=50&id=2
bits of PRR moved to each peripheral (p.7)
additional BOD mode (p.15)
Microchip Technology Inc
Microchip
AN2633
Precise, Ultra-Low-Power Timing using Periodic Enabling of the 32.768 kHz External Crystal Oscillator for Recalibration of the ULP Internal Oscillator
01/30/2018
http://www.microchip.com/wwwappnotes/appnotes.aspx?appnote=jp604346
Microchip
AN2634
Bootloader for tinyAVR 0- and 1-series, and megaAVR 0-series
by Egil Rotevatn
02/05/2018
http://www.microchip.com/wwwappnotes/appnotes.aspx?appnote=en604508
Microchip
ATmega4809 Xplained Pro Schematics
http://ww1.microchip.com/downloads/en/devicedoc/atmega4809_xplained_pro_schematics.pdf (5.6MB)
via
Microchip
Schematics
http://www.microchip.com/doclisting/techdoc.aspx?type=schematics
Search by: pull-down menu, select Document Title
enter ATmega4809
Search
engineering sample
An Xplained Pro that can power the target MCU at 5V (is that a first?)
Level converters!  Thank you!
ATECC508A cryptographic authenticator (ATECC608A adds AES-128)
3 Xplained Pro headers
1 mikroBUSTM header
32KHz crystal (Kyocera ST3215SB32768C0HPWBB)
http://www.microchip.com/wwwproducts/en/atecc508a
http://www.microchip.com/wwwproducts/en/atecc608a
Mouser Electronics
AVX / Kyocera
Crystals SMD 32.768kHz Tuning Forks 7pF
https://www.mouser.com/ProductDetail/AVX-Kyocera/ST3215SB32768C0HPWBB?qs=%2fha2pyFaduh8oCrdFLUv8Ccy3mfYtgQAHuqnoJP9i3zMn1Xvp%2fvrd0H7ZVNGPxY0
From iom4808.h:
#define MAPPED_EEPROM_START     (EEPROM_START)
#define MAPPED_EEPROM_SIZE      (EEPROM_SIZE)
#define MAPPED_EEPROM_PAGE_SIZE (EEPROM_PAGE_SIZE)
#define MAPPED_EEPROM_END       (MAPPED_EEPROM_START + MAPPED_EEPROM_SIZE - 1)
#define FUSES_START     (0x1280)
#define FUSES_SIZE      (10)
#define FUSES_PAGE_SIZE (64)
#define FUSES_END       (FUSES_START + FUSES_SIZE - 1)
#define INTERNAL_SRAM_START     (0x2800)
#define INTERNAL_SRAM_SIZE      (6144)
#define INTERNAL_SRAM_PAGE_SIZE (0)
#define INTERNAL_SRAM_END       (INTERNAL_SRAM_START + INTERNAL_SRAM_SIZE - 1)
#define IO_START     (0x0000)
#define IO_SIZE      (4352)
#define IO_PAGE_SIZE (0)
#define IO_END       (IO_START + IO_SIZE - 1)
#define LOCKBITS_START     (0x128A)
#define LOCKBITS_SIZE      (1)
#define LOCKBITS_PAGE_SIZE (64)
#define LOCKBITS_END       (LOCKBITS_START + LOCKBITS_SIZE - 1)
#define MAPPED_PROGMEM_START     (0x4000)
#define MAPPED_PROGMEM_SIZE      (49152)
#define MAPPED_PROGMEM_PAGE_SIZE (128)
#define MAPPED_PROGMEM_END       (MAPPED_PROGMEM_START + MAPPED_PROGMEM_SIZE - 1
Hmm, memory mapped FLASH.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
So you can get an explained pro, lots of app notes but no datasheet?? surprise
...and I would be the first one to put my hand up for a board in case there is a giveaway..... devil if I can get a datasheet of course.
I've looked at the schematic. 48pin LQFP 0.5mm pitch, 41 i/o (wow!), at least 3 uarts .... (I always need uarts...).
48K flash all mapped to data space is nice too. 6K ram is also a pleasant surprise.
I have a feeling that Microchip with these new tiny and mega family wants to keep the architecture in the 64K limit.
Personally, I would do that the same. It's natural (and simpler) to have the 8bitters in max 64K range.
And for anything else, there is always cortex-m.
Anyway, it's a very pleasant surprise to see the avr architecture still actively developed, even if it will be kept in the 64K range smiley
And in-between are 16bitters.
It's been said that 16 bits is a sweet spot (code density, classic C int)
XMEGA was advertised as 8/16b; XMEGA AVR have a 24b address space.
AVR16 anyone?
Merge the AVR and PIC24 camps?  (best of both)
PIC32 can compete against arm Cortex-M.
A concern is the sale of MIPS.
Imagination Technologies
Completion of sale of MIPS
25th October 2017
https://www.imgtec.com/news/press-release/completion-of-sale-of-mips/
http://www.microchip.com/forums/FindPost/1023282 by wdy
(post #12)
How else would the evolution be kept if everybody jumped on the hyped ARM bandwagon?
Eggs in two baskets.
Edits: link target, #12
They are also defined in current avrdude.conf, for example:
# ATmega4809
part parent    ".avr8x_mega"
    id        = "m4809";
    desc      = "ATmega4809";
    signature = 0x1E 0x96 0x51;
    memory "flash"
        size      = 0xC000;
        offset    = 0x4000;
        page_size = 0x80;
        readsize  = 0x100;
    memory "eeprom"
        size      = 0x100;
        offset    = 0x1400;
        page_size = 0x40;
        readsize  = 0x100;
AVR16 anyone?
25th October 2017
(post #12)
Modern 8bitters are a good deal 16bitters as well.
16bit is hard to justify without going beyond the 64K space. But then, the easier way is just 32bit.
In my view, a true in-between 16bitter would have 16bit registers and 32bit address range with register pairs as indexes. But these days it seems that just a plain 32bit cpu may be simpler.
Cortex-m was just an example. I'm sure one can come with a better 32bit cpu (for example, a CISC one).
Competition.
rammon wrote:
48pin LQFP 0.5mm pitch, 41 i/o (wow!), ...
The least pin count version is in SSOP for 23 I/O (mega4808)
Microchip
megaAVR® Microcontrollers
ATmega4809 Family
http://ww1.microchip.com/downloads/en/devicedoc/30010170a.pdf
(bottom of last page for packages)
ETA late May 2018 for mega4809 and board :
http://new.microchipdirect.com/product/search/all/ATmega4809
via
http://www.microchip.com/wwwproducts/en/atmega4809
Samples may be available from a Microchip sales office :
http://www.microchip.com/distributors/SalesHome.aspx
js wrote:
...  but no datasheet?? surprise
Preliminary datasheet and manual arrived today :
Microchip
ATmega3209/4809 – 48-pin Data Sheet
megaAVR® 0-series
http://ww1.microchip.com/downloads/en/DeviceDoc/40002016A.pdf (774KB)
Microchip
megaAVR® 0-Series
Manual
http://ww1.microchip.com/downloads/en/DeviceDoc/40002015A.pdf (2.8MB)
via http://www.microchip.com/wwwproducts/en/atmega4809
Clock Controller :
Main Clock Features: – Safe run-time switching
Table 5-15. External Clock Characteristics
Change in period from one clock cycle to the next, 20% max
5.9 I/O Pin Characteristics
Rise time, 1.5ns typ (5V, 20pF)
Fall time, 1.3ns typ (5V, 20pF)
Edits: main clock, rise & fall times
Sampling removed.
ETA updated :
  • board 12-Mar-2018 now
  • mega4809 QFP 28-May-2018 now
1.2.209 (2018-02-19)
Corrected reset pin configurations and changed PORTMUX signal names for ATmega4809, ATmega4808, ATmega3209 and ATmega3208.  ...
48-pin QFN/TQFP! Why? It doesn't exist in my PCB package so I will need to make one up if ever I want use them chips.
What are you waiting for, get to it!
Well I AM semiretired, so don't really care much for the extra stress. cheeky
And 0.5mm is just about out of my visual comfort, I can do it if I have to otherwise it's all up to the younger generation.
Just finished testing and calibrating 500 boards, I can now restart on the next crop of vegies for winter. Much less stressful.
The more I say that I am semi-retired, the more my wife keeps proving me wrong!wink
Interesting chips. A quick datasheet skim shows...
3/4 USARTs, you even get 3 in the 28-pin SSOP
5V operation
No external high-speed crystal option. It's 32k or ext cll only
Internal 16MHz or 20MHz, fuse selectable
The dataspace mapped code implies that 48k will probably be the code limit
6k SRAM
11 choices of main clock prescaler
[E2A]
Hmmm, no PTC channels in a clear distinction to the tiny1 series.
Though doesn't answer your question (IIRC Rimu), the footprint for TQFP-48 may be in KiCad :
https://github.com/KiCad/kicad-footprints/blob/master/Package_QFP.pretty/TQFP-48_7x7mm_P0.5mm.kicad_mod
Rimu PCB
http://www.alpro.pl/hs/rimuuk.html
http://kicad-pcb.org/
PTC is also in PB megaAVR.
Maybe there will be a mega-1 series with PTC?
PTC?  don't ya just love TLA's!
TLA's FTW!
edit: The PTC is the "peripheral touch controller".
Microchip
Press Release
Digital Control Meets Intelligent Analog to Streamline Design
Simplify development of traditionally complex designs with new PIC® and AVR® families featuring Core Independent Peripherals and Intelligent Analog
Chandler, Arizona, Feb. 27, 2018
https://www.microchip.com/en/pressreleasepage/digital-control-meets-intelligent-analog
The new PIC16F18446 family of microcontrollers are ideal components for use in sensor nodes.
The introduction of the ATmega4809 brings a new series of megaAVR® microcontrollers that were designed to create highly responsive command and control applications.
The ATmega4809 has been selected to be the on-board microcontroller of a next-generation Arduino board.
Development Tools
Rapid prototyping with the ATmega4809 is supported by the ATmega4809 Xplained Pro (ATmega4809-XPRO) evaluation kit.
https://plus.google.com/+MicrochipTech/posts/K7z8yfvoJza
That is really sad news if they run 20MHz with +-2% :(
For not much money they could put a crystal oscillator on the board.
These chips can only take a 32kHz crystal or an external clock generator. So you either calibrate the internal oscillator based on a 32kHz crystal in software, or use a clock generator, which is more expensive than a simple crystal.
El Tangas wrote:
...or use a clock generator, which is more expensive than a simple crystal.
Surprisingly cheap in quantity and from China.
But still cheaper to use a 328PB and then only run 16MHz. (about same price 328P @ 20MHz).
This chip also only have 256 Byte EEPROM, registers aren't memory mapped , so there are many changes.
But the step size in speed @20MHz are big, so even perfect setting will not be better than about 1%.
And yes for the UART it can be taken care of , and for long time just use the RTC, but just a lot of changes.
Oh, ok I see, the steps are about 400kHz so you can never calibrate better than ± 1%.
Don't get me wrong it's a good chip for the price, just not only good things compared to a 328P.
New Microchip announcement on this here on the Freaks Forum, today.
So Microchip, back in the day when a new product was release Atmel would sometimes send out a bunch of the chips, kits, or boards to a number of AVR Freaks members.
I recall receiving a security kit, and the RZ Raven kit, and perhaps a couple others over the years.
The up side to this plan, no doubt written off to marketing, was that the new hardware was instantly in the hands of a number of experienced users who were very familiar with the IDE and with how things usually work, and who could take the new hardware for a test drive and quickly turn up any chip die errors, or data sheet errors, before the Revision B chip design was committed.
Besides the free "Beta-testing" (of a released product...), there was also, of course, a lot of free publicity on the new product.
 /<Hint hint>
JC  wink
Late too, already in post #34 above.wink
"Late" is relative.
Time is in someways meaningless.
The press release and social media threads were created approx 1200 MT which is approx 2000 CET likely after Microchip Norway COB.
Having 8-bit design centers around the world is good ... unless a director or executive has your mobile contact information wink
Microchip
Product Change Notification - SYST-26JZNY375 - 28 Feb 2018 - ERRATA - megaAVR® 0-series Errata Errata Document Revision
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=SYST-26JZNY375
Description of Change: Initial release of the document.
megaAVR 0-series Errata
data sheet sec 7.5.6:
For a write operation, the low byte of the 16-bit register must be written before the high byte. ??!!??
Is this chip different than other AVR chips (such as a mega88pa):
To do a 16-bit write, the high byte must be written before the low byte. For a 16-bit read, the low byte must be read
Not sure if this means anything...maybe it implies a direct write, rather than a sequence of steps...I hope the program can write to the eeprom1
why is the board $38, while this board is $8.88:
http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=ATMEGA328PB-XMINI
Hope some Chinese versions appear
16 bit access has been changed since the xmega series.
Writing from program to EEPROM is possible via NVMCTRL. This is also as usual.
Well, one is xplained "pro", the other "mini".
According to the Microchip press release linked in post #34, a new version of Arduino will have this chip. I'm sure Chinese copies will follow in due time.
what does that mean?  $38 vs $9...what do you get for the difference?
do you know when/where (has that been specifically mentioned)?  There have been some datasheets that have been in error
Microchip
megaAVR® 0-Series
Manual
Unified memory with a nonvolatile memory controller yet three references to instances of the SPM instruction.
Well, there are differences, I doubt they justify $30 though. I'll compare the tiny817, which has both versions:
Tiny 817 Mini:
Tiny 817 Pro:
So the pro has a few more features, uses the EDBG debugger instead of the mEDBG which is kinda slow.
"Core-Independent Peripherals"?
Can someone tell me what this means? Independent clock system? Independent in some other way?
Well, LMGTFY:
Core Independent Peripherals are designed to handle their tasks with no code or supervision from the CPU to maintain operation. As a result, they simplify the implementation of complex control systems and give designers the flexibility to innovate.
http://www.microchip.com/design-centers/8-bit/peripherals/core-independent/overview
cheeky
Over in PIC-world a CIP is a peripheral with 'smarts', as an example...
https://www.microchip.com/design...
The Pros are usually bigger boards (and bigger processors), and come populated with the XPro headers - so that you can plug on XPro expansion boards.
As the name (and price) suggests, the Minis are smaller and don't have the extras.
ATTINY817-XMINI Microchip Technology | ATTINY817-XMINI-ND DigiKey Electronics
EDIT
Actual picture of the ATtiny817 Xplained Pro:
http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=ATTINY817-XPRO
(future) product web pages with preliminary datasheets were created for the 28-pin and 32-pin variants :
http://www.microchip.com/wwwproducts/en/ATMEGA3208
http://www.microchip.com/wwwproducts/en/ATMEGA4808
The LC filter on mega4809's AVDD in Xplained Pro :
  • ferrite bead, Murata BLM18PG471SN1, 1A, 470 ohms at 100MHz, 260mohm max ESR, 1608 metric
  • capacitor, 100nF MLCC 16V X7R
The same ferrite bead is on UC3A4 (EDBG) VDDANA and UC3A4 USB_VBUS.
USB VBUS is filtered; external 5V power is not filtered.
P.S.
megaAVR 0-series schematic checklist?
Reason: IO rise and fall times are greatly less than PB megaAVR.
or is the AVR EMC application note adequate?
https://www.mouser.com/Search/Refine.aspx?Keyword=BLM18PG471SN1
https://www.mouser.com/new/murataelectronics/murata-blm-emi-filter/
Application Notes
AN_1619 AVR040: EMC Design Considerations
http://www.microchip.com//wwwAppNotes/AppNotes.aspx?appnote=en590907
via http://www.microchip.com/wwwproducts/en/atmega324pb
Yes, this note appears in the Xmega timer manual (AVR1306):
       ...Note that on the XMEGA, the byte order for multi-byte access is always from the least significant byte to the most significant byte.
So does the megaAVR 0-series follow along with Xmega, or use the classic mega avr sequence?
They had the datasheet for the mega328PB reversed (following xmega) & finally corrected it:
YouTube
ATmega4809 8-bit High-Performance AVR CPU
Published on Feb 27, 2018
https://www.youtube.com/watch?v=SScQqkGWoB0 (4m35s)
via https://plus.google.com/+MicrochipTech/posts/dUMpErLv4cy
EDN
New brain for the Arduino, and…PICkit 4
by  (EDN Editor in Chief)
March 02, 2018
https://www.edn.com/electronics-products/electronic-product-reviews/other/4460386/New-brain-for-the-Arduino--and-PICkit-4
... it [mega4809] shares the basic characteristics of the somewhat-stuck-in-time AVR family.
Onto Microchip’s most-loved child, the PIC. The new PIC16F18446 is another overachiever when it comes to peripherals.
Finally, there’s the new PICkit 4 programmer/debugger ($48). Let’s hope it rights some of the wrongs perpetrated by the deposed PICkit 3. Especially, in my case, the inability to function at the 3V of my project! On the plus side, brownie points to any company that offers multi-platform support (it works under MacOS, Linux, and even Windows).
In the March 7, 2018 Embedded.com newsletter, Mega4809 is going to be the new Arduino MCU.
https://www.embedded.com/electro...
I think that is absolutely fantastic!  Simonetta is going to have to change the Mantra!
Blinky :
YouTube
Getting Started with the ATmega4809
https://www.youtube.com/watch?v=HUPSwIp-09E (1m39s)
This Xplained Pro board features the newly released ATmega4809 microcontroller. This device is packed with features such as Core Independent Peripherals, Event System, Intelligent Analog and Low Power. Programming the Xplained Pro board is easy and fast with Atmel Studio and Atmel Start. In this video we are demonstrating how you can get up and running with the Xplained Pro board with a Blink application in minutes.
via https://plus.google.com/+MicrochipTech/posts/NcA9HnJsZX7
YouTube
Microchip
eeNews Report on Embedded World 18
https://youtu.be/3Lq3Qh4ue7w?t=4m24s (mega4809 for almost 2m duration, earlier is a new PIC with a 12b ADC and doubled flash and RAM)
via
Lucio Di Jasio discusses the latest additions to our portfolio of 8-bit micro...
https://plus.google.com/+MicrochipTech/posts/gVm4WS3Wnjf
Will the mega4809 Arduino have EDBG?
(no answer is likely the best answer assuming there's an NDA in place)
Likely yes (mEDBG) due to mega32U4; see https://www.avrfreaks.net/forum/megaavr-0-series?page=1#comment-2470876
Reasons :
  1. Arduino Zero has EDBG
  2. Microsoft Arduino extension to Visual Studio Code
https://store.arduino.cc/usa/arduino-zero
Visual Studio Marketplace
Arduino
https://marketplace.visualstudio.com/items?itemName=vsciot-vscode.vscode-arduino
(2/3 page)
Debugging Arduino Code preview
[Arduino Zero, EDBG]
AVR Studio On Mac & Linux?
by ka7ehk
https://www.avrfreaks.net/forum/avr-studio-mac-linux
https://www.avrfreaks.net/forum/avr-studio-mac-linux#comment-2440271
Edits: strikethru, mEDBG
New arrival at Mouser :
Mouser Electronics  - Electronic Components Distributor
Mouser
ATmega4809 Xplained Pro Evaluation Kit
https://www.mouser.com/new/microchip/microchip-atmega4809-xpro/
ARDUINO UNO WiFi REV2
https://store.arduino.cc/arduino-uno-wiFi-rev2
Arduino Uno form, ATmega4809, ATECC608, IMU, Wi-Fi System-on-Chip
[ATmega4809, Wi-Fi SoC, IMU, ATECC608A crypto-authenticator]
via
Arduino Blog » Say hello to the next generation of Arduino boards!
by Arduino Team
May 17th, 2018
https://blog.arduino.cc/2018/05/17/say-hello-to-the-next-generation-of-arduino-boards/
Those heading to Maker Faire this weekend are invited to attend Massimo Banzi’s semi-annual ‘State of Arduino’ talk, where you can learn more about our latest developments including the MKR Vidor 4000, Uno WiFi Rev2, and our Arduino Day releases.
Both the MKR Vidor 4000 and Uno WiFi Rev2 will be available on the Arduino online store at the end of June.
via https://plus.google.com/u/0/106109247591403112418/posts/AmQsbfVdtb4 (404 error)
https://www.microchip.com/wwwproducts/en/ATMEGA4809
https://www.microchip.com/wwwproducts/en/ATECC608A
https://www.u-blox.com/en/product/nina-w10-series
Edit : tech specs tab added to https://store.arduino.cc/arduino-uno-wiFi-rev2
Edit : strikethru
Edit : 404
Edit: Wi-Fi module's URL
Hmm, that says "It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz ceramic resonator, a USB connection, a power jack, an ICSP header, and a reset button. "
- but the image shows a crystal on the Mega23U, and what looks like just 32KHz support (EPSON?) on 4809 ? Or has the 4809 secretly added Crystal Oscillator back into the mix ?
Or is this just lazy copy/paste ?
Other designs have allowed a CLK out from the Debug chip, to feed the MCU, but I don't think they did that here ?
Any Schematics ?
Is that a thermal relief around the thermal pad of that voltage regulator?
Looks like it - did you not expect that ?
Fairly common to do that to help better soldering flows. The added thermal resistance is tiny, compared to all the J-A adders.
Who-me wrote:
... and what looks like just 32KHz support (EPSON?) on 4809 ?
Yes
No
A mistake
EXTCLK goes to a via then to ?
An educated guess is EXTCLK is connected to mega32U4 high speed T/C 4 OC.4A or its CLKO.
tiny817 Xplained Mini mEDBG has an optional clock out to the tiny817.
mega4809 Xplained Pro has mega4809 EXTCLK to a header pin.
Who-me wrote:
Any Schematics ?
Couldn't locate it from a first guess on a location.
Hackaday.io
ATMega4809 developing board project
https://hackaday.io/project/134831-atmega4809-developing-board-project/
mega4809, mega88PA for UPDI, FTDI FT2232D USB dual UART, OLED
Details
Blinky test on ULTRA 4809 Explorer
https://hackaday.io/project/134831-atmega4809-developing-board-project/log/146590-blinky-test-on-ultra-4809-explorer
In the working directory, we also need  "avrdude.conf", which is available at ELTangas's jtag2updi repository.
via https://plus.google.com/u/0/106109247591403112418/posts/fBB4ycKiQTi
    I thought they resist to add Xmega to Arduino in order to be consistent on using the Mega328. Now I see they skip Xmega. Why ? What's wrong with Xmega ?
3.3v only operation ?
Nice, I'm happy that someone is using my programmer software on a product. From my github traffic, I can add that this board can be purchased here: https://www.tindie.com/products/...
And the fact that in this board an atmega88 is used to host the firmware made me notice that I can easily reduce the size of an array (I left a huge safety margin) and make it fit in an atmega48. That would save a few cents to the designer, not that it really matters in this case.
In Bob Martin's right hand is what appears to be an Arduino Uno WiFi rev 2 :
https://plus.google.com/+MicrochipTech/posts/PriSVyixBd6
What's with the clear plastic holder / case thingy ?
Maybe it's the display model from the Bay Area Maker Faire (mid-May'18)
wafer fabrication is by Microchip :
Product Change Notification - GBNG-06LXXH156 - 25 Jun 2018 - CCB 2856 Final Notice: Qualification of Microchip Fabrication site (FAB 4) for selected Atmel products manufactured with the 59.91K process technology.
http://www.microchip.com/mymicrochip/NotificationDetails.aspx?pcn=GBNG-06LXXH156
https://www.microchip.com/mymicrochip/Data/GBNG-06LXXH156/GBNG-06LXXH156_Affected_CPN_06252018.pdf
Affected Catalog Part Numbers (CPN)
ATMEGA4809-MFR
ATMEGA3209-MFR
ATMEGA4808-MFR
ATMEGA3208-MFR
ATMEGA4808-AFR
ATMEGA3208-AFR
ATMEGA4809-AFR
ATMEGA3209-AFR
Do we have any idea what is "59.91k process technology" ?
Was curious myself.  Google just points me to Microchip PCNs.
"Read a lot.  Write a lot."
Arduino - ArduinoUnoWiFiRev2
Getting started with the Arduino Uno WiFi Rev2
https://www.arduino.cc/en/Guide/ArduinoUnoWiFiRev2
Please Read...
https://www.arduino.cc/en/Guide/ArduinoUnoWiFiRev2#toc11
The programming of the MEGA4809 happens through an ATmega 32U4 programmed with the mDBG code and creates a virtual COM port when connected to a PC.
Last revision 2018/06/26 by SM
mDBG? Do they mean mEDBG?
Yes though there's not much mEDBG at arduino.cc
mega3209 is a new arrival at Mouser :
https://www.mouser.com/new/microchip/microchip-atmega3209-mcu/
A wee bit more information in an interview of Fabio Violante (Arduino CEO) by Microchip's Bob Martin at the 2018 Bay Area Maker Faire.
Arduino and the Maker Movement: A conversation with Arduino’s CEO - YouTube
Jul 18, 2018
https://youtu.be/xFD6c_FhL2Q?t=3m35s for 1m45s
earlier in the video is on Arduino's MKR (SAM D21) series with a goal of low-rate production for customers in addition to prototyping.
HP InfoTech
CodeVisionAVR V3 Revision History
http://hpinfotech.ro/cvavr_revision3.html
V3.33 Commercial Release
  • Compiler
  • Added compiler support for the AVR8X ATmega3208/3209/4808/4809 chips
  • Improved the code generated for the AVR8X chips
  • Fixed: @ operator address check for AVR8X EEPROM variables
  • CodeWizardAVR
    • Added a new Wizard for the AVR8X chips: ATtiny414/416/1614/1616/1617 and ATmega3208/3209/4808/4809
  • Chip Programmer
    • Added support for the Microchip EDBG programmer
YouTube
How to Use the Event System with AVR® ATmega4809
Aug 21, 2018
https://www.youtube.com/watch?v=WosagCSKdng (3m47s)
Have you ever wanted to periodically sample an ADC without using code? Have you ever wanted to trigger sensor readings without using CPU resources to do so? The Event System is a feature on some newer AVR® devices that allows autonomous communication between peripherals. This means that you can now trigger sensors, timers, and readings without needing CPU intervention. In this tutorial we will not only cover how to set up the Event System on an AVR device; but we will also cover how to utilize this feature to take more workload off of your CPU.
The forthcoming Microchip alternative :
Development Environment tab
(bottom)
AVR.IoT ATmega4808 WiFi ( AC164160 )
Hopefully will have EDBG instead of mEDBG (speed, etc); maybe nEDBG is good enough.
Likely will have a Microchip Wi-Fi module instead of an ESP32 module.
On same page is
ATmega4809-CNANO ( DM320115 )
(the fuzzy picture)
mega4809 with debugger on a breakout that's all pins (it's long) and 600mil wide, push button, LED is likely
NANO may mean nEDBG.
nEDBG is on the PIC16F18446 Sensor Board.
https://www.microchip.com/wwwproducts/en/PIC16F18446
Arduino Uno WiFi Rev2 will be a new arrival at Mouser with an ETA of 06-Nov-18. 31-Oct-18
https://www.mouser.com/new/arduino/arduino-uno-wifi-rev2/
Edits: typo, strikethru
Microchip logo
Press Release
Create Secure Connected Applications in a Single Click with Microchip’s AVR MCU Development Board for Google Cloud
New solution enables developers to easily deploy IoT devices to Google Cloud IoT Core’s artificial intelligence and machine learning infrastructure
Chandler, Arizona
October 10, 2018
https://www.microchip.com/en/pressreleasepage/AVR-IoT-WG-development-board
The AVR-IoT WG Development Board gives developers the ability to add Google Cloud connectivity to new and existing projects with a single click using a free online portal at www.AVR-IoT.com.
  • Powerful AVR microcontroller (MCU) with integrated peripherals: The ATmega4808 8-bit MCU brings the processing power and simplicity of the AVR architecture with added advanced sensing and robust actuation features. With the latest Core Independent Peripherals (CIPs) that decrease power consumption, it provides cutting-edge performance in real-time sensing and control applications.
[ATECC608A, ATWINC1510]
Pricing and Availability
The AVR-IoT WG Development Board (AC164160) is available in volume production now for $29 each. For additional information, contact a Microchip sales representative, authorized worldwide distributor or visit Microchip’s website. To purchase products mentioned in this press release, visit the AVR-IoT portalvisit our purchasing portal or contact one of Microchip’s authorized distribution partners.
AVR IoT WG Development Board Introduction - YouTube
by Microchip Technology
Oct 10, 2018
https://www.youtube.com/watch?v=BqjFZjdBLH8 (3m56s)
via https://plus.google.com/+MicrochipTech/posts/X12HREh5HHT
Everything Supercon: This. Is. Big. | Hackaday
by
October 8, 2018
https://hackaday.com/2018/10/08/everything-supercon-this-is-big/
Come one, come all, this is the megapost about the Hackaday Superconference. Join us in Pasadena on November 2-4 for the hardware conference you cannot miss. Get your ticket quickly as they will sell out!
Prototyping IoT Applications Using the AVR-IoT WG Development Board
via https://plus.google.com/+MicrochipTech/posts/6LTrUeocKu6
I'm sure it will be a great conference, but this November I'm going to Electronica, it's closer to home and my funds are not unlimitedfrown
Getting Started With Your AVR-IoT WG Development Board - YouTube
Oct 10, 2018
https://www.youtube.com/watch?v=WK4ljyKDMIQ (6m26s)
via https://plus.google.com/+MicrochipTech/posts/7pLed2HKFf5
1.2.272 (2018-09-14)
Corrected CLKCTRL signals, ALT out signals and interrupt edge triggering values for CCL and added SEQCTRL1 for ATmega4809, ATmega4808, ATmega3209 and ATmega3208.
Corrected RW status on MCLKSTATUS register.
Added ATmega1609, ATmega1608, ATmega809 and ATmega808.
Interesting. So that's (likely) the megaAVR 0-series family complete. You can't go bigger than 48k because of the way the memory is mapped, it probably doesn't make sense to go smaller than 8k, it also probably doesn't make sense to go more than 48 pins, and you'd never fit all the functionality is less than 28 pins.
The tinyAVR 1-series is looking to be complete, unless there are plans for 48k devices, as is the tinyAVR 0-series.
It seems I also need to add the ATmega1609, ATmega1608, ATmega809 and ATmega808 to the avrdude.conf file in my programmer.
BTW, tiny3204, tiny3206 and tiny3207 are also missing in my avrdude.conf, but they don't seem to be planed even as future products.
USB megaAVR are popular.
Prediction - megaAVR 1-series
Updated USB device controller, unified memory, ...
Currently future product :
ATmega1609
ATmega1608
ATmega809
ATmega808
the overview say :
 The series uses the latest Core Independent Peripherals with low power features.
is that new version or just a bug fixed one ?
IIRC, CIP is from the PIC side of the house.
If you say so.  I always thought that Microchip's "Core Independent Peripherals" and Atmel's "Event System" and/or "Sleepwalking peripherals" were approximately the same thing.  (though I haven't looked at either one in enough detail to see if there are any important differences.)
It's my assumption.
In '11, became aware of the Charge Time Measurement Unit (CTMU) in some PIC18F where the CTMU is sensing touch buttons while the CPU sleeps.
Atmel QTouch is implemented by library software (CPU) that was improved by some PB megaAVR with the Peripheral Touch Controller (PTC)
AVR32 UC3L has an autonomous touch button hardware interface (Capacitive Touch or CT) to wake the CPU.
Waking up a capacitive touch-sensing device with an MCU peripheral
Nithin Kumar Mada and Harsha Jagadish, Microchip Technology - July 27, 2011
When a capacitive touch screen goes into sleep or standby mode to save energy, how can you design the system to wake up quickly without degrading its performance or burning a lot of power. Here are two options: a traditional method and a new MCU-based method.
https://www.embedded.com/print/4218309
Overview of Charge Time Measurement Unit (CTMU)
https://www.microchip.com/stellent/groups/SiteComm_sg/documents/DeviceDoc/en542792.pdf
(page 32)
Other Applications of CTMU
[capacitance sensing, TDR, precise time, temperature sensing, humidity sensing, DAC]
Total votes: 2
The code for the new ATmega4809-based Arduino board has been checked in:
https://github.com/arduino/ArduinoCore-megaavr
    How they run it at 16MHz ? I thought it will run at 20MHz. Is the schematic available ?
Couldn't quickly locate the schematic of Arduino Uno WiFi rev2.
Its competitor is AVR-IOT WG Development Board
AVR-IOT WG's mega4808 is on page 3 at B3 :
http://ww1.microchip.com/downloads/en/DeviceDoc/AVR-IoT_WG_Schematics.pdf
To megaAVR 0-series UARTs were added autobaud (BREAK, SYNC, data) and FBRG.
AVR-IOT WG's nEDBG SAMD21 (page 2, C5) has access to USB SOF for creation of an accurate internal clock.
Edit: page 2
ATmega4809 Curiosity Nano
has separate LDO for mega4809 and nEDBG SAMD21 such that mega4809 VCC can be nearly USB VBUS.
http://ww1.microchip.com/downloads/en/DeviceDoc/ATmega4809_Curiosity_Nano_Schematics.pdf
in stock
lead time is 15 weeks
ABX00021 Arduino (Uno WiFi Rev2) | Mouser
ARDUINO UNO WiFi REV2, documentation tab
That's a lot of level shifters.
And man, that power supply just keeps getting more and more complicated.  Six transistors, now!  (oh wait - the opamp is gone...)
Am I missing something?   Were there spectacular problems with the old design?  Is there something wholy awful about a couple of diodes?
(and you'd think that someone would have put this whole "USB or external power to 5 and 3V @500mA total" on a single chip/module by now...)
Did someone test the Arduino Uno WiFi Rev 2 ?
It is very strange to see "coming soon" at the Arduino store, as if it had not arrived !
But it is available at Mouser ...
Bernard.
No, but I've been playing with the code using an Xplained Pro board.
That's the lovely thing about Open Source - you can analyze it, criticize it, submit bugs, even write fixes, all without actually contributing to the vendor's revenue stream!
You're onto something really handy (breadboards, typical protoboards)
top left at ATMEGA4809 - 8-bit AVR Microcontrollers - Microcontrollers and Processors
Do you think they'll come with a DIP40 version of the 4809?
Arduino Uno WiFi (the one with the mega4809 on it) is now in stock at Farnell...
https://uk.farnell.com/arduino/a...
Total votes: 2
Soon...
