I need to write a small project on an existing PCB using the UC3C2256. I have written code for Atmel AVR8s for years and have never used the clunky, bug-laden Atmel Studio.
I compile using either the Arduino compiler and programmer, or I've used the (older) HiTech compiler and an AVR ISP device to program. I prefer the latter: a command-line compiler and then the Atmel ICE or mkII (I have both).
I use Debian because I do a lot of CNC-related things and LinuxCNC no longer supports Ubuntu.
I also use Windows 7 Pro.
Either environment is fine with me.
I greatly appreciate any guidance! Thank you.
