serial communication
22 posts / 0 new
hi ,
im using atmega328pb mcu with a6 module, ive attached the schematic of my board ,
i wanted to check the a6 module is working by giving AT commands through putty serial and a usb to serial converter, i tried it by connecting tx rx gnd of ftdi to j6 test points on my board.
the putty terminal wont work, what am i missing here ?
What is an "A6" module? Is it a GSM device? Your schematic does not seem to show much. For example, where is the module, how is it powered, and what are the connections between the MCU and the A6 device? Yes, I could probably find them, but some are off the edge of the image.
Have you verified whether or not there is any serial data on the UART TX and RX lines?
yup its a gsm module , check out the second attachement
There is no second attachment!
Rather than attach the schematic, it's clearer if you embed it in the post - where we can actually see it.
Instructions here: https://www.avrfreaks.net/comment...
Go on - how about giving full make & model? And link to a datasheet?
ensure you connect tx to rx & rx to tx, otherwise won't work. You don't show the FTDI chip, so who knows what you did
how about the right baud rate?
Not necessarily.
Strictly, a GSM module or modem is a DCE and, at a DCE, "TXD" is an input.
http://www.ece.ubc.ca/~edc/464/lectures/lec14.pdf
This is because the original RS232 specification defined the connection circuits - not the pins on the device:
The TXD circuit is the connection which carries the data to be transmitted from the DTE to the DCE - thus it is an output from the DTE, and an input to the DCE.
See the table here: https://en.wikipedia.org/wiki/RS-232#3-wire_and_5-wire_RS-232
Also: https://en.wikipedia.org/wiki/RS-232#Connectors
See also: https://www.avrfreaks.net/comment...
This convention is not well respected nowadays, so you just have to check specifically whether the pin marked "Tx" is actually an input or an output.
What do you mean, "won't work" ?
Wrong baud rate generally results in "garbage" characters being displayed; eg,
Baud Mismatch
See: https://learn.sparkfun.com/tutorials/serial-communication
#DteDce
EDIT
Add Wikipedia links
EDIT 2
and old topic link
EDIT 3
Note that V.24 takes the same approach in defining "Interchange Circuits":
  • CT103 is equivalent to TXD - which is an output from the DTE and an input to the DCE;
  • CT104 is equivalent to RXD - which is an input to the DTE and an output from the DCE.
https://www.itu.int/rec/dologin_pub.asp?lang=e&id=T-REC-V.24-199303-S!!PDF-E&type=items
ITU-T V.24 wrote:
Circuit 103 – Transmitted data
Direction: To DCE
The data signals originated by the DTE:
  1.  to be transmitted via a data channel to one or more remote data stations;
  2.  to be passed to the DCE for maintenance test purposes under control of the DTE; or
  3.  for the programming or control of serial automatic calling DCEs,
are transferred on this circuit to the DCE.
Circuit 104 – Received data
Direction: From DCE
The data signals generated by the DCE:
  1.  in response to data channel line signals received from a remote data station;
  2.  in response to the DTE maintenance test signals; or
  3.  in response to (or as an echo of) programming or control signals from the DTE where a serial automatic calling facility is implemented in the DCE,
are transferred on this circuit to the DTE.
I'm referring to connection between the AVR & the FTDI chip.
Sadly, you are quite correct---must always check!
Ah - OK.
But the OP might still want to check the connections to the GSM thingy - to ensure "Tx" and "Rx" are correct ...
here's the schematic of a6
But that is surely just the "module"? The important schematic is how the module connects to the AVR
Like this:
and you still haven't answered the other questions:
I guess that would be via the 'GSM_TX0' and 'GSM_RX0' off-sheet connectors?
There's a barely legible company name on that "mENSMART Wireless Module Circuit" - looks like: http://mathiimigaltech.com/
Do you work for this company, or are they just the module manufacturer?
that "mENSMART Wireless Module Circuit" appears to show two UARTs connected in parallel:
In particular, connecting two outputs together is not going to work.
Presumably, some of those resistors are (or should be) not fitted ... ?
i removed those jumper resistors still no improvement
a6 datasheet
https://www.google.co.in/url?sa=...
baud 9600
which jumper resistors, exactly?
If you removed them all then, obviously, it won't work!
And still no answers on the other questions:
  • baud rate?
  • ensure "Tx" and "Rx" are correct?
  • Do you work for "Mathiimigal Tech", or are they just the module (or board or "unit") manufacturer/supplier - or what?
EDIT
clarify "manufacturer"
That datasheet doesn't help to clarify the directions of "TXD" and "RXD" - so you're going to have to do that some other way.
But the datasheet does tell you that they are 2.8V
Your schematic shows the microcontroller is 3.3V - so you're taking a bit of a risk there ...
You did prototype this before making a PCB, didn't you ... ?
Same applies to a WiFi module ...
https://alselectro.wordpress.com...
this guy has connected to arduino .
no prototype
no prototype
Time to start one, then!
What kind of goofballs name a part the "A6"---makes me wonder if I'd ever buy anything from such a place.  That's not much of a search filter.  How about a part called "G" & do a search for that?
In any case, since it is described as having "uart pins", I believe you need to hook txd to rxd
