Porblem with 16bit uint comparison in 8bit AVR
16 posts / 0 new
Hello guys, I have been programming an ATMEGA16 using Atmel Studio 7 in assembly so far and I am now moving in C. The project I am on is not that hard but I fell into a minor problem. I have a simple function that takes a 16bit uint and only contains a switch. I noticed that it only works for the cases that involve the 8 LSB of the 16bit uint while every other case just goes to default. I suppose this has to do with the fact that ATMEGA16 is an 8bit controller and the switch involves a comparison which only occurs for the 8 LSB. Of course the simple solution would be converting my 16bit number into 2 8bit numbers and having 2 switches instead. So my questions are:
1) Atmel Studio really does not support comparisons with 16bit integers or it can be done with maybe some type casting?(I did try some type castings but I seemed to get the same result every time)
2) If it is not supported is there a smarter way than converting the number into 2 8bit numbers?
3) Is there an option that makes it show warnings for that? (which in my opinion should show up in the first place)
I am also attaching my code. Thanks for your time! smiley
uint8_t keypad_to_ascii_single_switch(uint16_t keyspressed)
	switch(keyspressed)
		case 0x0001:
		return 'E';
		case 0x0002:
		return '0';
		case 0x0004:
		return 'F';
		case 0x0008:
		return 'D';
		case 0x0010:
		return '7';
		case 0x0020:
		return '8';
		case 0x0040:
		return '9';
		case 0x0080:
		return 'C';
		case 0x0100:
		return '4';
		case 0x0200:
		return '5';
		case 0x0400:
		return '6';
		case 0x0800:
		return 'B';
		case 0x1000:
		return '1';
		case 0x2000:
		return '2';
		case 0x4000:
		return '3';
		case 0x8000:
		return 'A';
		default:
		return 0;
There is absolutely no reason why a switch on a uint16_t should not work correctly - the 'C' compiler handles getting that right.
You need to post a minimum but complete program which illustrates the problem.
At a guess, I would say that the most likely problem is with the value you are passing in to the function - so how have you verified that it is correct?
The ATMega16 has on-chip debug - so the most obvious way would be to simply step into the function and see what's happening!
You could also do that in the simulator.
Of course Studio can handle this
I tend to find that a simple switch "lookup table" is more clearly written like this:
	switch(keyspressed)
		case 0x0001: 	return 'E';
		case 0x0002: 	return '0';
		case 0x0004:	return 'F';
		case 0x0008:	return 'D';
		case 0x0010:	return '7';
		case 0x0020:	return '8';
		case 0x0040:	return '9';
etc, ...
EDIT
typo
Show the invocation of the function. There may be some promotion/truncation happening there.
Yep - that's the kind of thing I was thinking of with, "the most likely problem is with the value you are passing in to the function" ...
Thanks for your instant reply awneil. I am having the 16bit number converted into 2 8bit numbers and displayed on LEDs to verify it is indeed a 16bit number. But you are right since adding the Number=0x1000; line or the keyspressed=0x8000; works as expected. However the displayed values at the LEDs in PORTA and PORTB are correct when using the number returned from scan_keypad_rising_edge() which is strange. I did use Studio's debug and the switch function was entered with Number=0x1000 and it selected the default case instead of the case 0x1000 as you can see in the pictures attached. So the program works fine if it is given a value but does not work as expected if the value is returned from the function scan_keypad_rising_edge() even though the value returned is a valid 16bit uint. Any ideas?
This is my complete code
#define F_CPU 8
#include <util/delay.h>
uint16_t *PreviousNumber;
uint8_t scan_row(uint8_t rownumber);
uint16_t scan_keypad();
uint16_t scan_keypad_rising_edge();
uint8_t keypad_to_ascii_single_switch(uint16_t keyspressed);
    uint16_t Number=0;
    while (1)
    Number=scan_keypad_rising_edge();
    //Number=0x1000;
    if(Number)
        DDRA=0xff;
        DDRB=0xff;
        DDRD=0xff;
        uint8_t NumberH,NumberL;
        NumberL=Number&0x00ff;
        NumberH=(Number>>8)&0x00ff;
        PORTA = NumberL;
        PORTB = NumberH;
        //uint16_t debug=0;
        PORTD = keypad_to_ascii_single_switch(Number);
    _delay_ms(10);
    //keyspressed=0x8000;
    switch(keyspressed)
        case 0x0080:	return 'C';
        case 0x0100:	return '4';
        case 0x0200:	return '5';
        case 0x0400:	return '6';
        case 0x0800:	return 'B';
        case 0x1000:	return '1';
        case 0x2000:	return '2';
        case 0x4000:	return '3';
        case 0x8000:	return 'A';
        default:	return 0;
uint8_t scan_row(uint8_t rowNumber)
	DDRC=0b11110000;
	uint8_t row=0b00010000;
	for(uint8_t i=1;i<rowNumber;i++)
		row=(row<<1);
	PORTC=row;
	asm volatile ("nop");
	uint8_t readNumber=PINC&0b00001111;
	//PORTC = readNumber; debug
	return readNumber;
	uint16_t ReadNumber=0;
	uint8_t rowNumber;
	for(rowNumber=1;rowNumber<=4;rowNumber++)
		ReadNumber= (ReadNumber<<4);
		ReadNumber|=scan_row(rowNumber);//+= not correct.
	return ReadNumber;
	uint16_t ReadNumber1,ReadNumber2,Previous;
	ReadNumber1=scan_keypad();
	_delay_ms(15);
	ReadNumber2=scan_keypad();
	ReadNumber2&=ReadNumber1;
	Previous= ~(*PreviousNumber);
	*PreviousNumber=ReadNumber2;
	ReadNumber2&=Previous;
	return ReadNumber2;
It might not be the problem, but where does "uint16_t *PreviousNumber" point to?
The idea is to store the PreviousNumber that was read from the keypad, complement it and then with a logical AND with the currently pressed buttons you should only have the ones pressed now. It is used only in the scan_keypad_rising_edge() function. It seems to be working fine (if I keep a button pressed and then press a new one only the value of the new one is returned)
But that hasn't answered what it points to. You create a POINTER TO uint16_t but I don't see where you ever assign an address of a unit16_t to that pointer ? But later you write through the pointer with *PreviouNumber=xxx
Why is PreviousNumber even a pointer  in the first place? Why not a simple uint16_t?
I was transferring my program from assembly to C and a pointer was used there but you are right it is not needed. Also making it a simple uint16_t fixes the problem laugh Thank you!!!!! And now I must ask... I thought that when you create a pointer to a uint16_t it is automatically assigned an address which is obviously wrong. How do you assign an address to the pointer?
So what made you think that?
Indeed!
Go on - what does your 'C' textbook say?
How about:
uint16_t   a_uint_16;
uint16_t * pointer_to_uint_16;
pointer_to_uint_16; = &a_uint_16;
Here are some 'C' learning & reference materials - including a free online textbook: http://blog.antronics.co.uk/2011...
One of the classic errors in C. Perhaps THE classic error is creating pointers that then do not have a valid target when you write through them. Creating pointers does NOT create assigned storage. You either need to malloc() or you need to use &some_object to assign to the pointer to give it the storage it can then read/write.
It sounds like the OP is confusing the storage for the pointer itself - which, of course, has to be created when the pointer is created - with the storage for whatever the pointer points to.
As you say, that's probably quite a common confusion/misunderstanding.
EDIT
See also: https://www.avrfreaks.net/comment...
Indeed!
How about:
uint16_t   a_uint_16;
I tried that before but I tried it right under the declaration (which is outside of functions) and I got compile errors. I added the address assignment inside main and now it works! Thank you smiley
To be honest it has been more than a year since I last used pointers so I needed some refreshing. The fact that the function that had to do with the pointer returned a result that seemed correct completely mislead me. That and the fact that at the debugging the contents of the location pointed by the pointer were correctly updated.
Yes I get it now. Thanks for finding that mistake! I would have never found it  cheeky
Of course - because 'C' does not allow executable code outside of functions.
But you could have initialised it in the definition:
uint16_t   a_uint_16;
uint16_t * pointer_to_uint_16 = & a_uint_16;  // Definition with initialisation
The above is not specific to pointers.
Definitely time for a re-read of that textbook...
wink
Just because something appears to "work" doesn't necessarily mean it's correct!
"Beware the 'Proven Product' Syndrome"
eg, see: https://www.avrfreaks.net/comment...
Credit where credit is due. It was 'tedy' who actually spotted / fixed this. I simply pointed out you hadn't answered the question he asked.
wink
That is 100% correct cheeky
Yes you are right!
Thank you tedy! You fixed my problem!laugh
