Is something wrong with my Atmega8A-PU
46 posts / 0 new
Hi, I am a beginner to microcontrollers.. I bought a programmer (AvrProg USB v3) and Atmega8A-PU. I successfully connected it together and in my atmel studio I managed to read my device using tools > device programming.
Until that, I was successful. But when I tried to connect diode and make it light, I can't get a result. Nothing happens.
The simplest possible I wrote is this:
#include <asf.h>
int main (void)
	board_init();
	DDRD = 0xFF;
	PORTD = 0x00;
	while(1) {
		// this maybe useless
But no matter what I do, the diod is not blinking on (btw I connected longer end to PD0 and shorter end to ground, which is probably obvious from the code).
Am I doing something wrong? Can i somehow find out there is something wrong with my chip? Thank you.
I don't use C, so some others can help out here, but a few things to keep in mind:
You generally need a instruction that tells the compiler the clock frequency of the micro, (e.g. 8 MHz, or whatever).
For the LED to blink, you need to turn it on, wait a while, then turn if off, and wait a while, then loop.
Pseudo code:
Definitions, compiler info
Main:
configure I/O pin for output
Do
  turn on LED, (set the I/O pin High)
  delay 500 mSec
  turn off LED, (set the I/O pin low)
  delay 500 mSec
Loop
Additionally, you need to have a 330 ohm or 470 ohm resistor or something similar in series with your LED.
Welcome to the Forum.
sorry that was a mistake, I corrected it, I want the diode just to be on. To see the light, nothing more. But it doesnt work.
Indeed.
See, for example: https://electronicsclub.info/leds.htm
It's unhelpful to change your post after people have replied to it - because it makes nonsense of the replies!
So have you tried it with just the LED and resistor ?
(if you tried connecting just the LED to a power supply with no resistor, you have probably blown the LED).
I saw it in some youtube, that since i am using 3.3V that it shouldn't hurt the diode for a while. Anyway i took new diode and added 330 ohm resistor, but the program is not working.
I get no error, build runs and the avrprog diode blinks to indicate the program is being uploaded to the chip.
LED circuit symbol
LED connections
So, in other words: you connected the anode to PD0 and cathode (or "kathode") to ground.
So that's the lower of these two:
sinking and sourcing current
https://electronicsclub.info/ics.htm
Which means that you need to set the port pin high for the LED to light.
But your code sets it low.
good point, I set it to 0x01 but it still doesnt do anything.
Sorry, that's just wrong.
The length of time it takes to blow up semiconductors like LEDs is measured in thousandths of a second!
Again, does it work without the microcontroller - just the LED, resistor, and power supply?
yes
#include <asf.h>
int main (void)
	board_init();
	DDRD = 0xFF;
	PORTD = 0x00;
	while(1) {
Hmm...  Why are you using ASF with an old, 8-bit device, as ASF has little to no support for old, 8-bit devices.  What board are you using?
Greg Muth
Portland, OR, US
Make Xmega Great Again!
I actually do not have a clue what is it for, I followed some tutorial and didn't focus on that.
I tried to create project without ASF, so now its just
    DDRD = 0xFF;
    PORTD = 0x01;
    while (1)
still no result.
1. do not connect LED directly to MCU otherwise you will damage both MCU and LED, use a resistor seried with LED to limit current,
2. you need to know max rating current and forward voltage of your LED , to calculate resistor value, if you cant calculate, any value 220 ohm to 560 ohm will be fine
3. put the resistor between MCU and LED.
4. PORTD = 0x00 means set port pins to 0V , so your code is wrong, you need to set pins to Vcc (maybe 5V) : PORTD=0xff will set all pins to Vcc, PORTD=0x01 will set just pin0 to Vcc
5. longer lead generally is anode but maybe not in some LEDs, after correcting your code if still not work, try reverse LED connection
Majid
tried all, still nothing happening.
Time to post a schematic (aka "circuit diagram") of your setup.
Also a good, clear, in-focus photograph (or photographs) where all connections can clearly be seen.
Instructions on how to post images (photos & schematics): https://www.avrfreaks.net/comment...
This is how it looks, no exposed wires are touching..
I am not sure how to draw this circuit diagram (never did it with MCU) but this should be sufficient enough, hopefully.
(As I said with this setup i can read the MCU in atmel studio no problem. )
See the note on page 16 of the datasheet:
AVCC ... should be externally connected to VCC, even if the ADC is not used
http://www.atmel.com/images/atmel-8159-8-bit-avr-microcontroller-atmega8a_datasheet.pdf
I see, that might be it! What does it mean exactly? Should I connect a battery to avcc and gnd then? 5V battery? Sorry I am total newbie. And thanks!
I cant see pull-up resistor on reset pin
10k ohm - 47kohm between reset and vcc
Majid
Remove the wire from the reset pin and see if the LED turns on after adding the pull-up resistor as m.majid has written above.
EDIT: m.majid
It means you take a wire, and use it to connect the AVCC pin to the VCC pin
You do not need a resistor to Rest as long as you are not trying to program the AVR.  For programming you will need the resistor.  In this application as Larry and majid suggest I would put a 10k resistor to Vcc and remove the wire.
Question regarding the wire to the RESET line....is that wire going to your programmer by chance?
JIm
Ok I'll try that thanks.
JIm
The reset leads to my programmer indeed.
What do you mean by "programming"? I thought that creating and compiling the code above and uploading it on the chip IS programming. :-)
"Programming" is used both to describe the act of writing programs, and the process of loading the resulting executable into the target processor.
Similarly, "Programmer"  is used both to describe a person who writes programs, and the equipment for loading the resulting executable into the target processor.
in that context, "programming" is the process of loading the executable into the target processor
it didn't help
Time to post a complete program that can be compiled by others.
Too much back and forth with the small snippets of info......
Happy New Year!
So the diode finally flashed. But I don't understand it.
When I have a reset connected to the programmer, the program is apparently uploaded but not executed.
When I dont have the reset connected, the program is not updated (uploaded) but the present version on the MCU runs for a second (the diod lights) until I get error (got  0xc0 instead of 0x00) which I am getting every time I connect the programmer in a wrong way to the MCU.
When I connect VCC to ACC nothing changes in both cases.
When I connect VCC to reset via 1k resistor nothing changes when reset unpluged. And another error (Unexpected signature 0x003e9397 (expected 0x001e9307).) happens when I also connect reset to the programmer.
edit: with 10k resistor its the same as above
I assume this occurred when you disconnected the reset wire.
Because the reset wire is still connected, yes?
The programmer cannot program the chip with the reset line disconnected.
Connect it anyway as this is per the data sheet.
You have something wired incorrectly.
What programmer are you using to program the chip?  Please don't say yourself. ;)
EDIT: Please follow the instructions in post #27 and include a new picture of the breadboard circuit with all of our suggested connections in place.
That is too strong a pull up, the programmer can not pull the line down, change the resistor to 10k!
I'm beginning to wonder if the 10K resistor was really ever tested.
It was tested.
I am not sure what more to give you of the code.
This is all:
    DDRD = 0xff;
    PORTD = 0x01;
    while (1)
In atmel studio if you create GCC  C Executable Project and paste this to the main.c you will have exactly the same as I do.
Here is updated circuit:
Oh, and as I wrote above I use AVRProg USB v3 https://www.gme.cz/data/attachments/orn.752-447.1.pdf
I find it a bit odd, and confusing, that the ground wires are red and the VCC wires are green.  That is completely opposite what would be considered the norm.
Use red for VCC and black (or green if you must) for GND.  Don't believe it?  Plug these terms into a browser search and select images - avr atmega8 circuit breadboard​
If you disconnect the reset wire after programming the chip does the LED light up?
Does the LED light if the '+' is directly connected to VCC (leaving the '-' connected to GND through the resistor)?
(In other words, leaving the uC out of the mix... does the LED work?)
David
Both the Vcc and the AVcc pin must be connected to your +5 V power supply positive side.
Both of the grounds, (pins 8 and 22), need to be connected to the power supply's negative side, (ground).
You should put a 0.1 uF capacitor from the Vcc pin to Ground, and from the AVcc pin to Ground.
This is for reliable operation.
These are called By-pass capacitors.
Put the one end as close to the micro's Vcc and AVcc pins as possible, (nearest hole on the bread board).
Next:
You do not need to have a resistor on the Reset\ pin.
The micro has an internal pull up resistor that will work just fine for your bread boarding experiments.
IF you do use one, make it 10K ohms or higher, NOT 1K.
Next:
Consider disconnecting your programmer and cycling the power off and then on, to test your circuit.
Depending upon the hardware programmer, and the software running it, it is sometimes possible for the hardware programmer to hold the micro in its reset, (non-running) state.
Finally:
The color of the wires doesn't matter.
Not even a little bit.
BUT, some of us old timers would NEVER use a red wire for Ground, and a Green wire for Vcc.
Red wires are traditionally used for the V+ powering bus.
Black or Green wires are traditionally used for the Ground bus.
As I said, it doesn't matter at all.
But when troubleshooting a layout it is beneficial to follow "Standards" and tradition.
Do report back on how your project is coming along.
most strange thing just happened:
there is a switch on the programmer, which changes 3.3V to 5V. I switched it and nothing happened for a while... but... after a minute or so, the diode started shining.
So I updated the program as following:
#ifndef F_CPU
#define F_CPU 1000000UL
#endif // F_CPU
#include <util/delay.h>
#define set_bit(target, num)    (   target |=   _BV(num))
#define clear_bit(target, num)  (   target &=   ~ _BV(num))
#define toggle_bit(target, num) (   target ^=   _BV(num))
#define DELAY_IN_MS 500 /* 1 sec */
int main()
    set_bit(DDRD, PD0);
    set_bit(PORTD, PD0);
        toggle_bit(PORTD, PD0);
        _delay_ms(DELAY_IN_MS);
    return 0;
An started debug session and it works! the diode is blinking.
I guess I should've switched to 5V from the beginning, what I do not get is the delay after which it suddenly started working. Does anybody know?
larryvc: thank you for the color codes tip, I will adjust that.
And thank you all for your patience.
DocJC wrote:
BUT, some of us old timers...
Speak for yourself Doc ;)
thank you, your insights helped me, and I will try that capacitors once I buy them tomorrow.
I switched the cables, as you say standards are good to follow.
Particularly when asking other people to help with the troubleshooting
 Why is this making things more reliable? Do I do it only for breadboard projects or is it a common practice?
See Wiki Decoupling Capacitor for a better answer than I can provide.
They are required for reliable operation for any layout, bread board or PCB.
They are expected standard practice for digital logic circuits.
ok Ill check it, thanks :)
See also: https://www.avrfreaks.net/comment... (and preceding comments)
edit
preceding comments
The only reason you don't instantly burn the diode and the pin, is because AVR pins have aprox. 20-30 ohm of internal resistance. This may keep the current under the absolute max of 40mA even without a (external) resistor for certain LEDs if VCC = 3.3V, but at 5V it would surely burn something very quickly.
True for the LED connected to an MCU output pin.
But it seemed that the OP might be misinterpreting it as meaning that the LED could be connected direct to any 3.3V power supply with no resistor.
While it's possible that a 3.3V power supply might limit its current to a safe level, that is by no means guaranteed!
There are also youtubes showing LEDs connected directly to 3V coin cells. This, again, relies on the coin cell's (relatively) high internal resistance - it should not be attempted with any other type of battery!!
surprise
