Not triggering RX interrupt ISR
14 posts / 0 new
Hey all, I am trying to set up communication between 2 XMega (2 XMega256a3u's), I have the first MCU, call it MCU1, sending data through its UART, which I can measure on a scope to be at 9600bps, and the code I am running on my MCU2 should be interrupted whenever data is sent, but I am current getting dead air. I have also tried reversing it (MCU2 --> MCU1), and the same issues results. I tried using the simulator functionality of Atmel studio (rather than the emulation of my JTAG-ICE3), and I am setting the RXCIF flag (I think this should cause the ISR to trigger), but nothing happens still. The MCU's are connected from USARTC0 (MCU1) to USARTE0 (MCU2). I appreciate any help! I am hoping its a simple mistake.
Here is my code on MCU2:
#define F_CPU 32000000UL
#include <util/delay.h>
void FastRCClock(void)
    CCP = CCP_IOREG_gc;              // disable register security for oscillator update
    OSC.CTRL = OSC_RC32MEN_bm;       // enable 32MHz oscillator
    while(!(OSC.STATUS & OSC_RC32MRDY_bm)); // wait for oscillator to be ready
    CCP = CCP_IOREG_gc;              // disable register security for clock update
    CLK.CTRL = CLK_SCLKSEL_RC32M_gc; // switch to 32MHz clock
void setUpSerial()
    /* This PORT setting is only valid to USARTE0 if other USARTs is used a
     * different PORT and/or pins are used.
     PE3 (TXD0) as output. */
    PORTE.DIRSET   = PIN3_bm;
    /* PE2 (RXD0) as input. */
    PORTE.DIRCLR   = PIN2_bm;
    // Baud rate selection
    // BSEL = (32000000 / (2^0 * 16*9600) -1 = 207.333 -> BSCALE = 0
    // FBAUD = ( (32000000)/(2^0*16(207+1)) = 9615.384 -> it's alright
    USARTE0_BAUDCTRLB = 0; //Just to be sure that BSCALE is 0
    USARTE0_BAUDCTRLA = 0xCF; // 207, 9600 BAUD
    //Disable interrupts, just for safety
    USARTE0_CTRLA = 0;
    //8 data bits, no parity and 1 stop bit
    USARTE0_CTRLC = USART_CHSIZE_8BIT_gc;
    //Enable receive and transmit
    USARTE0_CTRLB = USART_TXEN_bm | USART_RXEN_bm;
    //Sets interrupt to low level priority in the PMIC
    USARTE0_CTRLA |= USART_RXCINTLVL_LO_gc;
void sendChar(char c)
    while( !(USARTE0_STATUS & USART_DREIF_bm) ); //Wait until DATA buffer is empty &'d the status register and USART DREIF bit mask together
    USARTE0_DATA = c;
ISR(USARTE0_RXC_vect)
    char temp = 0;
    PORTB.OUT =  0x1C;
    temp = USARTE0_DATA;
    sendChar(~temp);
    PORTB.DIRSET = 0x1C;
    //PORTB.OUT =  0x1C;
    FastRCClock();
    setUpSerial();
    PMIC.CTRL = PMIC_LOLVLEN_bm | PMIC_MEDLVLEN_bm | PMIC_HILVLEN_bm;//enable all interrupts
    PMIC.CTRL |= PMIC_LOLVLEX_bm; //Low level interrupt may be occurring don't stop it
    SREG |= 0x80; //sei(); equivalent
while (1)
    return 0;
Here is the code for MCU1:
void setUpSerial()
	/* This PORT setting is only valid to USARTC0 if other USARTs is used a
	PORTC.DIRSET   = PIN3_bm;
	PORTC.DIRCLR   = PIN2_bm;
	USARTC0_BAUDCTRLB = 0; //Just to be sure that BSCALE is 0
	USARTC0_BAUDCTRLA = 0xCF; // 207, 9600 BAUD
	USARTC0_CTRLA = 0;
	USARTC0_CTRLC = USART_CHSIZE_8BIT_gc;
	USARTC0_CTRLB = USART_TXEN_bm | USART_RXEN_bm; // And enable high speed mode
	while( !(USARTC0_STATUS & USART_DREIF_bm) ); //Wait until DATA buffer is empty &'d the status register and USART DREIF bit mask together
	USARTC0_DATA = c;
	PORTA.DIRSET = 0x38;
	PORTA.OUT =  0x38;
	FastRCClock();
	setUpSerial();
while (1)
	//PORTA.OUT = 0x00;
	//_delay_ms(1000);
	//PORTA.OUT = 0x38;
	//_delay_ms(1000);
	sendChar(0x20);
	_delay_ms(1000);
	sendChar(0xBB);
	_delay_ms(1000);
	//sendChar(0xCC);
	//sendChar(0xDD);
	//sendChar(0xFF);
	return 0;
No it doesn't.  Writing a one to RXCIF clears the flag.
How could a low level interrupt be occurring when global interrupts are disabled?
Edit:
    USARTE0_DATA = c;
    char temp = 0;
    PORTB.OUT =  0x1C;
    sendChar(~temp);
Having an ISR that calls a function that blocks while waiting until it can write to the USART.DATA register is not a good idea.  Echo the received char in the main loop, not the ISR.
Greg Muth
Portland, OR, US
Atmel Studio 7 (Version: 7.0.1652) on Windows 10
okay, thanks for the response.
That makes sense when writing a 1 clears the flag, but how is the interrupt triggered, i.e. what bit value is set to 1 or what occurs to make the ISR trigger?
I also understand why that line before the sei() does not make sense.
Yeah, I try to keep ISR's short, but the code itself is not doing much, so I didnt see the harm, but you're right.
The USART receiving a char triggers the interrupt (if the RXC interrupt and global interrupts are enabled).
Greg Muth
Portland, OR, US
Okay, that's what I understood. Is there a way to simulate this? Also, do you see any obvious errors in my code, besides the aforementioned (which I have corrected)?
And if interrupts for that level, High, Med, or low, are also enabled.
Right.  Because this is not the ATmega328P I was thinking about, it is an ATxmega256A3BU.
@MaxwellZ said:
Also, do you see any obvious errors in my code...
No.  But I am curious as to why you are inverting (~) the received char before echoing it:
    char temp = 0;
    PORTB.OUT =  0x1C;
    sendChar(~temp);
I prefer to use the _PROTECTED_WRITE() macro with CCP-protected registers:
    _PROTECTED_WRITE(OSC.CTRL, OSC_RC32MEN_bm);
    _PROTECTED_WRITE(CLK.CTRL, CLK_SCLKSEL_RC32M_gc); // switch to 32MHz clock
Edit: I see a hidden error in the FastRCClock() function.  The first line enables the RC32M and disables the RC2M, the current clock source.  If the Xmega clock hardware did not prevent you from disabling the current clock source, this would be a problem.
    _PROTECTED_WRITE(OSC.CTRL, OSC_RC32MEN_bm | OSC_RC2MEN_bm); // enable RC32M
    while(!(OSC.STATUS & OSC_RC32MRDY_bm)); // wait for RC32M ready
    _PROTECTED_WRITE(CLK.CTRL, CLK_SCLKSEL_RC32M_gc); // switch to RC32M
    _PROTECTED_WRITE(OSC.CTRL, OSC_RC32MEN_bm); // disable RC2M
Greg Muth
Portland, OR, US
Presumably so (s)he can tell it's actually the software doing the loop-back - and not just a hardware short-circuit?
Trouble with this is that it's liable to lead to unprintable character codes!
surprise
A better idea might be to just add one, or convert upper <--> lower case, etc ...
That's the one I generally do when testing such things and then, of course, typing "HAL" at it.
That's a good idea, and yeah I was sending the inverse because I wanted to make sure it was functioning properly. Would you happen to understand why my software is not functioning correctly?
Op said " trying to set up communication between 2 XMega "
Could this be a simple h/w error,  i.e.  tx -> tx / rx -> rx, instead of the correct way, tx -> rx both directions???
Nope, my hardware is correct :/
Okay, my original code actually works fine, I was just testing incorrectly. Sorry about that!
Thanks for feeding black - please mark the solution: https://www.avrfreaks.net/comment...
