Arduino Uno and TSS463B VAN Datalink Controller
4 posts / 0 new
I've been struggling with a TSS463B VAN Datalink Controller and I'm not able to decrypt its datasheet. I'm using SPI to interface the controller (basically following this: https://github.com/lazarov-g/vanreader ) but could not find a reliable way to detect when a new message arrives. I can see that there is a Last Message Status Register which holds the channel number that was successfully transmitted or received, but it's a read only register, so I can't set it after reading out the contents of the corresponding mailbox. Maybe there is another way, but I couldn't figure it out. And also cannot figure out how to send a message, if I understand it correctly, I need to set the corresponding channel registers as seen on page 37 and 44, or am I wrong? Any help is greatly appreciated.
Have you seen this?   http://www.atmel.com/images/doc4...
Don't know if that will help, as I have no experience with VANbus, only some CANbus.
edit: could not get copy/paste to work, but when posted, all of my pastes show up in the text, but not when it is in edit mode?????
http://www.atmel.com/images/doc4205.pdf
Keys to wealth:
Yes, it's almost the same as I've linked. I have figured it out that I need to play with the various message types which are described on page 44. I came to the conclusion that I need to set up channels for every message type, and even the order of the channels setup matters. For example I get more messages if I set up the channels like this:
Channel 0: reply request message
Channel 1: receive message
Channel 2: reply request message without transmission
Compared to this channel setup:
Channel 0: receive message
Channel 1: reply request message
I don't know why...
I also have a question:
Is it needed to wait after every byte of data sent?
The question is because of this sentence "the minimum inter-character delay is 12 µs (12 oscillator periods)" in the topic "Clocks and Speed ​​Considerations" for the SPI on the datasheet, illustrated by figure 7, but as English is not my primary language, I got myself confused.
Thank you in advance,
Best regards,
Lincoln
