Impedance controlled PCB advice
9 posts / 0 new
Hi All
I am developing a RF PCB and would like to know what is the difference between?:
  1. Asking the PCB manufacture for their standard PCB stack up along with their Substrate Dielectric and using the calculator to work out track thickness and spacing
OR
     2. Or giving them the PCB design and requesting a them to adjust their process to achieve the desired impedance
Thank You
DJ
Regards
DJ
Option 1 is the usual method. Option 2 has the problem that the pcb manufacturer doesn’t have infinite choices - he has constraints, so you end up back at option 1.
Well, any time you ask any supplier to do specific, custom work for you (ie, your option 2) - the difference is going to be a higher price!
Yes i have noticed price increase.
I have designed my board based on there stack up.
If option 2 was to selected then what exactly do they do? Would i be correct in saying that they simply change the stack up so that my tracks achieve the desired impedance? And as a pcb would deviate from there standard process that is the reason for a price increase?
Regards
DJ
As we on the topic of impedance, just would like to know on micro strip differential pair , the spacing between the two track are specified to 0.2mm but what should the spacing be between the tracks and GND pour on the same layer. Would it be 0.2mm like the spacing between tracks or 0.113mm like the spacing between the tracks and GND layer below it.
Regards
DJ
As slightly off question, but related to PCB design.
I have 0402 components, that are 0.5mm by 0.5mm in each each pad with 0.5mm spacing between them. And my impedance trace goes through such 0402 components.
If i was to choose to keep a trace thickness of say 0.2mm, then at point of the component the trace would be seen as 0.5mm due to component pad, what effect would that have on overall impedance.
Or should i simply keep my trace 0.5mm in width and 0.5mm in spacing , and request PCB manufacture adjust stack up to get the 50 ohms impedance?
Options 1, is sticking to there stack up.
Option 2, is changing there stack up but getting a full trace with same width all the way through.
Thank YOu
Thank You
Regards
DJ
Seems like it's the choice between putting your time and effort in it and desinging it yourself or putting your money in it to have it designed by somebody else.
A few years back I read a story about the design for a multi GHz radar PCB.
After a lot of design iterations they came to the conclusion that the only way to achieve the accuracy needed was to mill the edges of the pcb traces.
The sides of etched pcb traces were not straight & square enough and reflections caused too much signal distortion.
I usually buld my AVR prototypes on a breadboard with lacquered wire, throw in a few decoupling caps and be done with it :)
I've looked at some youtube vid's of spectrum analysers but those boards mostly look like voodoo to me.
Paul van der Hoeven.
http://www.hoevendesign.com
Paulvdh wrote:
... but those boards mostly look like voodoo to me.
Converse - the art of the masters ... that's even more impressive because these can be manufactured.
Happen to have draw a normal stack for 4-layer board,
Stack of 4-layer board
One of our customer need this stack so that he can design the board, he have requirement of impedance, to be honest, we produce the project by customer's design.
For the project have demand in impedance, we'll EQ them after place the order. Eh, this is the process.
Juvtmall produce normal PCB, FPC and HDI
D
