EEPROM corrupt or damge in BOD ?
9 posts / 0 new
hi
I know this is discussed several times before,
I have read most of very useful old threads, and did my project as below:
my circuit is 4.5V
BODLEVEL set to 2.7V
ATmega328P 20 MHz
I do not use address 0 of eeprom
save 2 bytes data every one hour,
my project requirement is 5 years = 43800 hours (for ATmega328P max 100000 write allowed = 11 years )
check data integrity at start-up and ignore corrupted data
my cicuits seems works fine but I did not find explicit explanation to something I am worry about :
what happens if power loose exacly at middle of write process ?
1. data loose , not write  , (no problem for my requirements)
2. data corruption, wrong data, ( I have already handled)
3. eeprom damage, is it possible, shall I care about it?
Majid
Most likely 1 & 2. Physical damage is unlikely.
m.majid wrote:
my circuit is 4.5V BODLEVEL set to 2.7V ATmega328P 20 MHz
What does the datasheet say about safe operating at 20MHz, in regards to VCC?
Is a BOD level of 2.7v the correct level?
How important is the correct and safe operation of your device?
Can it perform the work needed at a lower speed using CLKPR of /2 or /4 or /8?
How stable is the power source?  4.5v, battery perhaps, is it monitored?
FF = PI > S.E.T
Thanks for reply
Majid
Thanks for reply
Good questions!
Datasheet says min 4.5v for 20Mhz is ok
3 BODLEVELs available:
1.8 (1.7-2.0) risk for eeprom
2.7 (2.5-2.9) my choice
4.3 (4.1-4.5) can not use for 4.5v vcc
Project requirements forces 20Mhz
What do u mean by "monitored"?
it is Step-down regulator, 2A load,
Stable voltage during load fast change between 0.1A and 2A
MCU power is branched from supply through 10 ohm reistor and has a bypass cap 100nf
it works fine except 1 incident of eeprom adress 0 damage, I dont use address 0 anymore
I hope I didn't miss anything
Majid
Project requirements forces 20Mhz What do u mean by "monitored"?
MCU power is branched from supply through 10 ohm reistor and has a bypass cap 100nf it works fine except 1 incident of eeprom adress 0 damage, I dont use address 0 anymore I hope I didn't miss anything
Ok, the vcc of 4.5v is common for battery powered projects, 3s AAA batteries, so I was asking if you monitored the battery voltage....  NA for this power source.
Why 4.5v and not 5.0v?  are you losing 0.5v thru the 10 ohm resistor (that would be a 1/2 amp mpu load, not likely...)
I would add a 10 - 100uf after the 10 ohm resistor, an use 100nf caps close to both vcc/gnd and avcc/gnd pin pairs.
I guess this is drifting off topic, as you asked in OP about possible EEPROM damage, which is no, but you could have data corruption, but that is already handled, you said.
Post a picture of your pcb, we may see something and can add some additional hints.
FF = PI > S.E.T
Jim thanks for guides .
main load requirement is 4.5V 2A, SD regulator is fixed to 4.5V
I used 10 ohm to decouple MCU from main load, precaution to reduce likely ripples, MCU is about 10 mA
is 1u-10u ok for MCU? doesn't it affect BOD operation ? cause it will smooth the voltage fall ramp
I put one 100n exactly as u mentioned close to VCC, but not to AVCC,
datasheet says :
"1.1.7 AVCC: AVCC is the supply voltage pin for the A/D converter, PC3:0, and ADC7:6. It should be externally connected to VCC, even if
the ADC is not used. If the ADC is used, it should be connected to VCC through a low-pass filter. Note that PC6..4 use digital
supply voltage, VCC."
I interpreted AVCC always must be connect to VCC , but 100n is needed only if ADC is used, I dont use ADC
Majid
m.majid wrote:
I used 10 ohm to decouple MCU from main load, ...
Instead, the recommendation's a ferrite bead.
Atmel AVR042: AVR Hardware Design Considerations [APPLICATION NOTE]
http://ww1.microchip.com/downloads/en/appnotes/atmel-2521-avr-hardware-design-considerations_applicationnote_avr042.pdf
(page 5)
Figure 2-2. Decoupling with Series Inductor
very useful appnote , thanks
new name AN2519 Rev 08/2017:
http://ww1.microchip.com/downloads/en/AppNotes/00002519A.pdf
choosing true ferrite bead is quite complicated!
Majid
