IO space vs Memory space writes
9 posts / 0 new
Hi all. Very new to AVR, but very not-new to programming.
Quick question:
Is using store-direct ("sts") to write IO ports considered hackish?
I see that the .def of PORTB is a relative offset in IO land (it's missing the 0x20 offset into memory space).
If I'm mixing memory mapped IO writes (above 0x3f) with standard-IO writes, it starts to feel like address space juggling. Yeah(?)
Thanks-
(btw, I see that "out" is a smaller instruction, and will be smaller/faster)
Are you going to use assembler for programming? If not why worry, the compiler will do what needs to be done.
Assembler. I'm curious (not worried) about the exact things that a compiler abstracts.
So are you familiar with other similar microcontrollers, or is the "very not-new to programming" in entirely other domain(s) ?
I'd say familiar with other similar. I have production code on the ARM cortex m4 (ARMv7E-M Harvard architecture).
Everything else is in 'other domains'. I'm a rendering engineer on gaming consoles.
If you are using assembler then the thing to do is to download AVR001: Conditional Assembly and portability macros, it will select between In/Lds and Out/Sts depending on the appropriate register address.
Behold! Address juggling macros!
Much appreciated.
Have they been ported to the gnu assembler?  (huh.  001, eh?  That has to be pretty ancient!)
Link to macros.inc from atmel
http://www.atmel.com/Images/avr001.zip
