OCR1A (mega168) showing negative signed (int) value in AS7
3 posts / 0 new
Doing some += calcs to update 16bit output compare register for an atmeg168 and atmel studio is showing negative values when the OCR register overflows to a positive number only...
However in hexcode display converted shows anticipated correct unsigned values.
Clicking around to try to get it to show the correct unsigned 16 bit value.
*edit: As a work around, for testing i created an unsigned int to store OCR1A value to view. And i moved down to AS6 because it seems a bit peppier and my project is simple.
~William
What else would you use? Unless you are doing maths of some description always use unsigned, uint16_t in this case.
Use the IO view, not watches for SFRs.
