Problems with watchdog on ATTiny2313
5 posts / 0 new
I tried to use the watchdog as system reset on my tiny2313.
It works fine the first time, but after the reset the tiny resets all over again. A hardware reset at this point also has no use.
I have te disconnect the power to user the tiny again.
What am i doing wrong?
Here is the code I use:
void main(void)
  DDRB = 0xFF;      //portb = output
  DDRD = 0x00;      //portd = input
  PORTB = 0;
  MCUSR = 0;
  __delay_cycles(10000);
  PORTB = 0xFF;
  WDTCR   =   (1<<WDIF)|(0<<WDIE)|(1<<WDCE)|(1<<WDE )|(1<<WDP3 )|(0<<WDP2 )|(0<<WDP1)|(0<<WDP0);
  _SEI();
    __watchdog_reset();
    for(;;);  //wait for wd to reset
What compiler are you using?
Which delay time (ms) does this code produce?
ATTiny2313 has no register named WDCR but a WDTCSR register.
The Watchdog will be cleared only once since after the line
__watchdog_reset();
the program will hang in the endless loop
for(;;);
So the watchdog must reset the AVR.
Regards
Sebastian
[/code]
I'm using IAR Workbench __delay_cycles(10000) will delay 10 ms when i use an 1MZh crystal.
I looked in the iotiny2312 file and the register is WDTCR.
If i use WDTCSR, i get a compile error.
__watchdog_reset();
for(;;);
The program works for the first time. When it reaches for(;;), the Tiny reboots after 4sec watchdog time.
But after the reboot, the leds at PORTB are blinking very fast, so i think the uC reboots all the time. Even if i do a hardware reset (pulling RST low), PORTB keeps blinking.
Only after i disconnect the power and reconnect, it starts normal and resets after 4sec watchdog time. After this, it starts all over again.
See my respective comments on top of the avr-libc watchdog header
file:
http://www.nongnu.org/avr-libc/user-manual/group__avr__watchdog.html
The actual syntax will be very different for IAR, but the problem is the
same. It's well described in the datasheet (though basically not really
expected at a first glance).
Jörg Wunsch
Thanks Jörg I wasn't aware, that WDT is enabled after reset (and spend some time reading datasheet, but I didn't find this particular information). Google rulez :).
