ADC interrupt not working on ATtiny85
7 posts / 0 new
I wrote this:
.equ SDA = (1 << PB4)
.equ SCK = (1 << PB2)
.equ ADCIN = (1 << PB3)
.equ TIMER0_COMPB_vect = 11
.equ ADC_vect = 8
.equ START = 15
.org 0x000000
	rjmp START
.org ADC_vect
	rjmp adcdone
.org START
	ldi r16, (SCK | SDA)
	out DDRB, r16
	out PORTB, r18
	;pwm setup
	ldi r16, (2<<COM0A0 | 2<<COM0B0 | 3<<WGM00)
	out TCCR0A, r16
	ldi r16, (0<<WGM02 | 1<<CS00)
	out TCCR0B, r16
	ldi r16, (0<<PWM1A | 0<<COM1A0 | 1<<CS10)
	out TCCR1, r16
	ldi r16, (1<<PWM1B | 2<<COM1B0)
	out GTCCR, r16
	ldi r16, 15
	out OCR1B, r16
	;pwm setup end
	;adc setup
	ldi r16, ((1 << ADLAR) | (1 << MUX0) | (1 << MUX1))
	sts ADMUX, r16
	ldi r16, ((1 << ADEN) | (1 << ADPS1) | (1 << ADPS2) | (1 << ADIE) | (1 << ADSC))
	sts ADCSRA, r16
	;adc setup end
	sei
	ldi r16, SDA
	ldi r17, SCK
	ldi r24, 0xFF
	ldi r25, 0xFF
	ldi r26, 0x02
	rcall delay
	ldi r25, 0x00
	ldi r26, 0x00
loop:
	;rcall shiftout
	rjmp loop
delay:
	sts 0x0200, r24
	sts 0x0201, r25
	sts 0x0202, r26
	sts 0x0203, r27
delay1:
	sbiw r25:r24, 1
	brcc delay1
	lds r24, 0x0200
	lds r25, 0x0201
	sbiw r27:r26, 1
	brcc delay1
	lds r26, 0x0202
	lds r27, 0x0203
	ret
adcdone:
	lds r20, ADCH
	out OCR1B, r20
	lds r20, ADCSRA
	ori r20, (1 << ADSC)
	sts ADCSRA, r20
	reti
The pwm is working perfectly, but the ADC_vect interrupt isn't being called, anybody knows how to fix this?
Why are you redefining everything in the device header?
I'm not, ADC_vect isn't defined by default
Yes it is. Atmel do not call it "ADC_vect".
See the inc.def file.
This in fact...
Okay, i'm now using ADCCaddr, but it still doesn't work
Nevermind, got it to work by changing STS to OUT and LDS to IN, i don't know why i used these
