Does frequent reading slows down DS3231 RTC???
46 posts / 0 new
Hi freaks
Recently i was building a precise timeclock with mega328 and GLCD and DS3231.I was using a Casio G-shock(Pretty accurate I think) as my reference.I found that my DS3231 clock was about 17sec slow as compared to my reference Casio after a 12hr runtime.At the whole time,DS3231 as well as the whole circuit was powered by external 5v(not by internal battery of DS3231).I was reading the DS3231 every second and was updating the reading to the GLCD.Then i thought to sync after every 5 mins.This time i ran the clock for nearly 24hr and found a delay of nearly 2s with my reference clock.
Now I upgraded the hardware(pulled up the sqw line and changed the cpu to mega32 for higher pincount) and set the DS3231 to give a square wave output of 1hz.Now the Idea is to sync every second for update without reading the RTC using level change interrupt.I have planned to read the RTC only two times a day(every am to pm conversion or vice-versa).
Is it normal for the DS3231 to get slow if reading it frequently??I have read the datasheet but found no such illustration.Someone faced this sort of things??Previously I have used DS1307,but in that case also,it was getting damn slow.So i thought t ask the experts......and here I am.
Are you sure you have a 'real' ds3231? The cheap ones are Chinese copies which might explain the problem. As such, reading the chip should not slow it down.
Is the OSF bit set in the Status register ?
Are you writing anything into the Crystal Aging Offset register ?
No...I simply uploaded the Time related datas once and was reading it back every 1sec.I didn't write anything else anywhere.
I am not pretty sure if it is a chinese crap........
Just look at the price of a genuine DS3231 chip from a Maxim Distributor like Digikey, Farnell, ...
Then look at price of the Ebay modules from China including delivery.
I bought a Chinese module to see how it performs.    It works but is NOT accurate.
Likewise,   a lot of the DS1307 modules from Ebay are not as accurate as you would expect.   i.e. have crap crystals.
I am in India and here Digikey/Farnell/Mouser doesn't sell to individuals/hobbyists.Although i have found an online store who imports from Adafruit & Sparkfun and sell breakout boards(The price is costly though).Please take a look at two breaouts regarding DS1307 & DS3231(Chronodot).
https://www.mgsuperlabs.co.in/estore/Real-Time-Clock-Module?search=RTC
https://www.mgsuperlabs.co.in/estore/ChronoDot-Ultra-Precise-Real-Time-Clock?search=Chronodot
Are they any worthy to give a try???Please reply..............
They might not sell to you. But you can still visit a US or European Distributor's website and see the dollar price.
Ok...but I asked if those modules from sparkfun/adafruit are any good ore not????
Everything seems incredibly expensive in India.   $48 for the Sparkfun DS3231 module.
I have only tried the cheap Ebay DS3231 modules.  e.g. http://www.ebay.co.uk/itm/PCS-DS3231-AT24C32-IIC-precision-Real-time-clock-module-memory-module-Arduino-/172183832510?hash=item2816f4c7be:g:RV4AAOSw-tNXIX1x
As you can see,  it is about $1.50 delivered to my door all the way from China.
In the US,  Digikey has http://www.digikey.com/product-detail/en/maxim-integrated/DS3231MZ-V-/DS3231MZ-V--ND/3133910
which is $6.50 for one chip.   And many more dollars for Tax and Delivery.
Sparkun products are generally very good.   I would assume that they use genuine Maxim chips.   I would assume that it is 100% accurate,  but only an owner can confirm this.
I can NOT believe that the $1.50 Ebay module has genuine chips.    My Ebay module is not very accurate.
Thanks for the reply......
detecting the 1hz square wave using interrupt method is doing fine still now(still no drift wrt my Casio for nearly 24hr).I will put the clock in a long run and tell you whats happening further.But surely,reading the I2C frequently was making the counterfeit DS3231(as i assume from it's behaviour) slow.But i will order some real DS3231 breakout board or some bare chip (As i found a company who redistributes Mouser products in India) and also put them to test.
Another thing i would like you to ask that are you reading the DS3231 frequently or using some Interrupt driven method(like mine)??????
Reading I2C will not affect the timekeeping in any way.
Personally, I use the 1Hz output to tell the Arduino that the RTC has changed. I read the whole set of RTC registers. And display them on LCD or Serial.
There are many different RTC chips from every i.c. maker that use a 32kHz crystal.
Genuine RTC chips from ST, TI, Microchip, ... are pretty cheap, even from Distributors.
Their accuracy depends on the crystal. Genuine crystals are pretty cheap too.
Even so, Chinese Ebay vendors are so cheap that I suspect that some or all of the components are QC rejects. Or even blatant counterfeit. They work ok for hobbyist purposes but I would not want to use them in a commercial product.
I am fascinated how Farnell or Digikey work in India.
In the UK, I or any humble punter can buy anything from the big Distributors. They are quite happy to take my money and add a handling charge for small orders. I pay VAT in the usual way.
Obviously Farnell would prefer me to spend $1000s. They treat a small customer just as well as a large customer.
l suspect that if I spent $100000, they might offer me special terms.
I can understand that India will want to encourage / protect its home industries. E.g. you pay import duties or higher rate of VAT for imported goods. That is fine. You just weigh up the costs for imported or domestic electronic products. Choose what suits you. Pay for it.
Unlike other counties that have US restrictions, surely India is free to import what it likes. Your government just applies taxes.
Hi Sharan. Same from my side. Upto 30min of delay every 24h. I am reading every sec via serial com. I would say that this method of readings too often induced a delay.
/jp
Rubbish. The RTC depends on the accuracy of the crystal.
The chip should oscillate reliably with a good crystal.
Cheap modules from Ebay probably contain reject crystals and reject chips
Replace the crystal if it is external e.g. DS1307. Replace the whole chip if it has integrated crystal e.g. DS3231.
Even a QC reject chip will work in most respects e.g. timekeeping ok but power is out of spec.
For the benefit of other readers, could you post a link to this distributor, or how to contact them.
We get a lot of India(n) visitors here and they may find that helpful!
Why not go direct to https://www.mouser.in ?
I configured the DS3231 to give a square wave output of 1hz.Upon each pin change(configure the interrupt either on falling or on rising),avr will count 1s.Also I configured the avr in such a way so that it will only read the ds3231 in 12hr interval.Now using this method,my clock is running successfully over a year without almost no significant delay like i described before!!Still I am using the counterfeit chinese replica of the ds3231.....
Please post a program that gives the "wrong" time.
Please post the program that gives the "correct" time.
Make sure that you provide something that is buildable e.g. ZIP up an AS7 project or Arduino sketch.
It is easier to attach a ZIP than to paste long files into separate CODE windows.
I possess an Ebay DS3231 module.    I can probably replicate your AVR hardware.
BTW the 22pF caps don’t ‘decouple’ the clock signal - they are load capacitors for the crystal oscillator.
Interesting.
In theory, reading a RTC should not affect the counter, but anything is possible....
eg If you say it was running faster, then maybe extra clock edges are being injected from the bus crosstalk.
Read should capture counters, but capture is not simple on ripple counters, as you need to be sure you do not capture while values overflow.
If you have access to a 1pps GPS system, you should be able to connect GSP-1pps and RTC 1pps, and report those two, and then vary a reading rate to see how that affects the two 1-second timings.
Capture of a time stamp would allow you to watch the exact phase of those 1pps, if the RTC does disturb, maybe it drops one or more 32khz edges to run slower as you report ?
Well, you're just repeating the claim there without giving any evidence.
Rather than just spreading unsubstantiated rumours on the interwebs, please do as as David requested in #18:
EDIT
typo
It is true that rapidly reading an RTC should not cause timing errors.  Should not.  They should also latch all the time registers simultaneously at the very start of the read operation, so overflowing counters should be a non-problem.  While reading, the counters themselves continue to run, while the output data is held stable to read.
I'd like to add to 'Who-Me' in #21 who mentioned using a GPS time reference.  A Casio G-Shock is a perfectly good watch, but the atomic clocks of GPS are better.
Note that your cellphone probably uses GPS timekeeping, and if the phone doesn't, the phone network certainly does.  You won't be able to get sub-second precision, but averaged over a few hours should give useful results.
My other major suspicion would be a lousy 32kHz crystal.  If the chip has one built-in, like the DS3231, then it's a bum chip.  Note that even the best from the best vendors can still show up broken.  It's rare, but it happens.  They'll replace them if you can prove it.
S.
In his instructable, SHARANYADAS states that it is due to
SHARANYADAS wrote:
cheap chinese modules. These suckers stops the counting while you access the registers of the chip in order to read.
and
SHARANYADAS wrote:
because of cheap chinese crap chips
And states that this information came from AVRFreaks!
surprise
What's the old proverb? 'a watched kettle never boils'. Thus the solution is to stop reading the time from the device and it will work properly.
Schrodinger's RTC ?
If you read it too fast, it might cause time dilation and a vortex to another dimension appears...... or i’ve been watching too much Regular Show.
I built the code as an AS7 project and ran it on a DS1307 because I could not find my DS3231 module.
The AVR counts the 1Hz SQW output from the DS1307.   And only reads the RTC at midnight.
Life is much simpler if people post projects as a ZIP.   It was painful to copy-paste each individual file from the Instructables site.
Update.   I have just found my DS3231.
I will try continuous I2C reads to see if it makes any difference.
I had forgotten just how ugly KS0104 displays are.
I'll agree for e.g. calibration purposes.  But OP is getting gross errors that could be measured with a sundial.
That will indeed be interesting.
Some years ago we were doing an app with a DS1305.  Strange RTC readings -- very very slow.  It turned out that the watch crystal wasn't crystalizing, and the chip would clock itself off the SPI "SCK".  (I can't see how that could happen with the symptoms here...)
sub-second checking would be possible with some timer-capture code in a small MCU - that would report the skew between GPS edges and RTC edges, and show the quanta of the errors.
( eg A missed Xtal edge, would change RTC dT by +30.517us )
Cool. Look forward to some independent tests.
I had a similar experience with one of my boards and the DS3231, the clock was running fast from memory.
After many hours of debugging, changing chips etc, I discovered some pulses, maybe 1V, ABOVE the 5V VCC, The pulses seems to change with the varying load.
I had omitted a large capacitor required on the 5V regulator I had never used before and it would overcompensate for the current varying requirement, once the PCB surgery was performed and added the cap all worked perfectly.
Ok,  I wrote a small sketch to run an an Arduino SMD clone.   Connect SQW pin to INT0 (digital #2).
I compared two Ebay DS1307 modules with my Ebay DS3231 module:
Compare DS3231 timing.   LED should toggle in ISR()
Thu 14 Dec 2017 01:39:11 PM
call I2C continuously for 300 secs
Elapsed time : 299985 ms,  288866 calls to read DS3231
Thu 14 Dec 2017 01:44:13 PM
do nothing for 300 secs
Elapsed time : 300002 ms
Thu 14 Dec 2017 01:49:15 PM.
Thu 14 Dec 2017 02:16:31 PM
call I2C continuously for 100 secs
Elapsed time : 99994 ms,  96287 calls to read DS3231
Thu 14 Dec 2017 02:18:13 PM
do nothing for 100 secs
Elapsed time : 100000 ms
Thu 14 Dec 2017 02:19:55 PM
Compare DS1307 timing.   LED should toggle in ISR()
Thu 14 Dec 2017 02:27:33 PM
Elapsed time : 99944 ms,  96265 calls to read DS1307
Thu 14 Dec 2017 02:29:15 PM
Thu 14 Dec 2017 02:30:57 PM
Thu 14 Dec 2017 02:31:22 PM
Elapsed time : 99962 ms,  96282 calls to read DS1307
Thu 14 Dec 2017 02:33:04 PM
Thu 14 Dec 2017 02:34:46 PM
You can see that the Arduino reports different times for each module.   The Arduino clone has an accurate 16mHz HF crystal.    Official UNOs have crap ceramic resonators.
In theory it should take 900us to read the RTC on a 100kHz bus.   The Arduino only manages 1038us with the Wire library.    The important point is that I have done 24 hours worth of RTC traffic with no noticeable difference.
The SQW loop has a granularity of 1.04ms i.e. the read_DS3231() time.
The millis() has a granularity of 1-2ms.
So any difference of 5ms in 100000ms is acceptable.   The 300 second run shows a bigger difference i.e. 15ms
DS3231_busy.ino
#include <Wire.h>
const byte DS1307 = 0x68;
const byte DS3231 = 0x68;
const byte ledPin = 13;
const byte interruptPin = 2;
const int MAXSQW = 100;
volatile int16_t SQW_count;
volatile bool edge;
uint8_t hour, min, sec, wkday, day, mon, year;
char printbuf[80];
#define PRINTF(fmt ...)  { sprintf(printbuf, fmt); Serial.print(printbuf); }
// it is easy to use PCINTx instead of the Arduino's INT0
void init_pinchange(void)
    PORTC |= (1 << 3);       //pullup on PC3 (prevents floating)
    PCMSK1 = (1 << 3);       //monitor   PC3
    PCICR = (1 << PCIE1);    //enable IRQ
ISR(PCINT1_vect)                   //regular pin change on PC3
    if (PINC & (1 << PC3)) return; //ignore rising edge
    PORTB ^= (1 << 5);       //toggle LED
    SQW_count++;
    edge = true;
void sqw(void)                   //Arduino INT0 interrupt service call
    static uint8_t state;
    state = !state;
    digitalWrite(ledPin, state);
    SQW_count++;
    edge = true;
uint8_t write_reg_block(uint8_t slave, uint8_t reg, uint8_t *block, int8_t n)
    Wire.beginTransmission(slave);
    Wire.write(reg);
    Wire.write(block, n);
    return Wire.endTransmission();
uint8_t write_reg_val(uint8_t slave, uint8_t reg, uint8_t val)
    return write_reg_block(slave, reg, &val, 1);
void read_DS3231(uint8_t slave)
    Wire.write(0);
    Wire.requestFrom(slave, 7);  // request 7 bytes from slave device #2
    sec = Wire.read();
    min = Wire.read();
    hour = Wire.read();
    wkday = Wire.read();
    day = Wire.read();
    mon = Wire.read();
    year = Wire.read();
void show_time(void)
    char *daynm[] = {
        "Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat", "Sun"
    char *month[] = {
        "bum", "Jan", "Feb", "Mar", "Apr", "May", "Jun",
        "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
    read_DS3231(DS3231);
    uint8_t pmam = (hour & 0x60);   //weird 12 hour for Americans
    uint8_t hour12 = hour & ((pmam & 0x40) ? 0x1F : 0x3F);
    char *mode = (pmam & 0x40) ? (pmam & 0x20) ? "PM" : "AM" : "";
#if 1
    uint8_t idx = (mon >> 4) * 10 + (mon & 15);
    PRINTF("%s %02x %s 20%02x %02x:%02x:%02x %s\n",
           daynm[wkday - 1], day, month[idx], year, hour12, min, sec, mode);
#else
    PRINTF("%02x/%02x/20%02x %02x:%02x:%02x %s\n",
           day, mon, year, hour12, min, sec, mode);
#endif
void setup()
    //                       sec   min    hr wkday   day   mon  year
    uint8_t init_regs[] = { 0xD0, 0x47, 0x49, 0x05, 0x14, 0x12, 0x17, };
    int32_t read_count = 0;
    int32_t t;
    uint8_t status;
    Wire.begin();
    //    write_reg_block(DS3231, 0, init_regs, sizeof(init_regs));
    write_reg_val(DS1307, 0x07, 0x10);   //enable 1Hz SQW on DS1307
    status = write_reg_val(DS3231, 0x0E, 0x40);   //enable 1Hz SQW
    Serial.begin(9600);
    PRINTF("Compare DS3231 timing.   LED should toggle in ISR()\n");
    if (status != 0) {
        PRINTF("Failed to enable SQW:%d\n", status);
        while (1);
    delay(1000);             //allow Serial to drain
    show_time();
    pinMode(ledPin, OUTPUT);       //LED
    pinMode(interruptPin, INPUT_PULLUP);
    attachInterrupt(digitalPinToInterrupt(interruptPin), sqw, FALLING);
    PRINTF("call I2C continuously for %d secs\n", MAXSQW);
    for (edge = false; edge == false; ) ; //wait till next SQW
    t = millis();
    for (SQW_count = 0; SQW_count < MAXSQW; read_count++) {
        //        if (PINC & (1<<PC3)) PORTB |= (1<<5); else PORTB &= ~(1<<5);
        read_DS3231(DS3231);     //continuous reads
    t = millis() - t;  //elapsed time
    PRINTF("Elapsed time : %ld ms,  %ld calls to read DS3231\n", t, read_count);
    show_time();
    PRINTF("do nothing for %d secs\n", MAXSQW);
    t = millis();
    for (SQW_count = 0; SQW_count < MAXSQW; ) {
        //nuffink
    PRINTF("Elapsed time : %ld ms\n", t);
    show_time();
void loop()
I thought hard about whether an example should be written for Arduino or bare AVR.
I concluded that everyone has an Arduino.    It should build out of the box.
If I posted an AS7 project with separate UART, I2C, timing functions for any AVR,   punters would be unlikely to try it for themselves.
p.s. Civilised people can change the 12/24 format bit in the hour register (reg=2).
Edit.   Changed read_count from int to int32_t.   This makes sense now
Edit.   Updated reads for DS1307 comparisons.   Changed my conclusion.
[LOL -- for the purposes of below, 120 seconds instead of 100 would have made my mental math easier.]
So what is the conclusion?  Doing mental math on the 100 second interval timestamps gives more than +/- 1 second readings, doesn't it?  And in the same direction for both types of devices.  But it seems to "catch up" so that the 200 seconds for both tests is OK?
Hmm--could it be that the timekeeping of the module is OK, but some update is being delayed?
The important point is that I have done 8 hours worth of RTC traffic with no noticeable difference
So any difference of 5ms in 100000ms is acceptable.   It would represent 15ms in a 24 hour period.
So nothing like the alleged
If you find the maths easier for 120 SQW pulses,   you only have to edit one line.
My conclusion was that the DS3231 does have a noticeable difference.    In a 24 hour period normal RTC programs would read the I2C every second.  i.e. 86400 reads in 24 hours.    My 96k reads seem to actually go faster by 5-6ms.
Either the RTC Silicon adjusts its internal compensation for the massive I2C activity.
Or the Arduino is somehow missing a few milliseconds.
I can't see where any RTC can lose 30 minutes in a day.
The Arduino clone has a good HF crystal.   It will have good short term stability.
The Arduino libraries handle Serial and Wire with interrupts.   The Timing is done with interrupts.    The AVR hardware Timers are 100% reliable.
I suggest that punters try the Arduino sketch for themselves.    I suspect that many people have DS1307.   And several have DS3231.
The real mystery is:   Why would anyone understand or want 12 hour format?
Good to see some numbers, but I did not see the reports for almost-no-readings ?
The 15ms in 300s is 50ppm, which is not great as drift, but with no A/B comparison, it may include absolute crystal ppm differences.
ie I'd expect a crystal to hold sub 10ppm in a short-term stable room, but out of the box, cheapest crystals sold are 50ppm, tho most give ±30ppm or ±20ppm, that does assume someone took the trouble to 'centre the caps' to remove circuit errors (few bother)
Yes, 30 minutes a day is very large, and seems due to 'some other effect', it may be cross talk, or voltage/power etc - that's why I suggest to the OP they connect a GPS 1 pps, and report/log the RTC-GPS time difference.
If they read in bursts then pause, such a log should show any difference effects due to the reading.
Just how much/how evenly the error jumps, should give good clues to just what is causing it.
What? Lee doesn't have one.....
The Arduino Xtal will also be temperature-sensitive.  Hammering the communication hardware will heat up the chip a bit more than doing nothing.  Real-Time Clock Chips are supposed to have compensation for temperature.  I don't think the Arduino does.  The difference will be small, but as Who-Me noted, we're talking tens of ppm here.  Not half an hour a day.  Something else is wrong with the OPs RTC.
Beats me!   And I don't have an Arduino either!  S.
and/or elsewhere in the OP's system ...
EDIT
typo
Does that include Henry Blake?
Fox Home Entertainment presents
M*A*S*H: Season Two (Collector's Edition) (1973)
"But general, you promised us help by noon! Well, what time is it now? 1300 hours? Well, uh... now, that's um... after noon, isn't it, sir? I mean, isn't it 12 up until it gets to be noon, and then you start all that hundred hour stuff? ...I wish the army would tell time like everybody else!"
- Lieutenant Colonel Henry Blake (McLean Stevenson)
http://www.digitallyobsessed.com...
and the favourite of Ernie Wise in the plays what he wrote; eg,
Our story take place in 1748 (which is nearly ten to six) ...
No,   I can't see why any interrupts would ever get missed in the regular Arduino platform.
But when I was walking my dog,  I thought that I would produce a non-interrupt version for AS7.
############# AS7 100kHz #####################################
Thu 14 Dec 2017 09:07:01 PM
Elapsed time : 99994 ms,  104994 calls to read DS3231
Thu 14 Dec 2017 09:08:43 PM
Elapsed time : 100001 ms
Thu 14 Dec 2017 09:10:25 PM
############# AS7 400kHz #####################################
Thu 14 Dec 2017 09:22:43 PM
Elapsed time : 99973 ms,  394010 calls to read DS3231
Thu 14 Dec 2017 09:24:25 PM
Thu 14 Dec 2017 09:26:07 PM
I get a similar result.   Ok, the millis() work much the same as Arduino.  i.e. I don't sync them.   So there is still a 1-2ms granularity.
But I still get 6-7ms difference with DS3231.    The DS1307 gave identical times.
I get 28ms difference when I run the I2C bus at 400kHz achieving almost 4x activity.
The DS1307 will only go at 100kHz.   So there is no point in trying at 400kHz.
Yes,   I suppose that the CMOS in the DS3231 will heat up with the extra activity.   Which will warm up the integrated crystal.
The DS1307 silicon will equally warm up.   But the external crystal will not.   Likewise,  the UNO crystal is external.
If my heating theory is correct,   I should get different results if I do nothing before doing continuous.
This problem is well known. In order to somehow solve it and test the modules, as well as calibrate them, I developed a small free tool:
CLI- and GUI-client for adjust the exact time and calibrating the RTC DS3231 module
The application allows you to:
  • Synchronize the time of the RTC DS3231 with your computer time;
  • Correct the time drift of the DS3231-RTC clock. The algorithm performs correction in the range from -12.8 to +12.7 ppm;
  • The application allows you to evaluate the accuracy and reliability of the RTC oscillator for a particular sample, as well as the chances of successful correction in case of significant time drift;
  • Automatically save parameters and calibration data to the energy-independent flash memory of the type AT24C256. In case there is a power failure to the module.
The project and the binary data is on my Github homepage SynchroTime
Greetings,
Sergej
P.S. new update to version 1.1.0 CLI- and GUI-client for adjust the exact time and calibrating the RTC DS3231 module SynchroTime_Win32_1.1.0-beta.7z
Great but this thread was started 4 years ago. And don't you have another Sergej account from where you posted the same thing?
I don't have another account here
