no jtag devices found, fixed
16 posts / 0 new
"No JTAG devices found" is the message I got the last several times I tried to debug with an Atmel ICE through AS7 on Windows 10.
I've not made any hardware changes since the last time it worked.
I reseated all the cables.  I used to do tech support, I know the drill.
Also, the device manager claims it's working properly.
The device manager also says that VID/PID 03EB:2141 need further installation.
From a long edge in, three LEDs are steady green, steady orange and off.
When I try to use it, the third LED blinks and eventually goes out.
AS7 shows the right serial number for the device,
but when I try to read the target signature, it claims "No JTAG devices found."
On the other hand, it claims to be able to read the target device voltage just fine.
How do I get it working again?
International Theophysical Year seems to have been forgotten..
Anyone remember the song Jukebox Band?
skeeve wrote:
... through AS7 ...
Pre or post 7.0.1416?
Reason: 7.0.1416 replaced Jungo with WinUSB
Atmel Studio
Driver and USB Issues
http://www.microchip.com/webdoc/GUID-ECD8A826-B1DA-44FC-BE0B-5A53418A47BD/index.html?GUID-033A42FD-C88B-4874-AC33-7807B5F9C91F
skeeve wrote:
... on Windows 10.
A common Windows 10 issue is a driver update will make devices non-functional.
Driver updates can be disabled in Windows 10 though that procedure has several steps.
gchapman wrote:
skeeve wrote:
... through AS7 ...
Post: 7.0.1417
Atmel Studio
skeeve wrote:
... on Windows 10.
No kidding.
First I have to figure how to figure out how to roll back the current one.
No joy.
The latest update of *anything* I can find is 11/16 10/16 .
The problem is more recent than that.
I'm reluctant to try the uninstall/reinstall method,
because I'm not at all certain I'll be able to do the second part.
It seems to me, that the icon would go away and I
would not know where to search to install it again.
When I click on repair, W10 tells me that it requires a resource not available.
Clicking on change, W10 seems to go through some motions before
quietly doing nothing.
How do I find joy (not Joy, that is in my kitchen).
Edit: corrected date
skeeve wrote:
The latest update of *anything* I can find is 10/16 .
Windows 10 limits the amount of stored previous builds.
Other options are restore points and backups.
AskWoody
How to roll back a bad driver update
Posted on December 30th, 2016 at 08:09
https://www.askwoody.com/2016/how-to-roll-back-a-bad-driver-update/
11/16 is older than my current.
At the moment, my system is in a state thaat I would not want to restore to.
AskWoody
Found it, but the updates listed do not have rollback as an option,
possibly because they are all more than ten days old.
The only vaguely relevant thing I can find that offers rollback
is the ELAN HID class filter driver.
It appears never to have been updated and its install date
is before I bought the computer new.
I really need to fix this.
It's a show-stopper.
skeeve wrote:
Found it ...
Is "it" WinUSB?
If yes, WinUSB is mentioned in Zadig.
[Zadig icon]
Zadig - USB driver installation made easy
http://zadig.akeo.ie/
gchapman wrote:
skeeve wrote:
Found it ...
Is "it" WinUSB?
No.  It is the AskAndy rollback stuff.
The only mention I found of WinUSB was under Atmel-ICE data data gateway: device started (WinUSB).
Is WinUSB's absence the likely problem?
Very likely WinUSB is present.
Attention was drawn to your OP :
After the following then I'm at a loss :
(as-installer-7.0.1645-readme.pdf)
(page 15)
2.4 Driver and USB Issues
2.4.1  How do I get my Tool to be recognized by Atmel Studio?
This should happen automatically, but sometimes the Windows driver does not recognize the tool correctly. To correct this, you have to check that the tool is listed under the Atmel node in the device manager in Windows. If your tool is not listed, try to find it under Unknown devices. If it is located there, try to reinstall the driver by double clicking the tool, click the Driver tab and choose Update Driver. Let Windows search for the driver. The driver should be reinstalled and the tool should be displayed under Atmel. Now, the tool should be usable from Atmel Studio.
Edit: typo
Again, how many times do I have to repeat myself, Atmel-ICE uses HID for the debugger access. So there are no drivers required for debugging. DGI uses winusb for its transport, which is tied to the Data Visualiser.
We moved.the older bulk tools from jungo to winusb some time back (but this only applies to the MK2, stk600 and jtagice3 with firmware version 1 or 2.
:: Morten
I'm not using the Atmel-ICE just for debugging.
I'm also using it to install programs.
I tried to update the driver labelled Atmel-ICE data gateway.
W10 says it's already up to date.
IIRC the 50mil pitch target cable can become intermittent.
According to a multimeter and some wire-wrap wire,
all ten connections are there.
Also, the ribbon cable connects to the AVR, not W10.
Would a broken AVR connection cause AS7 to not find the ICE?
No
An alternate to the ribbon cable is the squid cable in a full kit Atmel-ICE.
I have no more ideas.
I borrowed another Atmel ICE, one with a different serial number.
AS7 noticed.
It worked.
After replacing it with the original,
the original worked also.
That's a relief!
Want to buy a new Atmel-ICE (full kit)?
https://www.avrfreaks.net/forum/microchip-dev-tools-end-year-2017-sale
