Problem with strcasecmp()
41 posts / 0 new
hello
i wrote a program to control atmega16 pins with sms using sim300 and here is my code:
#define F_CPU 8000000UL
#include <util/delay.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include "usart.c"
#include "sim300.c"
	DDRB=(1<<PB0)|(1<<PB1)|(1<<PB2)|(1<<PB3)|(1<<PB4);
	DDRD=(1<<PD7);
	uint8_t id,r;
	while(SIM300Init()!=SIM300_OK);//wait for intit
	PORTB|=(1<<PB0);//led to indicate init is done
	while(SIM300GetNetStat()!=SIM300_NW_REGISTERED_HOME);//wait for sim to be registered
	PORTB|=(1<<PB1);//led to indicate sim is registered
	char oa[20];//sender number
	char msg[300];//array to store the message
	while (1)
		while (SIM300WaitForMsg(&id)!=SIM300_OK);//wait for meassge
		PORTB^=(1<<PB4);//toggle pb4 to indicate a message is received
		_delay_ms(300);
		r=SIM300ReadMsg(id,msg,oa);//read the message and store it in msg array
		if(r==SIM300_OK)//if read is successful
			if(strcasecmp(msg,"led3-on")==0)
				PORTB|=(1<<PB3);
			else if (strcasecmp(msg,"led3-off")==0)
				PORTB&=~(1<<PB3);
			else if (strcasecmp(msg,"led2-on")==0)
				PORTB|=(1<<PB2);
			else if (strcasecmp(msg,"led2-off")==0)
				PORTB&=~(1<<PB2);
			msg[0]=0;//clear msg array data
		_delay_ms(300);
		if(SIM300DeleteMsg(id)==SIM300_OK)//delete the msg
		PORTD^=(1<<PD7);//led to indicate delete is successful
All LED indicators work good but my problem is that when I send any text, only PB2 is toggled (doesnt matter what text i send.)
But strcasecmp() returns 0 when it matches.
Your code looks as if it expects true for a match.
oh yes!
i corrected the code in my post
the problem is still remaining
Either the code above has been edited, or some of the tests do the correct and test if the return from strcasecmp() is zero, e.g.
and the others (erroneously) take the return value as the condition of the if-statments, e.g.
else if (strcasecmp(msg,"led2-on"))
Indeed.
As do most (all?) ..cmp() functions.
They do so for the reason that you don't only want to have a match/no-match return, but you want to know if one is "less" than the other. E.g. for using when sorting data. The ..cmp() functions returns -1 first parameter is less than second, 0 if they are equal and 1 of first parameter is greater than second.
if sending "led3-on" isn't working then it might be because the message does not contain exactly "led3-on" when received. Could there be a line ending character, e.g. \r or \n or a combination of those two?
now none of PB3 and PB2 toggle.
i dont send any additional character
Show the source of
SIM300ReadMsg()
int8_t	SIM300ReadMsg(uint8_t i, char *msg, char *oa)
	//Clear pending data in queue
	UFlushBuffer();
	//String for storing the command to be sent
	char cmd[16];
	//Build command string
	sprintf(cmd,"AT+CMGR=%d",i);
	//Send Command
	SIM300Cmd(cmd);
	uint8_t len=SIM300WaitForResponse(1000);
	if(len==0)
		return SIM300_TIMEOUT;
	sim300_buffer[len-1]='\0';
	//Check of SIM NOT Ready error
	if(strcasecmp(sim300_buffer+2,"+CMS ERROR: 517")==0)
		//SIM NOT Ready
		return SIM300_SIM_NOT_READY;
	//MSG Slot Empty
	if(strcasecmp(sim300_buffer+2,"OK")==0)
		return SIM300_MSG_EMPTY;
	//Check if OK
	if(strncasecmp(sim300_buffer+2,"+CMGR:",6)==0)
		char *start,*end;
		//Find the 3rd "
		start=strchr(sim300_buffer,'"');
		start++;
		start=strchr(start,'"');
		start++;
		start++;
		end=strchr(start,'"');
		*end='\0';
		strcpy(oa,start);
	//Now read the actual msg text
	if(len==0)
	strcpy(msg,sim300_buffer+1);//+1 for removing trailing LF of prev line
	return SIM300_OK;
If that was re my post, then I wasn't talking about what "you" (i.e. the AVR) is sending.
You are having problems interpreting what the SIM module sends to the AVR. Are you sure the SIM module does not send line endings?
We can say nothing about that unless you post the code you have "now".
"now" means <after i corrected the code as i said in my second post.
my code:
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include "usart.c"
#include "sim300.c"
	DDRD=(1<<PD7);
	uint8_t id,r;
	while (1)
		_delay_ms(300);
				PORTB|=(1<<PB3);
				PORTB&=~(1<<PB3);
				PORTB|=(1<<PB2);
				PORTB&=~(1<<PB2);
		_delay_ms(300);
usart library is attached.
PB0,PB1,PB4 and PD7 toggle as they should but PB2 and PB3 dont.
please help
reza_mslm wrote:
#include "usart.c"
#include "sim300.c"
Is this actually what you have in the code or is it a typo?
If that is the code then that could be causing issues as you are including the C source code instead of the header files. It should be:
#include "usart.h"
#include "sim300.h"
It may not fix all your problems but it may help.
The include thing doesn't seem entirely likely to be relevant, if things are building at all it's probably unidiomatic but not breaking anything.
What you probably need here is some more insight into what's happening.
I note that you have a couple instances of |=, and a couple of ^=, for LED toggles. Probably ought to be using |= to turn on, and &=~ to turn off, so you know which way each thing is setting the LED. An LED being toggled really fast can be invisible.
I don't see the declaration of sim300_buffer. I guess what I'd probably do first is, on message receive, set one LED to indicate which of the SIM300 codes you got back (_OK, _MSG_EMPTY, _SIM_NOT_READY, _TIMEOUT), and delay for a little bit so you have time to see the light flash. If you consistently see the light for _OK, then you know you should at least be getting *some* kind of string back. Obviously, if you can get a console you can dump things to, that'll make it a lot easier...
no, that is the code.
i have added .h files to my solution.
that is OK and there is no problem.
my only problem is what that is said.
it is declared in sim300.c
Absolutely.
The ATMega16 has "Extensive On-chip Debug Support" - so use it!
Fault-seeking is about forming hypotheses about an isolated cause of the problem and the n test those hypotheses. One by one. In a structured manner. Isolated, so that you know what you're testing.
Ideas for a list of isolated hypotheses:
  • Something is wrong with how responses from the SIM module is interpreted. (E.g. see my ideas above about the SIM module possibly not sending the exact strings you're thinking it does - e.g. it might add line ending chars". Ways to test: Hook up the SIM to a PC serial port (with a level converter) and use a good terminal software so that you can get "raw" unfiltered/untranslated views of what the SIM module actually sends. Or.. Change your AVR program to test on beginning of SIM message string using strncmp() (rather than the complete message).
  • Something is wrong with how you toggle pins. Start by doing a structured inspection of all your togglings. Make them uniform - i.e. do it the same way everywhere (not ^= in some places and |= in others.
  • Something is wrong, hardware-wise, with some of the port pins. Or with one of the LEDs! Easily tested by swapping a toggle that works to one of the non-working pins.
As I said above. Test one of these at a time. Work slowly and structured. Be meticulous with making notes - pen, paper and brain are the prime tools here!
This is all standard procedure and way of working when debugging. The Devils is in the details, and in the situations where several things are wrong. "Combinatory bugs" are at least as much hell as are intermittent faults, and require a very structured way of working to get solved. You don't know if your problem is a combination of faults so be structured and prepared from the start!
HTH!
I assumed it was declared in sim300.c, but since we can't see it, we don't know what type it has, or how much storage it has, or anything else. There's a lot of things here that look like they might need bounds checking, or could be overflowing bounds. I'd check on that, too.
it is actually attached in #7
thank you every body
i found the problem by adding a character lcd to my circuit and showing the received message and oa[](sender number).
i found that my message is not received completely in most times. for example when I send "Led3_on" lcd shows: "d3_on" or "_on" etc.
is that problem because i have not attached GSM antenna to the module??
No.
Although not having an antenna connected is a Very Bad Idea, the module will either receive the complete message, or nothing at all. The GSM protocols will ensure that it doesn't get partial messages.
It must be your code missing characters.
EDIT
typo
See this post for how to monitor your serial communications using two terminals: https://www.avrfreaks.net/comment...
And this for a discussion of serial comms debugging tools & techniques: https://www.avrfreaks.net/forum/m...
The problem is very likely in your usart.c file -  which seems to me to be handling a ring buffer, though in a somewhat "exotic" way making it a hard read (for me). I might review your code in usart.c a bit more later today, but my advice to you is to look in that file first for the problem.
This is an excellent case for testing without involving AVRs or Atmel Studio at all. Get your favourite "C for PC" IDE up and write a small test-bench that runs the functions in usart.c. Make extensive use of your favourite IDEs debugger and step through code while debugging.
Another possibility to investigate is the code in sim300.c. It might do bad readouts from the ring buffer. E.g. is that read-out code atomic (non-interruptable)? Since the reception proper is interrupt-driven this is more or less a requirement.
+999 !!
Also note that the ATMega16 has on-chip debug:
The ATMega16 Datasheet wrote:
• JTAG (IEEE std. 1149.1 Compliant) Interface
– Boundary-scan Capabilities According to the JTAG Standard
– Extensive On-chip Debug Support
– Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
So use it!
Two obvious things. One, you're allocating a 300-byte buffer to use, and that's large enough to be a likely problem on machines with only 2K or so of memory. The other is, you've got a lot of points at which you skip past things (like the strcpy starting from buffer+1) which could be resulting in skipping past some characters.
that is to skip CR or LF characters
it requires JTAGICE MKII device and i dont have it (and can't buy it for some reasons)
it is noticable (and strange) that oa[] which is sender number is read correctly all of time but msg is not while these both are read with a same manner
A mega16 is old enough that you can debug with one of the $10 JTAGICE clones from ebay. No need for an expensive device like JTAGICEmkII (or these days probably Atmel-ICE)
I still argue that the code for circular buffer and the whole SIM part of the code is actually not relying on an AVR, or a microcontroller in general. It can be developed and tested in the less "awkward" environment of a IDE targeting any "PC operating system". There, it can be debugged in a controlled manner.
This will also have the additional advantage that the code will be clearly modularized.
I'd also replace the somewhat "hacky" implementation of the circular buffer with something proven and tested, e.g. Dean Cameras work.
I have the code given above in a NetBeans project and might rig it up for testing tomorrow. Or I might not, so don't stay up waiting.. ;-)
That may be  the intention - but does it actually work?
How have you tested and verified it?
Agreed.
Obviously the intent is to "skip CR or LF characters". But if you aren't checking what the actual values are, who knows?
Basic advice for debugging: If your code is not doing what you think it should be doing, you know that something you believe about your code or its inputs is wrong. So any time you say "well, this must be right, because...", stop and say "have I tested this?"
So any time you say "well, this must be right, because..." [...]
+1
Put another way: Assumption is the mother of much evil. The process of debugging is much about removing assumptions and instead establish facts.
Indeed.
Or, as stated in #16 - also here - it's about forming hypotheses and then testing whether whether they hold up.
See also: http://www.ganssle.com/articles/developingagoodbedsidemanner.htm
one forgotten note:
the usart,lcd and GSM libraries are written for ATmega32 and sim300
but i use atmega16 and sim808 with no change in the libraries. (I think the AT commands are the same)
would this be the problem source?
There's another assumption!
What have you done to confirm that they're the same?
Likewise with the ATmega32 vs 16 ?
However, I'd have thought it most likely that any problems here would result in it not working at all - rather than just missing odd characters?
Was the code actually tested on an ATmega32 and sim300 ?
YES! The libraries are tested in a voting system
http://extremeelectronics.co.in/...
when i burn the above voting system Code to my circuit and I SMS (for example) "VOTE D" it is not recognized!(GSM sends Invalid Vote ...) AS "Led3_on" was not in my Code!!
I think buying an atmega32 will not solve the problem:
http://www.atmel.com/Images/doc2...
I found the solution
commenting the
UFlushBuffer();
in first
Sim300WaitForResponse();
that was used in
SIM300ReadMessage();
(it was causing data loss.)
thank you friends.
I want to state for the record that i cannot possibly stress enough how completely, totally, insane it would be to use anything this poorly understood or maintained for any kind of thing for which "voting" would be at issue. If you don't know *why* that code was there in the first place, or what it was trying to do, just commenting it out may make things better, today, but it may break something else tomorrow.
And voting is way too important to leave to "we don't really understand this". Get someone more qualified in to review the code carefully. Seriously.
It's not clear that the OP is actually doing a voting system - it seems that (s)he may just have nicked the SMS code from it ... ?
But it is a very important point that just randomly hacking about in poorly-understood code is not a great way to build reliable, dependable systems ...
Indeed. Just because a problem stops occurring does not mean the problem is actually identified and removed/rectified. Removing the symptom and believing the problem has been removed is also possible.
Sort of depends, eh? Could be the European Song Contest, SomeCountry Got Talent, or a family voting for Tacos v/s Pizza for dinner..
Even if it's not actually a super-important thing, it still seems like it'd be worth studying and understanding to find out why that line of code used to be needed but doesn't seem to be now...
Absolutely. I was just hinting at the consequences might not be so severe as if this was a general election or some such. And I should have placed a winky-smilie on my post. Here it is: ;-)
