Number must be positive and less than 8
33 posts / 0 new
So i have this piece of code
inline void sendByte(uint8_t clr) {
	for(uint8_t i = 0; i < 8; i++) {
		if((clr & (1 << (7-i))) > 0) {
			asm volatile(
				"sbi %[port], %[pin] \n\t"
				".rept %[delayH] \n\t"
				"nop \n\t"
				".endr \n\t"
				"cbi %[port], %[pin] \n\t"
				".rept %[delayL] \n\t"
				"nop \n\t"
				".endr \n\t"
				[port]	"I" (_SFR_IO_ADDR(PORT)),
				[pin]	"I" (PIN),
				[delayH]	"I" (T1HC),
				[delayL]	"I" (T1LC)
		} else {
and when i compile it it gives me this error, any idea how to fix this?
1)  Your error list shows a span of over 100 lines -- much more than the posted fragment.
2)  Which line is 51?  Which line is 55?
3)  Aaah, GCC inline assembler.  The infinite-value toolchain.  Those with a good supply of eye of newt might be able to help but not us mere mortals.
(if I had to guess, it applies to pin or PIN)
aj22r wrote:
asm volatile( "sbi %[port], %[pin] \n\t"  line 51?
"nop \n\t"
".endr \n\t"
"cbi %[port], %[pin] \n\t" line 55?
When you look into inline gcc assembly... it looks back at you.
I suppose in your program PIN is higher than 7 and then the sbi and cbi instructions go out of range? Or maybe PIN is not a constant?
Is that something you wrote yourself, or something you found elsewhere ?
Think about the possible values for i in that loop;
For each of those values, think about what
(1 << (7-i))
becomes ...
I forgot to mention this:
#define PORT PORTB
#define PIN 0x20
I found the assembly part elsewhere, but the other stuff i wrote myself
It is very hard for us to map the error messages to the source code snippet you posted.
Do us all two favors so that we can help you better.
FAVOR 1:
i) Do a rebuild (i.e. a clean followed by a build)
ii) Switch to the Output tab (where the complete build output is shown)
iii) Select everything
iv) Copy
v) Paste into post you make here
FAVOR 2:
Post complete source so that we can see all #define's etc. If they are in a separate header file then post that too.
go on - what about the loop values, then.
Use pencil & paper if necessary...
				[pin]	"I" (PIN),
#define PIN 0x20
You have to define PIN as a bit number (5 in this case), not as a mask.
Stefan Ernst
I do not see any problem. "i" goes from 0 to 7, so "(7-i)" goes from 7 to 0.
Stefan Ernst
Exactly, sbi and cbi assembly instructions take the bit number as argument, and not the bit mask.
Is zero positive ... ?
What are you talking about?
Stefan Ernst
The message said, "must be positive..."
But I agree that it's a red herring - it'll be the "bit position - not mask" issue ...
Oh, the error message. I thought it was also related to the loop values.
Stefan Ernst
The error message has an error ;-)
He who fights with bugs should look to it that he himself does not become a bug.  And...
Greg Muth
Portland, OR, US
Make Xmega Great Again!
...but the difference between the positive integers and the non-negative integers is 0.devil
Greg Muth
Portland, OR, US
Well, it's non-negative :P
I think this is a rigidly defined area of doubt and uncertainty ...
Anyone remember one-eyed no-nosed nothings?
No, but I remember one-eyed one-horned flying purple people eaters.
What do you try to do?
sbi can't take parameters, it's a fixed instruction!
To do what you want you have to make it with a AND with a mask and then use brne/breq.
joeymorin wrote:
purple people eater
Which is what my twin brother called the first car he ever owned - a purple mark 2 Cortina:
Ooh baby! That’s shagadelic!
Yep, those seats must have seen plenty of action back in the day ;-)
I have the movie.
I didn't even know it existed!  I had the '45 of the song.
NPH before Doogie and Dr. Horrible... I wonder if it's worth watching...?
Now you made me do a Google session, and the "Songfacts" are interesting
http://www.songfacts.com/detail....
...which includes
The song got its own Disney Channel film in 1988 with Purple People Eater, in which a young boy plays the song and accidentally summons the creature itself, who then befriends him on an adventure. Neil Patrick Harris plays the boy, who later went on to play Doogie Howser M.D..
...and hits for the "movie" on Wikipedia and IMDB.
Then there's C.W. McCall's 'Convoy'... followed by Kris Kristofferson's 'Convoy'  ;-)
My Apologies to the OP for the community dragging your thread into the abyss.
Yeah, that was me :(
