USBasp programmer not work with usb isolator ADUM3160
8 posts / 0 new
hi
my problem is my old USBasp programmer not work with usb isolator Module
i have old USBasp programmer that work pretty with avr mcu and progisp software
now i want to use my programmer with usb isolator ADUM3160 Module ( for protect laptop usb port )
but programmer not work with usb isolator and even not recognized with Device Manger ( my os is Windows 7 64bit)
i test ADUM3160 isloator with arduino UNO R3 and work ok but with USBasp progammer not work
in ADUM3160 userguid say isolator work with AVRISP progamer but not working
This product uses ADI's proprietary iCoupler® technology, the industry's first single-package USB isolation solution. Compatible with USB 2.0, provides full isolation 12 Mbps data rate, isolated 2500V voltage, no external power supply, no driver required. USB signal timing, amplitude, direction, rate, protocol and its complex, so the realization of USB signal magnetic isolation is also very complex technology, this paragraph basically represents the highest level of isolation field.
Technical indicators:
Compatible with USB2.0
ADUM3160 isolation voltage: 2500V
Power supply module isolation voltage: 1500V
support USB full speed 12Mbps does not support pure high-speed equipment
support USB control transmission, batch transmission, interrupt transmission, synchronous / isochronous transmission
Power supply: from the computer host USB port
free drive, the use of more convenient
Use of the environment: -40 ℃ to 85 ℃
Why is the USB interface isolated?
 USB interface is already one of the most commonly used interfaces for electronic engineers, practitioners daily work and life. With the computer industry more and more competition, product prices are getting lower and lower, Forcing the majority of businesses on the computer motherboard interface protection can be simplified to simplify, save the province. USB interface not only often with the human body, external contact, and many times it is also for External equipment powered. Many of these status led to a lot of computer USB interface strike in advance. Even the motherboard is damaged.
This product is suitable for the following users:
1. Contains strong electric, strong interference of the working environment Part of the circuit contains strong electricity, strong interference (such as high voltage, inverter, motor drive, etc.) environment, Related to the occasion with the computer connection, must be isolated to ensure that the computer, personal safety.
2. Noise sensitive areas We all know that the computer is a big source of noise. In the field of noise-sensitive we can through this device on the USB interface for communication isolation. Such as high-precision USB data acquisition system, HIFI sound system.
 3. USB debug device Such as various USB interface JTAG / SWD emulator, ISP / ASP / IAP / ICP download and so on. When you are unable to connect during a debugging process, the simulation is abnormal and you can use the USB Isolator to try to improve.
4. Various industrial USB devices Industrial environment, USB devices often crashes, such as USB mouse, keyboard, USB to serial and other communications equipment. USB isolators can effectively reduce the crashes and damage rates of these devices in industrial environments.
Sometimes need to extend the USB cable, USB isolator can act as a very good USB repeater, you can also isolate the upstream and downstream equipment to the pressure difference.
 5. Other common USB peripherals, such as mouse, keyboard, USB sound card, USB, printer, digital camera, USB hub (HUB), USB camera.
6. Medical equipment Human safety is the most important and important consideration, but some medical equipment through the USB interface and computer connection, in the human body to collect data or treatment process, the need for direct electrical contact with the human body,
And to avoid possible from the computer through the equipment and interface lines to the human body to the high voltage caused by electric shock, the electrical isolation of the interface line as one of the important protective measures.
Tested supported devices:
Full speed equipment:
USB chip, AVRJTAG, AVRISP, AVRISPMKII, S-Lab, JET51, J-Link, FET430UIF, PICKIT2, XDS100, LPC-Link, ICD2, USB to serial port (FT232, CP2102, PL2303, CH341 chip).
 After testing the device does not support USB wireless card, part USB3.0 USB.
Precautions:
This product onboard output power supply Jin Shengyang B0505S power 1W, when your USB device operating current> 180mA, you can use USB double head line plus power supply.
This product supports full-speed equipment, but does not support pure high-speed equipment (USB2.0). Most USB devices are backward compatible and can be used.
plz help, what i do ? change programmer ? change isolator ? or use another driver or software ?
can i convert Arduino R3 to USBasp progammer work with progisp software ?
plz help i need to connect progammer with isolator
Why would anyone want to remove an AVR from its pcb.   Program it on an external board.  Then put it back on the project pcb  ?
God invented ICSP and it does what it says: In-Circuit-Serial-Programming.
You put a 5x2 header on your target pcb.  Buy a proper Chinese $3 USBASP.   Plug it into the 5x2 on your target pcb.   Allow the USBASP to power the target board.   (select 3V3 or 5V on USBASP)
Traditionally USBASP comes with 5x2 header.   Some come with standard Atmel 3x2 header.   Or you can buy/make an adapter.
Dig a deep hole.   Bury your "usb isolator ADUM3160"
no i dont want to remove avr and put it back to pcb , exactly i want to pragrame avr with ISP(In-Circuit-Serial-Programming) and for this i worry and want to use usb isolator
the main problem is device manager not recognize programmer if i use isolator ( Whether I put avr in programmer or use with ISP cable)
why you say usb isolator not useful ? you mean this isolator can not protect my usb port ?
This may be your issue, not enough power to run programmer....
I'm not sure what your trying to protect against, there is nothing on the programmer that would damage your laptop.....
Your photos in #1 all show an AVR mounted in the ZIF socket.
If you are using a ribbon from the 5x2 header, it can provide power to your external board. Remove the external board from any hazardous wiring.
Your USBASP is no risk to your Laptop. There is only a risk if your external target is connected to mains wiring or high voltages.
If your external target is at dangerous potential, you can always use your Laptop on battery power. i.e. you isolate the whole Laptop.
i agree with you
but how arduino uno work with this isolator ?
on battery power normally laptop should be safe , but i burned one usb port in past and for that i want to connect with isolator
Why do you want to isolate?
Most things can be unplugged for programming.
Yes,  I can understand if your target is at the top of an electricity transmission tower.   Or at the top of a TV transmitter.
In which case,  you design accordingly in the first place.
