BRNE beginners question.
9 posts / 0 new
I am using the Arduino IDE and an Uno to learn the basics of AVR assembler.
I have the following code. It works fine except the changes I make in the "Donner2" subroutine are not reflected in the final Z.
I have been mucking around with this for an hour now.. any help as to what i am doing wrong is much appreciated!!
        LDI      ZL         ,  lo8(   Table2   )   //   Z  at element 0
        LDI      ZH         ,  hi8(   Table2   )   //   Z at element  0
        ADIW     Z          ,  5                   //   increment to element 5
        LDI      R16        ,  0                   //
        LDI      R17        ,  23                  //
        // NOTE!  If I RET here I will have array element position 5 as expected.
        RCALL    Check4
        LPM      R24        ,  Z                   //
        // NOTE!  This returns the value in array element 10, I expected the value in element 14
        RET
Check4:
        CP       R16        ,  R17
        BRNE     Donner2                // branch if EQUAL
        // these 2 ADIWs are not in the final value!!
        ADIW     Z          ,      1   // increment to element 11
        ADIW     Z          ,      3   // increment to element 14
        RET
Donner:
        RET
Donner2:
        ADIW     Z          ,      5  // increment Z by 3
        RET
I am a new AVR programmer. I am learning alone out of books, the Internet, etc. Please excuse me if I ask simple questions. Thanks.
Correction: It works fine but the ADIWs after the BRNE are not reflected in the final value for Z
Those ADIW are unreachable. When the BRNE jumps to Donner2, the return will be to the LPM...
David (aka frog_jr)
frog_jr:
Thank you for a quick and clear answer.  What could I do differently to it can be reached? What I am trying to do is just play with nested function calls and make sure I understand them and how to call / return properly.
CPSE   R16, R17
RCALL Donner2
seems to do it.
Thank you frog_jr!!
Perhaps something like:
    CP       R16, R17
    BREQ     RegsEqual    // branch if EQUAL
    CALL     Donner2      // Increment by 5
Regs_Equal:
    ADIW     Z, 1       // increment to element 11 if R16 != R17, else element 6
    ADIW     Z, 3       // increment to element 14
    RET
Donner:      // Not used
    RET
Donner2:
    ADIW     Z, 5       // increment Z by 5
    RET
This will branch to Donner2 if R16 == R17 and then return to LPM
This will call Donner2 and then continue to the two ADIW if R16 != R17.
Edit: you figured it out while I was typing...smiley
David (aka frog_jr)
One final question:
CPSE is compare and skip if equal.
I can not find any "compare and skip if NOT equal" directly as an opcode.  Does such an animal exist?
Not on AVR, and that has been the subject of much grumbling around here over the years.  E.g.:
https://www.avrfreaks.net/forum/cpse-instruction
https://www.avrfreaks.net/forum/use-cpse-instruction
https://www.avrfreaks.net/comment/1083171#comment-1083171
Joey:
Thank you for the help!
