open ready made arduino functions
3 posts / 0 new
Hello guys
Is there a way I can read what is inside the ready made arduino functions like analogWrite() and analogRead()??
It's all open source, and ships with the IDE.  Just have a look inside the folder to which you extracted it.  The functions you mention are within the file wiring_analog.c, but there's a fair amount of interdependence with other files as well.  You'll want to inspect most of what's in that folder.
"Read a lot.  Write a lot."
