Am I misunderstanding I/O multiplexing (or is this a Datasheet error)?
22 posts / 0 new
I am looking at the Atmel SAM D20E / SAMD 20G / SAM D20J data sheet (Atmel-42129P-SAM-D20_Datasheet_Complete-09/2016), and specifically at Table 7-1 Port Function Multiplexing.
I was under the impression that for each SERCOM/PAD it would only be routed to one pin under "function C" (SERCOM) and one pin under "function D" (SERCOMALT).
In the table I find two sets of entries for the SERCOM4 PADs (PB08-09-PB10-PB11 and PA12-13-14-15). Similar duplicates exists for e.g. SERCOM3 and SERCOM5.
I have a hard time believing such a blatant error would pass through corrective reading before publishing, so what would be the point in "duplicating" the routing in this way, having the in- and out-put of one SERCOM on several sets of pins?
EDIT/PS: I confess not having read every word of the data sheet yet. On my way, though...
You must remember that you select the function of each pin individually, not as a single unit.
So you can configure each SERCOM pin as required.
David
Doh! Of-course. blush
This is what happens to me when I take in too muck information in too short a time for my brain to cope with. Assumptions and misconceptions roam freely between my ears.. wink
The more general question, for understanding, would be "what parameters are behind how the set of possible "routings" are determined?" Why the duplication of e.g. SERCOM4 routing possibilities? Did the Atmel people have specific options/applications in mind, or is it simply what reasonably could be designed? (Hope you get what I'm asking - I am aware the question might sound weird...)
JohanEkdahl wrote:
muck information
laugh
Nope - I never could fathom that.
Especially, IIRC, some of the omissions.
angry
I found it useful when the pins could be adjusted to accommodate  other needed functions. In one instance, I found it allowed for a bit more "elegant" board layout.
awneil wrote:
Especially, IIRC, some of the omissions.angry
yes
I still tend to find combinations where no twiddling of the pins can get all of the desired functions, so off to a larger package or another device.
David
awneil wrote:
JohanEkdahl wrote:
muck information
laugh
Both fun and serious: I'm not sure what has happened to my typing lately, but I do that more and more. Not hitting the adjacent key but hitting "similar" keys, not only phonetically similar (but that happens too). 'k' instead of 'h', 'c' instead of 's' (in Swedish both are often "sss"-sounding. The weirder one is 'e' instead of 'a' or vice verse - I'm heving problems with my kayboard typing. It's like there is some badly programmed logic in my psyche - a corrupted LUT? Time for a shrink?
Is is probably just that you need a new keyboard!wink
David
Back to serious things after this flippant discussion
If it's anything like the SAMD21 you can configure how the pads are used with the bits SERCOMn->CTRLA.TXPO and .RXPO
I could give you a short example of code (not ASF) for setting up a SERCOM to talk to a GPS module
Jerry
Yes, it is.
Yes, we know that - but you're missing the point.
The point is that only a few of all the possible permutations and combinations are actually available - so the question was how (if at all) they decided which ones to put in, and which ones to leave out.
Yes, it's very much like the D21. And, yes, I know how to configure the I/O multiplexing. My initial question was a brain fart due to constipation in my synapses. ;-)
Thanks for the code offer, but (as noted in some thread here) I have SERCOM USARTs running just fine (like you, no ASF). Rx working both polled and interrupt driven. Will hook in circular buffers and test out interrupt driven Tx eventually, but right now I'm more eager to get the OLED Xplained extension board working. That requires SERCOM SPI (a different beast!), code to control the SSD1306 display controller which is new to me and then some font stuff too.. After that I'd like to go for SERCOM I2C since I have a separate OLED (also SSD1306) that uses I2C.
Both of those was what triggered a new inspection/study of the I/O multiplexing table in the data sheet, and somewhere at that point my brain went into overheating. (-:
Only a very limited number of pins can do I2C - so that further reduces your options for that case ...
Also, some of the pin assignment choices on the XPro board do seem, well - "strange" ...
I know. That was part of the reason for me re-visiting and studying the mux table in the sheet.
awneil wrote:
O dear! You're right. My only excuse is that it was late and the brain was almost in hibernation mode.
It's indeed difficult to choose what pin should do what if you want to use a lot of the available pins. Just keep shuffling until something sensible comes out
It's easier with some of the PIC (should I mention that here?) chips, you can assign a function to any pin
Jerry
..and, while I might be guilty of choosing the wrong wordings and words my (follow-up) question was not even about how I should choose among the options available but rather:
What made Atmel choose the set of options they did? Are there any very thoughts behind it that I am missing? I assume they didn't just "sprinkle it out randomly", and knowing what thoughts/ideas/insights they had in mind might help me choosing how to multiplex things in a better way.
I spent the last hour yesterday doing a spread-sheet which combines most of table 7-1 from the data sheet with the pinouts of the SAM D20 Xplained board. Makes for easy sorting on whatever column you like, so I can easily get a list of what is available on the EXTn headers - ordered by n and pin within that. (I know I saw a similar spreadsheet being posted somewhere here the other day, but couldn't locate it again. Gotta love the search functionality of this site. Not... )-: )
https://community.atmel.com/comm...
David
You're welcome!
laugh
Absolutely.
And, as I said in the other post, it's a shame that manufacturers don't provide this information in an easily machine-digestible form - for precisely this kind of thing!
angry
Copying & pasting from the PDF is a pain, and it seems that it is more of a pain now than previously - as Adobe seem to have messed-up copying from PDF tables.
angry
In a thread I started myself! [rolls eyes] Ouch..
Dear all,
I find this thread interesting to deepen on this matter. All this after a case that I am facing:
After selecting a SAME54 uC for my project and doing the PCB I was to create a project with Atmel Start. My problem is that I cannot select the SERCOM ports I planned from the datasheet (and that I have routed on my PCB).
I do not know if I commited a big mistake by ignoring some point or I should modify later in the registers once obtained the project.
This is the info from the datasheet. The peripheral C for pins 34 & 35 are related to SERCOM4. There it is said that the PAD names are PB12 and PB13:
But in the Atmel start I have no option to select them. Only ports related to A:
I tried to enter in advanced menu and I can only select these port names.
For sercom0 I face a similar case:
Hope you can help me solving this question.
Thanks and best regards.
I2C pins are listed in "6.2.6 SERCOM I2C Configurations", alas no PB pins there.
/Lars
Thank you Lars.
it is clearly printed out there. Time to fine soldering.
I will check the meaning of all this in some days. At present moment I do not get it out.
Best regards.
