Latching Relay vs Flip Flop
37 posts / 0 new
Hi all,
I need some analog design advice. I am designing a circuit that every time a switch is pressed the output latches to the opposite state.
In regard to reliability, what is the most reliable and easiest to implement circuit, relay or the flipflop latch design. Also could you point me to what is considered the best most reliable configuration and components.
Tuurbo46
Latching switch?
Where does the analog come into it? Latching relays and flip flops are bistable devices. Do you want to remember state without power?
perhaps look for "solid state relays"
This circuit will sit in between a 5V switch in a control board and an ecu module.  This circuit needs to remember its state on power down.
Circuit requirements:
* Vin = 5V
* Vout = 5V
1) Button press 1, Vout = 5V
2) Button press 2, Vout = 0V
3) Button press 3, Vout = 5V
4) Button press 4, Vout = 0V
5) etc etc
Flip Flop Circuit
I have considered modifying the third circuit down (setting the starting state) on the below link, and feeding it with 5v and not 12v, but I am struggling on modifying the output electronics.
http://www.pcsilencioso.com/cpem...
Latching Relay
I have looked at a switching relay, and I think this part might be suitable but I am not sure.
RS Stock No.683-9469
I really need clear directing and a bit of help on what is the best/ easiest to implement.
Many thanks,
Tuurbo46
Tuurbo46 wrote:
I have considered modifying the third circuit down...
But none of them will "remember" state across a power-down
So what, exactly, is your "struggle" ?
A big part of that equation is the capability of the implementor.
It sounds like for you the simplest thing is going to be to use a relay.
EDIT
Actually, Brian's suggestion to use a Latching Switch is simpler.
5) etc etc
Still looks like a latching switch to me.
Yep... me too.
Thanks for all your inputs.
I cannot go the latching switch route, because I have already cut the control board interface and fitted a standard on/off push switch - yes my mistake I should of designed the circuit first.
So my next option is to go the FF or latching relay route.
I have added a picture of a circuit that I have modified, from the above link.
I would like the output to be able to supply 5V @ 100mA, but I think I am only going to get 4.3V (5V - 0.6V) and ~5mA.  Is this correct or have I calculated wrong.
How would I go about changing the circuit to supply 5V and the ability to supply 100mA?
Tuurbo46
But... as Andy has correctly stated in post #6,  none of those will survive a power down. You stated that the solution must remember its state before any power down.  Mistakes happen. Fix the mistake, don't try to make the mistake work.
Go on - those switches just mount in a standard hole.
Almost invariably, manufacturers make a range of switches with models in the various push-on, push-off, push-push options.
Unscrew the wrong switch, and screw-in the right one!
Job done.
+99
Especially as you said simplicity & reliability were key ...
Since this is an AVR forum, what about an ATtiny13 storing previous state in EEPROM...
David
Sledge hammer/peanut
 ... though the hammer might come in handy for removing the "wrong" switch ...
wink
Sorry to be a pain.  The switch will not physically fit - I would use if i could.
OK lets ditch the last know state, just initialise into a default state.
I have tried to simulate circuit #10, but the output is zero 0V.  Can you advise what i am doing wrong.  Also i have tried a default pmos and still no operation.
Tuurbo46
like I said, they are not usually unique - there is usually a range of contact & switching options in the same outline.
Why not post the manufacturer & part number &, preferably, a link - then we can see if we can find something compatible ...
If you would still like to have a set of contacts alternately open and close with each switch cycle, and have them stay in their last set state while the power is off, I bet I could dig up a circuit I once built for someone that uses a dual-coil, magnetically latching relay and about a half dozen, very to pretty inexpensive, passive parts.
- John
You can get bistable relays. I remember them being referred to as "Carpenter relays", but Google doesn't find much under that name. Search for "bistable relay".
In America, they are often called stepper or sequence relays. The aforementioned relay-plus-cheap-passives circuit replaced a stepper relay that was considerably bigger than a 35 mm film canister.
Oh, they are also called impulse relays.
- John
This, and replace one of the LEDs with a relay...
Or this...
I think that's what (s)he's referring to as a "latching" relay.
The RS 683-9469 part referenced is: http://uk.rs-online.com/web/p/la...
I have some that are about 3x5 mm and about 4 mm high. It really confuse people when they try to debug/reverse engineering :D
The OP's relay just latches. You have to pulse first one coil and then the other, and back again, to get it to alternately open and close, impulse by impulse. You can do that with a few cheap passives and dedicating a set of contacts.
- John
Hi jfiresto,
Is this the type of relay you mean?
RS components: 683-9469
Tuurbo46
A discussion of "latching" and "impulse" relays: http://www.mouser.com/ds/2/357/1...
EDIT
Sounds like what you want is the "impulse" relay, by this terminology
That one also just latches, but you can turn it into an alternating-action, impulse relay (as defined by the above Mouser link), by adding a few diodes, resistors and capacitors.
SORRY: Strike that. That 683-9469 is SPDT; you many want or need a DPDT relay (what I used) to steer the impulses.
- John
Here is the circuit for a momentary switch giving 12V pulses, with a 12V DPDT latching relay and a couple more parts to deal with automotive transients (unclamped load dumps, etc.):
alternate action relay
It is from a 15 year old Eagle project which still opens with Eagle 6.6.
- John
Tuurbo,  You have ~ 200 posts on a microcontroller Forum, so presumably you have some experience with micros...
So why not consider a Tiny with a push button switch and a small NFet transistor, (2N7000) driving a small relay.
The micro can save the last value in EEPROM as well, so it will power up in the last state it was in in prior to shut down.
Reading, (and debouncing), an input push button switch is straightforward, as is turning an I/O pin high or low to drive the transistor which drives the relay.
Reading the EEPROM on power up, and storing a new value when it changes, is another couple lines of code.
A clean power supply for a vehicular environment is needed.
Edit: Typo
See #13 - and the reply at #14
cheeky
I had ignored #14, but since you bring it up...
When you have access to a $0.50 (38p) sledgehammer, it starts looking like the right tool for the job!wink
David
laugh
I actually considered using an AT90LS2343 before quickly designing the circuit of post #28. Using an MCU would have used at least as many parts and I would still have to program it. For two installations, laziness triumphed over high-tech hotness.
- John
It takes a bit of work to build reliability into a microcontroller. There’s always the 555 -
http://www.talkingelectronics.com/projects/555/Page3-555.html
Output is good for 200mA
Thanks for all your input.  Very helpful forum as always.
I will have a good read and come back if I get stuck.
Tuurbo46.
Now I'm oddly curious.  I've never seen a solid-state latching relay.  Presumably one could make one out of the feedback circuit in #28, but I've never heard of one with that built in.  Still, I don't think it would stick in position very long after a power outage.
Personally, for a similar application I used a latching relay, an Omron G5RL-K1-E*, and instead of driving the set and reset coils directly from the AVR I buffered them through a couple of 2N2222 transistors.
S.
* DPDT, 16A, 250VAC, 1" long, 0.4" wide, 0.5" high (dimensions approximate).
Bit of an old thread here (ten days!!) but I just noticed something on the All Electronics website that I thought looked somewhat relevant to this:
https://www.allelectronics.com/i...
It's a 3V coil latching relay.  30Vdc / 1A, 125Vac / 0.5A on the contacts.  Cute!
S.
