ATTiny2313 and LM7001J(M)
2 posts / 0 new
How to use ATTiny2313/ATmega8A  for control LM7001J(M) using LCD 1602  and 7-segment LED  matrix?
Pretty much the same reply as your other similar question:
https://www.avrfreaks.net/forum/attiny2313-and-i2c-tv-tuner
Topic locked
