Problem making AVR assembler work in the Arduino IDE
15 posts / 0 new
I am a beginner! I have the latest Arduino IDE (1.8.3 I believe ) installed on my other computer. I am learning to do AVR assembler out of a bunch of books.
All is well and I am writing functions, geting values, twiddling ports and pins to my heart's delight... Except some things just won't compile.
MyArray:     .DB   1,2,3,4,5,6
will not compile.
.DEF statements will not either
LPM will not put the value found at the address (specified in the Z register) into R0
I can work around all these but I still would like it all to work "right" and as it should.  I will not be supprised if I come across more things that should work but don't.
Aside from these and a few other glitches I seem to be able to write small, elementary code and verify the returned values are correct.
My question is there a list of know issues  trying to do AVR assembler in the Arduino IDE and any workarounds?
Thanks in advance.
I am a new AVR programmer. I am learning alone out of books, the Internet, etc. Please excuse me if I ask simple questions. Thanks.
will not compile.
What do you mean, "will not compile"?
Are you getting error message(s)? If so, what are they?
Note that "Compile" is what you do to High-Level Languages; the term for Assembler is "Assemble".
awneil:
Thank you.  Assemble  :-)
Here is the error with .DB  Please note the .BYTE works fine though. I don't know why.
sketch\limit1.S: Assembler messages:
sketch\limit1.S:117: Error: unknown pseudo-op: `.db'
exit status 1
Error compiling for board Arduino/Genuino Uno.
Yet this code snippet directly above the "MyArray" I am trying to make work assembles fine and I can access it fine.
Table2:
//   index        0     1       2       3       4       5      6      7
           .BYTE  10,   21,     32,     43,     54,     65,    76,    87
//                8     9       10      11      12      13     14     15
           .BYTE  98,   109,    110,    121,    132,    143,   154,   165
//                16    17      18      19      20      21     22     23
           .BYTE  176,  187,    198,    209,    210,    221,   232,   243
           .BALIGN 2
So what assembler does the Arduino IDE actually use?
There is no standard Assembler syntax - they are all different.
Have you RTFM for the particular Assembler to check if it is supposed to accept ".DB" ?  and, if it is supposed to accept ".DB", what the correct syntax is ...
I don't know the exact assembler Arduino uses under the hood.
I would RTFM if there was a FM to read. So far I have not found any FM for the assembler version Arduino uses and I have not found any FM that would point me to differences / changes / etc from AVR assembler... Thus my asking the questions here.
It matters - you need to know that!
Knowing which assembler it is is key to finding the FM for it!
OK... so being this is an Arduino forum on a web page with assembler experts... can some one please tell me exactly which assembler I have and where any manual / compatablity matrix exists if any.
I frankly don't know how to dive into Arduino and Java and find it out.
There's an Arduino forum here only because most Arduinos are AVRs.
The place to find the experts with specific knowledge of the Arduino IDE, etc, is the actual Arduino forums: https://forum.arduino.cc/
I just posted the question there.
When cross-posting the same question to multiple forums always give links between them - so that people can see what's going on.
Otherwise someone may waste their time giving an answer in one which has already been given in the other.
D:\Users\mutha>"C:\Program Files (x86)\Arduino\hardware\tools\avr\avr\bin\as.exe" -v
GNU assembler version 2.26 (avr) using BFD version (GNU Binutils) 2.26.20160125
Greg Muth
Portland, OR, US
Make Xmega Great Again!
Arduino uses the gnu assembler, called "as", more specifically "avr-as" in this case. Directive ".db" is from Atmel assembler.
You need to replace ".db" by ".byte". A list of available directives: https://sourceware.org/binutils/...
So the required manual is: https://sourceware.org/binutils/docs/as/
awneil, greg, El and everyone else: Thank you!  I am gonna download and start one it after Thanksgiving dinner... provided the triptophan doesn't nuke me first LOL
