long delay
7 posts / 0 new
I have a problem programming a long delay loop. It will work fine in AVR Studio simulation, but in an 2313 it will always jump back to start.
loop:
inc r1
brne loop
sbis PORTB,5 ; to ask if a key is set or not
rjmp Start
inc r2
brne loop
inc r3
brne loop
What is wrong with this?
Greetings Dieter
admin's test signature
Sorry if this is the bleeding obvious, but it seems suspicious that the jump target is the target of the conditional test for pin 5 on port B. Have you checked that port B is connected correctly and is at logic 0 (not floating)?
Sean
You may try implementing a short "de-bounce" delay inside your "ask if a key is set" (a couple of ms should be sufficient)
Hi Dieter,
If your testing an input pin from your keypad, then you should be interogating PinB,5 and not PortB,5. PortB is the port's latch.
If you do a read from PortB, all you're reading is the latch.
A read from PinB will read the actual pin.
Cheers Jack
Yesterday I hadn't the program listing with me.
I don't know what I'm doing wrong. It is my first
try programming a microcontroller.
Here is the whole program:
.include "C:\Atmeldef\2313def.inc"
.Macro Wait1 ; this is working
ldi R17,$15
WGLOOP0: ldi R18,$C6
WGLOOP1: ldi R19,$C9
WGLOOP2: dec R19
brne WGLOOP2
dec R18
brne WGLOOP1
dec R17
brne WGLOOP0
.endmacro
.Macro Wait2 ; this is working without
ldi R17,$FF ; the sbis PINB and rjmp start command
WGLOOP3: ldi R18,$FF
WGLOOP4: ldi R19,$FF
WGLOOP5: dec R19
brne WGLOOP5
sbis PINB,5
rjmp start
sbis PINB,6
rjmp start
dec R18
brne WGLOOP4
dec R17
brne WGLOOP3
.endmacro
start:ldi r20,0x04
ldi r16, 0x1F ;3 In- and 5 Out
out DDRB, r16
ldi r16,0xE0 ;Inputs Pull_up
out PORTB, r16 ;Outputs Activ high
out PINB, r16
Ein1: sbic PINB,5 ;wenn bit gelöscht-springe
jmp Ein2
sbi PORTB,0 ;setze PORTB,0 high
Wait1
nop
sbic PINB,5
dec r20
sbis PINB,5
inc r20
out PORTB,r20
Wait1
nop
Wait1
nop
Wait2
nop
rjmp Start
Ein2: sbic PINB,6 ;wenn PINB,6 low - springe
rjmp Ein1
Wait1
nop
sbic PINB,6
dec r20
sbis PINB,6
inc r20
out PORTB,r20
Wait1
nop
Wait1
nop
Wait2
nop
Wait2
nop
rjmp start
>From: alenze (Andreas Lenze)
That what I will try tonight.
So I'm waisting time in the controller (I need 60 sec. delay), I will try to let the controller do some
cycles another routine. I hope this will help.
Thank you.
Dieter
Hi Dieter,
If it's your first try, get an LED blinking first, then you can move on to sending guided missiles through Bagdad streets.
Cheers Jack
Dieter Schmidt Wrote:
>It is my first try programming a microcontroller.
