how to send a .hex file to atmega128 with atmel studio 7 ( V 7.0.1645)
8 posts / 0 new
Hi
This is my first text on avrfreaks.
I hope this is the right place to ask my question:
i do program atmega128 for years now.
i progam in Bascom, and this compiler creates a .Hex file.
Normaly i send this hex file with avr-studio4 to the atmega128.
now my programmer does not work anymore.
So i bought a new one.. but this one can not be used with avr-studio4
So i installed atmel studio 7.0
Now i can not find how to send the .hex file to the atmega128.
The program can read some info from the atmega128.
So i think, the program and the programmer unit works.
please help me.
Wim Apon PA0SLT
I am programming atmega's with BASCOM
wimapon wrote:
i bought a new one
It would help to know what, exactly, you bought!
Does its documentation not help you in getting it going with Atmel Studio?
EDIT
typo
The programmer is:  Olimex AVR-ISP-MK2 (www.olimex.com)
i can not find the information in the help or in the documentation.
problem is: i do not understand most of the typical abbreviations
Wim
A link to the actual product page would be more helpful that just the manufacturer's home page!
https://www.olimex.com/Products/AVR/Programmers/AVR-ISP-MK2/open-source-hardware
Did you read the AVR-ISP-MK2 user's manual linked on that page?
Olimex, in the AVR-ISP-MK2 user's manual, wrote:
2.3 Quick setup
The purpose of this sub-chapter is to provide instructions on how to quickly set up AVR-ISP-MK2 under Windows.
The quick setup had been tested under Windows 10 x64 and under Windows 7 x64. The quick setup had been tested with Atmel Studio 7, ...
https://www.olimex.com/Products/AVR/Programmers/AVR-ISP-MK2/resources/AVR-ISP-MK2.pdf
So have you followed those instructions?
If the Olimex instructions for the Olimex product you have purchased don't work, you should contact Olimex!
There is a 'Support' link at the foot of their page...
EDIT
Also a forum: https://www.olimex.com/forum/
A LUFA based function-like of the Atmel AVRISP mkII.
It can per the Olimex manual.
Atmel Studio
Programming Dialog
Memories
http://www.atmel.com/webdoc/GUID-ECD8A826-B1DA-44FC-BE0B-5A53418A47BD/index.html?GUID-B5991BFE-21E0-4AA1-9E69-C78A9BBF599D
https://www.olimex.com/Products/AVR/Programmers/AVR-ISP-MK2/resources/AVR-ISP-MK2.pdf (page 13)
Dear awneil and gchapman,
Thank you very much for your help.
you did set  me in the right direction.
IT DOES WORK NOW !
I always have the same problem: i did not realise that MEMORY means "program the memory of the AVR."
It sounds stuped.but i can't help
Anyhow: thanks a thousend times
Wim Apon PA0SLT
You're welcome.
Now please mark the solution: https://www.avrfreaks.net/comment...
Okay folks,
The solution is:
install the driver for the Olimex , AVR-ISP-MK2 apparatus
start atmel studio 7
use TOOLS
   use DEVICE PROGRAMMING
     choose TOOL:  the AVRISP 2
     choose DEVICE: search for atmega128 ( in a long list)
     chose INTERFACE:   search for ISP
use APPLY
    now comes a new menu
        choose: MEMORIES
            browse to the .hex file you wish to send to the atmega128
       click now on: PROGRAM
THAT IS IT!   It works like a charm
thanks folks.. i am a happy man
Wim Apon PA0SLT
