SPI not working on UC3-A3
4 posts / 0 new
Hi forum,
Working with a colleague trying to set up SPI on the AT32UC3A3256 (with ASF) --- we seem to be running into exactly the same issue as this (rather old) post:
https://www.avrfreaks.net/forum/u...
We are correctly using gpio_enable_module as mentioned in comment 3 --- other than that, the symptoms match, the results match, we can add the while loop where he says and it hangs as he says.
Any ideas/pointers?
Cal-linux
Do spi_initMaster() and spi_selectionMode() return SPI_OK (0) ?
Have you configured the 'chip-selects' with appropriate calls to spi_setupChipReg() ?
You will need to do an spi_selectChip() before transmitting data and probably (depending on your configuration), an spi_unselectChip() afterwards.
mikech wrote:
Do spi_initMaster() and spi_selectionMode() return SPI_OK (0) ? Have you configured the 'chip-selects' with appropriate calls to spi_setupChipReg() ? You will need to do an spi_selectChip() before transmitting data and probably (depending on your configuration), an spi_unselectChip() afterwards.
Thanks mikech --- this actually helped resolve the problem. It turns out spi_setupChipReg() was not returning SPI_OK because the baud rate divider was too large. We were running the UC3 at 84MHz, and trying to run SPI at 100k baud. spi_setupChipReg() enforces the maximum of 8 bits of divider, and 84MHz requires a divisor of 840. Increasing the baud rate to 400k resolved the problem. The SPI pins are now active and producing signals.
Cal-linux
Please mark the solution: https://www.avrfreaks.net/comment...
