ATMelICE signed dummy kext for MacOS X High Sierra
27 posts / 0 new
The AtmelICE calls itself a USB HID device for better or (mostly) worse. This causes heartburn on MacOS X because the OS claims it and you can't get at it via libusb, so avrdude doesn't work. In the past, the workaround has been a dummy kext that keeps the OS from binding it to the HID stack. High Sierra broke that because it now insists on signed kexts and all of the workarounds to date have dried up.
So I've ponied up for a year of the Apple developer program and asked Apple nicely to allow me KEXT signing privileges with my developer ID. And thus, behold! Here attached is a properly signed dummy kext that you can use to let avrdude see your AtmelICE with High Sierra.
Unpack the zip and move the file to /Library/Extensions, then do a "kextload /Library/Extensions/AtmelICE.kext". You'll get a complaint that some bozo named Nicholas Sayer wants you to approve a kernel extension. Go into system preferences, in the "Security & Privacy" section under "General" you'll see where you can approve that. You can then repeat the kextload command and avrdude should work after that (you may need to disconnect and reconnect your AtmelICE).
Wow!
Is there an AVRDUDE bug report?  (I couldn't find one in a quick search)
http://savannah.nongnu.org/bugs/?group=avrdude
I don't know why there would be - it's not a bug in avrdude.
One could consider a non-functional AVRDUDE as a defect.
Similar issue occurred for LUFA AVRISP where a signed Windows driver solved it.
The intention is to get your effort recognition and visibility such that your solution gets some legs.
Could also, or alternatively, announce in the AVRDUDE mailing list :
http://savannah.nongnu.org/mail/?group=avrdude
Sounds reasonable. I'll post it to the mailing list. Thanks!
FWIW, one of the replies from the mailing list says that support has been checked in (but not yet released) to link avrdude against libhidapi instead of libusb, which also solves the problem.
I moved file to extension folder, but it told me that I installed it wrong and I can not use it.
Nonetheless, I tried terminal command:
-  kextload /Library/Extensions/AtmelICE.kext
On which, I got this error :(
-  /Library/Extensions/AtmelICE.kext failed to load - (libkern/kext) not privileged; check the system/kernel logs for errors or try kextutil(8)
Also, in security and privacy settings nothing appears to be approved.
Would much appreciate your help, my university project is based on ATmega644m.
Pull up a terminal window and "chown -R root:wheel /Library/Extensions/AtmelICE.kext"
it does not give me permission
chown: /Library/Extensions/AtmelICE.kext/Contents/_CodeSignature/CodeDirectory: Operation not permitted
chown: /Library/Extensions/AtmelICE.kext/Contents/_CodeSignature/CodeRequirements: Operation not permitted
chown: /Library/Extensions/AtmelICE.kext/Contents/_CodeSignature/CodeRequirements-1: Operation not permitted
chown: /Library/Extensions/AtmelICE.kext/Contents/_CodeSignature/CodeResources: Operation not permitted
chown: /Library/Extensions/AtmelICE.kext/Contents/_CodeSignature/CodeSignature: Operation not permitted
chown: /Library/Extensions/AtmelICE.kext/Contents/_CodeSignature: Operation not permitted
chown: /Library/Extensions/AtmelICE.kext/Contents/Info.plist: Operation not permitted
chown: /Library/Extensions/AtmelICE.kext/Contents: Operation not permitted
chown: /Library/Extensions/AtmelICE.kext: Operation not permitted
Sorry... "sudo chown...."
thanks, sudo chown worked, but I still got "not privileged" error for kextload :((
Also, I have Mac OS Sierra, not High Sierra. Does it make any difference?
Are you doing kextload as root ("sudo kextload...")?
Yeah, it worked with sudo, thanks you a lot, I'm new to this.
However, I still have my initial error when I try:
- avrdude -c usbasp -p m644
Error is:
-  avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
Also, in university from their PC I successfully uploaded .hex to ATmega with c232hm cable.
But, on my Mac when I try:
- avrdude -c c232hm -p m644p
It gives me this:
-  Can't find programmer id "c232hm"
Despite I installed c232hm drivers and even additional thing for OS X El Capitan an up.
This kext only works for the AtmelICE. I don't know about other programmers.
I have an AtmelICE device. I have placed the kext file in the extensions folder.
And I have entered the following in terminal:
sudo chown -R root:wheel /Library/Extensions/AtmelICE.kext
sudo kextload /Library/Extensions/AtmelICE.kext
But I am still getting the "not privileged" error.
Has Apple further restricted the Kext loading with the latest security update?
After doing kextload, do you see a new thing show up in the security page of system preferences? You have to “allow” there before it will actually load. But it doesn’t show up there before you try once.
The first time I loaded it, it did give me the warning and and I clicked approve in the System Preferences. But after a restart the extension was still not working. So decided to give it another try. So I reinstalled the kext, and with every subsequent install I get the "not privileged" error, and it does not ask me to approve anything in the system prefs.
EDIT: I decided to give it another try and I reinstalled the kext (for the Nth time) and this time it went through without error. I did the exact same steps that failed last time.
However its till not actually loaded in the system as it does not appear in the list when I run kextstat. And avrdude shows this error:
jtag3_open_common(): Did not find any device matching VID 0x03eb and PID list: 0x2141
EDIT2: Following this article: https://www.synack.com/2017/09/0...
I have checked the KextPolicy SQLite database located at /private/var/db/SystemPolicyConfiguration/KextPolicy
And I can see that com.kfu.AtmelICE comes up as Allowed (1). So the Approval part seems to have worked. At least. Still not loading though :(
I’m all out of ideas, unfortunately. If you reboot the system itself should load it at startup and it should work.
Does anyone have anymore information on this? I'm also getting the permissions error after attempting a kextload.
Alternatively, are there any other debuggers that are known to work with High Sierra?
@ wespiard : Still no luck here.
I don't understand. If the permissions are set right, and it's installed in the right place, there's no other trick to it.
When you download the driver, modify the permissions in the folder you downloaded the file in, because when you copy it over to /Library/Extensions the OS immediately stages it to be loaded on the next restart.
  1. sudo chown -R root:wheel AtmelICE.kext
  2. mv AtmelICE.kext /Library/Extensions/AtmelICE.kext
  3. sudo kextload /Library/Extensions/AtmelICE.kext
So if you get a permissions error here's what you have to do.
  1. Delete AtmelICE.kext from /Library/Extensions
    sudo rm -rf /Library/Extensions/AtmelICE.kext
  2. Restart the Mac and get into recovery mode (hold down CMD + R while booting)
  3. Mount the OS drive by choosing the Disk Utility, select the drive and mount it from the menu.
  4. Open a terminal by going to the Utilities menu at the top of the screen and then Terminal
  5. Remove the driver from /Volumes/your volume/Library/StagedExtensions/Library/Extensions
    rm -rf /Volumes/your volume/Library/StagedExtensions/Library/Extensions/AtmelICE.kext
  6. Close the terminal and restart the computer
  7. Follow the steps in the first part of this post and you should have a working driver
Is there a kext for EDBG?
I wanted to use avrdude to program my ATtiny817 Xplained Pro board.
I got past the permissions issues that folks were talking about, but avrdude still won't talk to libusb:
bash-3.2$ avrdude -c usbtiny -p m32u4 -U lfuse:r:low_fuse_val.hex:h -U hfuse:r:high_fuse_val.hex:h
avrdude: error: no usb support. Please compile again with libusb installed.
I also saw several related warnings during avrdude installation (after the kext and libusb installs):
warning: No libftdi or libusb support. Install libftdi1/libusb-1.0 or libftdi/libusb and run configure/make again. [-W#warnings]
I reinstalled libusb followed by avrdude, but that didn't help.
I'm running OSX 10.13.3 High Sierra.
<p>~ Athyrio</p>
it works but I still get error:
avrdude: usbhid_open(): No device found
I'm running OSX 10.13.6 on MacBook Pro 15 and atmel ICE through usb hub (Mac only have USB-C)
Hi @nsayer,
Is there any chance that the kext files for High Sierra will work for OSX Mojave?  If not, if there is any chance of registering Atmel-ICE kext for OSX Mojave please?
At the moment, when I attempt to perform the kextload I get:
/Library/Extensions/AtmelICE.kext failed to load - (libkern/kext) not loadable (reason unspecified); check the system/kernel logs for errors or try kextutil(8).
And when I attempt to refresh the kext cache sudo kextcache -system-caches I get the following:
Bundle (/Library/Extensions/AtmelICE.kext) failed to validate, deleting: /Library/StagedExtensions/Library/Extensions/XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX.kext
Unable to stage kext (/Library/Extensions/AtmelICE.kext) to secure location.
Thank you.
