osc frequency and out put frequncy??
5 posts / 0 new
What is the relationship between osc frequency and frequency out put on avr pins?
ex:
for generate 500Hz,Which crystal is appropriate?(ATmega8A).
thanks.
It all depends on how you intend to generate the output freq - , bit banging or timer output
bit banging depends on the number of CPU clock cycles your code uses & the period of those CPU clock cycles
Timer output depends on the timer clock frequency & how the timer is configured.
full details can be found in the datasheet
mostafa147 wrote:
...for generate 500Hz,Which crystal is appropriate?(ATmega8A).
To generate EXACTLY 500Hz you need a crystal whose frequency is an EXACT multiple of 500Hz.
HOWEVER, it's very rare in the real world to need an exact frequency unless you are making high precision test equipment. In the real world you will have tolerances. What tolerance does your 500Hz frequency have?
"How have you proved that your chip is running at xxMHz?" - Me
"If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand." - Heater's ex-boss
Preferably, a power-of-two multiple.
In which case, you'd probably use a dedicated oscillator ... ?
Well, as mentioned above, if your micro's Xtal is a multiple of 500 Hz then it is easier to get a pretty accurate output signal.
If you can tolerate < 1 uSec jitter for the loop, and the micro doesn't have to do anything else, (LCD display, user push button switches, etc.,), then the code is only a few lines:
$clock = 10000000 '10MHz, for example
Config I/O pin here
Main:
 do
  Set SignalPin
  waitus 1000 '1/2 Period High
  Reset SignalPin
  wait1000 '1/2 Period Low
loop   'Forever
Otherwise, have a look at the Timer/Counter and setting it up in CTC mode to generate an interrupt every 1/2 Period.
Inside the Interrupt Service Routine you toggle the I/O pin to generate your signal.
There is a Tutorial or two on Interrupts in another sub-Forum on this site.
Edit:Typo
