How to Get string using uart interrupt
8 posts / 0 new
hello everybody . I have two board avr using atmega2560: board master and board slave . when board slave doing something, board master send a string. I use  uart interrupt but the string I received was error . this is my code of slave . thanks for reading.
String str = "";
UseString()
    //do something;
int main()
  UBRR1H = 0;
  UBRR1L = 0;
  UCSR1A = 0x00;
  UCSR1C = (30 << UMSEL11) | (1 << UCSZ11) | (1 << UCSZ10) ;
  UCSR1B = (1 << RXEN1) | (1 << TXEN1) | ( 1 << RXCIE1); //enable Tx and Rx
  sei();
while()
  if (check  ==  1)
    UseString();
    check  = 0 ;
    // do something
ISR(USART1_RX_vect)
  char c = UDR1;
  str += c ;
  check = 1 ;
Divide
1:
UCSR1C = (30 << UMSEL11) | (1 << UCSZ11) | (1 << UCSZ10) ; ????
(30 << UMSEL11) will (effectively) set UMSEL11 = 0 and UMSEL10 = 0
so the end-result is that you will have Asynchronous mode, no-parity, 1 stop-bit, 8 data-bits.
Is that what the other device is set to ?
2:
What baudrate do you want ?
To determine that we need to know what the frequency of your processor clock is.
When does "str" ever stop growing?
How can this work with your WHILE() loop on the outside of MAIN?
Your ISR sets CHECK every time it fires, so your code will constantly only read one character at a time, not a 'String' unless the USESTRING() has some sort of magic code in it.
Post a complete code otherwise this is looking like a 100 poster.
JIm
No, it most definitively is not
Post exactly the code you have in your editor and that you compile. Do not do any editing on the way here.
Simply mark everything in your editor/IDE, copy and paste into a post here.
Posting some edited "close-to-wghat-I-have" code snippet here will create nothing but confusion, frustration and bad or no help to you.
Whats wrong with the code in your post? At least these:
1. #include directives missing (<avr/io.h> and <string> at least..)
2. As Jim noted, code outside function (the while-loop)
It would help clarify for the users here if you where explicit that this is C++ code (not C).
It would help if you where clear about in what way the received string was wrong (empty? garbage chars? or what...?)
hi all .thanks for reply. I have fixed it .
Divide
thank you_mylove.
you_mylove wrote:
 I have fixed it .
That's great.
So how about posting the code - for the benefit of future readers who may come here with the same problem ... ?
And please mark the thread as solved: https://www.avrfreaks.net/comment...
