Learning Microchip's New AVR Lineup vs PIC vs ARM??
22 posts / 0 new
Hey folks. Big fan of older AVRs. ATmega, ATtiny, etc. Have many tutorials on my website that use these devices.
Here's the deal. I have a project that requires a microcontroller in SOIC package that support I2C and SPI independently. Knowing that the classic ATtiny wouldn't meet my needs, curious me decided to take a look on DigiKey to see if there's anything I missed. "Whoah, cool, a new AVR microcontroller line-up... ATiny416/816/1616". Read a few pages into the datasheet... pinout looks different (to be expected with a new Manufacturer and all), but it looks like I2C and SPI use unique pins - perfect!
Then I started to read more into the datasheet. Had a minor panic attack. Everything is different! I know, old news for all of you, but totally new realization for me. Even the venerable AVRISP mk2 is no long supported. Seems like Atmel Studio 7 is still used though... for now.
Let me get to my point. I'm all about change, but I would like to be strategic in what I invest my time learning. Do you see value in learning this new lineup, or is Microchip just going to change the formula again down the road? Should I abandon ship and just learn PICs? Or should I go for something totally different like ARM? I know this is a tough, and loaded question, but looking for your opinion on what is the most "future-proof" in the evolving microcontroller-scene.
Thanks for your feedback.
I’d say the answer is arm. The learning curve isn’t so much with the arm core but more with the peripherals. Each manufacturer does things differently.
quantic wrote:
Do you see value in learning this new lineup, ...
Yes
quantic wrote:
... or is Microchip just going to change the formula again down the road?
Yes
https://www.avrfreaks.net/forum/come-join-us-mplab-now-supports-avrs
Learn both as both are solutions to problems (compute-bound, memory-bound, I/O-bound, power-bound)
quantic wrote:
... on what is the most "future-proof" in the evolving microcontroller-scene.
If one could only ask Carnac the Magnificent.
YouTube
TheOfficialCarson
Published on Dec 17, 2010
https://www.youtube.com/watch?v=9m_dT0wsrGI (1m38s)
Edit: power
quantic wrote:
...looking for your opinion on what is the most "future-proof" in the evolving microcontroller-scene.
The most reliable way to future-proof yourself is to learn to be 'processor agnostic'.
agnostic
[ag-nos-tik]
noun
adjective
7.(especially of digital technology) not limited or dedicated to a particular device, system, etc. (often used in combination):
platform agnostic software.
It might be that MPLAB will eventually support AVRs properly, but when I tried it out a few months ago it was essentially not working. Morten of Atmel /Microchip said it was not to be in the near future.
In general, ARM seems to be the future.
If you have previous experience of "old style" tiny/mega then why not stick with those? Mega48/88/168p range for example. Or if you really want "less pins" then maybe some of the more "loaded" tiny's like 2313 or 1634?
quantic wrote:
...a microcontroller in SOIC package that support I2C and SPI independently.
When you say 'independently' what exactly do you mean?
1) I2C...master or slave?
2) I2C...constantly being read or only at start up? If constantly, how often?
3) SPI...master or slave?
4) SPI...constantly being read or only at start up? If constantly, how often?
I have had both I2C and SPI devices on the same wires. SPI devices have a /CS line so you may as well use it, in which case they ignore other line activity. I2C can be a bit trickier depending on what devices they are.
As a general rule, Tinys are Slaves. e.g. TWIS or USI.
Megas can be Master or Slave.
With all device decisions you first have to specify your project requirements.
As soon as you look at Brian's reply in #7, everything becomes clearer.
SOIC is easy to solder by hand. But other packages are both smaller and suitable for machine soldering.
Absolutely!
Seriously: 98% of the job is generic - reading & understanding datasheets,  reading from registers, writing to registers, handling interrupts, manipulating data.
Once you understand those principles, they are easily transferable to any architecture.
The trouble seems to be that people really don't understand principles - they just copy recipes.
frown
EDIT - 27 Nov
JohanEkdahl  just gave an excellent expansion on this: https://community.atmel.com/comm...
#PrinciplesAreTransferrable
+9999999999999999999999999999999999999999999999999999999999999999999999999999999999999
Here we go again:
Design First
Device Choice & Code later.
I guess, in addition to the above comments, I'd ask:
Building 1, or 1 million?
If you are only building a few boards, then who really cares about a few dollars difference in micro's price, or having a few "spare" / "too many" pins.
You could select a $2 - $3 Arduino Nano type board, with a Mega328, power supply, reset switch, LED, USB interface, and I/O pin breakout; that has both SPI and I2C on separate pins, and be working on your first cut prototype!
(I2C is on PortC.4 and PortC.5 pins, SPI is on PortB.2,3,4 and 5 pins).
Easy decision.
Thanks, great feedback so far. Not looking to mass produce anything, so price isn't a factor. I work more in the 'proof of concept' phase which requires hand soldering components, so QFPs and QFNs are too difficult for me (perhaps one day). SOIC seems to be a really nice package to work with, but I can only find the older ATtiny's in SOIC.
I'd like to stick with my trusty ATmega168, but the SMD offerings are just too limited (just QFN and QFP).
JohanEkdahl wrote:
It might be that MPLAB will eventually support AVRs properly, but when I tried it out a few months ago it was essentially not working. Morten of Atmel /Microchip said it was not to be in the near future. In general, ARM seems to be the future.
That's interesting to hear. I figure at some point Microchip will discontinue support of Atmel Studio in favor of MPLAB.
The plan is to have a microcontroller serve as an I2C slave to a Raspberry Pi while also interfacing to with a SPI device. The Raspberry Pi has built-in pull-ups on SDA and SCL, so while switching between I2C and SPI master is possible with some interface circuitry, I think it's cleaner to find a chip that supports both on dedicated pins.
ARM sounds interesting. I don't have any experience with these, but I'll definitely something I can look into!
There are certainly lots of different naming schemes...
Mega328's come in TQFP, which is still a "gull wing" chip, I think.
If you can solder the SOIC, then I think soldering a TQFP would be essentially the same.
(I've not looked at the tech spec's, and pin spacings, etc...).
I agree, VQFN and MLF have the tiny contacts on the edge of the chip without any external leads are both intimidating and challenging.
I've soldered a few of those, and I swear at myself for designing that chip into the system every time, but I've never had a failure on the ones I did solder.
Flux and practice, and a good magnifier, are the keys to success in this regard.
I've never attempted to assemble a board with ball grid, (UFBGA), chips.
I suspect that doing so won't happen in this life time.
There are numerous prior Threads on soldering.
I recall my hesitancy, (fear!), of switching from years of through hole component designs and board builds to surface mount.
I now prefer the surface mount design, and only occasionally do an "old school" through hole design, primarily to use up some old components.
Make the transition!
quantic wrote:
SOIC seems to be a really nice package to work with, ...
More than several PIC, PIC24, dsPIC, and some PIC32 are in SOIC.
Then third parties will run with that as Microsoft Visual Studio is a juggernaut.
https://visualgdb.com/tutorials/avr/
https://www.avrfreaks.net/forum/platformio-do-or-do-not-thats-question#comment-2267111
Linear Technology
Setting up Linduino, Visual Micro, & Atmel-ICE for Hardware Debugging
Dan Eddleman - Senior Applications Engineer
Malavika Sajikumar - Firmware Engineer
Jan 10th 2017
http://www.linear.com/solutions/7718
Introduction
The Linduino is Linear Technology’s Arduino compatible system for distributing firmware libraries and example code to customers of Linear Technology’s integrated circuits. The design is based on the Arduino Uno, using the Atmel ATmega328 processor, while adding a 14-pin QuikEval™ connector that can be plugged into nearly 100 daughter boards. ...
Visual Studio
Marketplace
Visual Studio Code > Debuggers > Native Debug
https://marketplace.visualstudio.com/items?itemName=webfreak.debug
GDB, LLDB & Mago-MI Debugger support for VSCode
https://marketplace.visualstudio.com/items?itemName=webfreak.debug#review-details
Federico Zuccardi Merli
9/4/2016
I'm using this for embedded debugging, through OpenOCD and other gdb servers.
You know, perhaps you're right, maybe I should learn to solder QFPs. Would open the DOORS to many other microcontrollers options. I have some QFP to DIP adapters from Adafruit, so could learn on those. Thanks for the moral support.
If you can do SOIC then you can do 0.8mm QFP. Even 0.5mm QFP isn't too bad.
For one-offs Schmartboards are well worth the money.
ELM by ChaN's method has no adapters (QFP on kapton tape)
50mil pitch SMT protoboard is easy to work.
ELM
Extreme Wiring on the Prototyping Board
Update: December 16, 2014
http://elm-chan.org/docs/wire/wiring_e.html
http://www.busboard.com/surfacemountpcbs
I suggest learning the Arduino system.  This is an integrated microcontroller development system based on the AVR mega328p, mega32u4, and the mega2560.  It is a combination of standardized libraries that handle common microcontroller operations coupled with C (or C++) code.   The development boards (the UNO, Nano, Leo, and Mega) are mass-produced and cheap; about $2.80 US for a Nano with a bootloader and USB interface IC on it.
The libraries are standard across different CPU families so the code that compiles for the AVR-based Nano model with compile (with little or no change) on the ARM-based Due model.  The libraries are abstract enough to be useful across hardware platforms.  For example, the Wire library that handles I2C (TWI in AVRland) has :
    begin()                      You are Master or Slave
    requestFrom()           You are the Master
    beginTransmission()  You are Master
    endTransmission()     You are Master
    write()
    available()
    read()
    SetClock()
    onReceive()             You are a Slave Device
    onRequest()            You are a Slave Device
Arduino started as an Italian teaching tool and became a world-wide standard because the world needed a microcontroller standard and the chip companies weren't providing one.
That's the right decision. You'll see it's much easier than you think, actually it's faster than soldering a DIP, because you just drag the solder across the pins, check for solder bridges, correct them and that's it. The most important tool is a good quality flux. But since you already know how to solder SOIC, it's the same, just with smaller pitch (as mentioned in #13).
Here is one soldering Thread, in my first post on the Thread I note my first attempt was not a great success.
By Post #18 I added a few photos to show success.
As this link is to the old Forum, the photos aren't visible within the post, you have to click on them to see them.
Give it a try, you won't be disappointed.
And a shot of the frying pan method (post #13) for when I didn't want to solder each connection by hand.
Again, have to click on the photos to see the images.
 Avoiding Architecture and Vendor Wars entirely, I think I'd say the peripherals on ATtiny814/etc are somewhat typical of the more complex peripherals that ALL microcontroller vendors are putting on ALL of their chips these days, and therefore time spent puzzling out how the peripherals work is likely to be "valuable practice" regardless of final chip decisions.  Perhaps the "usefully familiar" CPU architecture would be helpful.
There is a link directly to the post in the top right corner of each post.
Post link in top right corner
