[SOLVED] #ifndef not working?
10 posts / 0 new
Hello, I have short question regarding the use of #ifndef. I want to move some functions to a library and for that I want to define F_CPU and other constants in the main.c:
In my main.c there is:
#define F_CPU   48000000
#include <avr32/io.h>
#include "my_usart.h"
int main (void)
        //some crazy stuff
in my my_usart.h:
#ifndef MY_USART_H_
#define MY_USART_H_
#include <compiler.h>
#ifndef F_CPU
	#warning F_CPU defined by my_usart
	#define F_CPU 60000000
#endif
void usart_init(uint16_t baudRate);
void usart_putc(char data);
void usart_puts(char *strPtr);
#endif /* MY_USART_H_ */
and in my my_usart.c:
#ifndef USART1_TXD
	#define USART1_TXD	AVR32_PIN_PA23
#endif
#ifndef USART1_RXD
	#define USART1_RXD	AVR32_PIN_PA24
#endif
and it's still taking the F_CPU from the my_usart.h file as I can see through my #warnings. I made the files according to the pattern I found in the util_delay.h file which I know from the 8 bit atmegas. For use of this library F_CPU must be defined before including the library. I wanted to do the same, but it's not. Can someone see what is going wrong?
The way to investigate preprocessor issues is to view the preprocessor output
IIRC, -save-temps is the GCC option for this.
https://gcc.gnu.org/onlinedocs/gcc/Preprocessor-Options.html
Many options there to help you - including:
GCC manual wrote:
-dM
Instead of the normal output, generate a list of ‘#define’ directives for all the macros defined during the execution of the preprocessor, including predefined macros.
This gives you a way of finding out what is predefined in your version of the preprocessor.
Sure! A #define in a c-file is not global. When my_usart.c is compiled the compiler knows nothing about the #define F_CPU in main.c, so the  #ifndef F_CPU triggers.
Stefan Ernst
That is why I define F_CPU in a header file (f_cpu.h) and #include that file where needed. It can also be defined in the IDE and it is global from there.
I prefer to define it in the project properties/toolchain settings:
Greg Muth
Portland, OR, US
Ok, I will deal with the GCC preprocessor tommorow. But how is the avr/util/delay.h library doing the trick?
What trick?
It is the exact same thing there. If you do a #include <util/delay.>, then you either have to do a #define F_CPU beforehand (directly in the same c-file, or indirectly by including a header file containing it, as suggested by Jim), or you "inject" the F_CPU definition from "outside" (as suggested by Greg). Having the #include <util/delay.> in one c-file and the #define F_CPU in some other c-file (like your code above) does not work.
Stefan Ernst
If you use <util/delay.h> without providing a F_CPU definition, the delay routines will default to assuming 1MHz for F_CPU.
Edit: clarify statement
David (aka frog_jr)
omg, I got it. I got confused with .h files and .c files . Thank you smiley
Rather than edit the thread title, here is the proper way to mark a thread as solved: https://www.avrfreaks.net/comment...
