It's that time of the year, the next release of Atmel Studio is finally done (yes, copy-paste from the previous post).
The readme/release note contains most of the info, so without further ado:
Most notable bugs that are fixed:
- AVRSV-7798: Tiny817 fuse programming from ELF issue.
- AVRSV-7903: Studio automatically sets GPNVM bits [7:8] thereby enabling TCM
- AVRSV-7892: Writing SAML22 RWW flash fails
- AVRSV-7883: Incorrect warning message for KB2978092 during installation of AS 7.0.1417
- AVRSV-7854: NaN values not handled by atprogram
- AVRSV-7911: Problems reading device ID on ATmega4809
Do note that if you use QTouch, you need to upgrade the QTouch Composer extension from the Extension Manager when upgrading to this version.
GCC Updates:
- AVR 8-bit GCC Toolchain 3.6.1.
- ARM GCC Toolchain 6.3.1 with upstream versions:
- gcc (ARM/embedded-6-branch revision 249437), GNU ARM Embedded Toolchain: 6-2017-q2-update
