USART Tx flag
14 posts / 0 new
The USART status reg has 2 Tx flags:
-bit 6 Txcomplete (TXCIF)
-bit 5 Datareg empty (DREIF)
For sending a byte, polling DREIF
until =1 then sending data works (no interrupt)
Using TXCIF instead of DREIF does not work
The datasheet mentions data can be written only if DREIF=1
so there must be a delay between TXCIF=1 and DREIF=1
For interrupt driven Tx I want to use TXCIF-int because DREIF can
not be cleared without writing new data.
Should I wait for DREIF in the TXCIF-int before sending and
how much is the delay?
What is the purpose of TXCIF?
It tells you that the stop bit(s) have finished being transmitted and that it is now safe to turn off any line drivers if running with a half-duplex link. Or any transmitter for an RF link. Or similar.
;works:
lbl:
  lds      r17,USARTC0_status
  sbrs    r17,5                           ;wait for DREIF
  rjmp   lbl
  sts     USARTC0_DATA,r16      ;write clears DREIF
  ret
;does not work
lbl:
  sbrs    r17,6                          ;wait for TXCIF
  rjmp   lbl
  ldi      r17,1<<6
  sts     USARTC0_status,r17      ;clear TXCIF
  ret
main:
   ldi r16,0x55     ;data
   rcall lbl
   rjmp main
But it depends what you are trying to achieve. "normal" use uses the DRE. Only worry about TXC if you need to act after the last bit has left the TXD pin
You seem to suggest that TXCIF happens before DREIF.
I believe it's the other way around - first DREIF and later TXCIF:
  1. User code stores byte to transmit into data register.
  2. Hardware does a parallel transfer from the data register to the shift-out register.
  3. When data register contents has been transferred DREIF happens.
  4. Hardware shifts bits out of the shift register serially.
  5. When last bit has been shifted out TXCIF happens.
Note that as soon as 3 has happened the user code is free to store another byte into the data register. Hardware will not transfer it to the shift-out register until 5 has happened.
I am not an XMega man so I might be wrong, but I doubt it. This is how most all UARTs have worked since time eternal.
      1   0   1   1   1   0   0   1
1. Application writes byte into data register.
      v   v   v   v   v   v   v   v
    | 1 | 0 | 1 | 1 | 1 | 0 | 0 | 1 |
2. Hardware transfers byte into shift-out register.
      v   v   v   v   v   v   v   v
    | 1 | 0 | 1 | 1 | 1 | 0 | 0 | 1|
3. Data register now empty so DREIF happens.
4. Hardware shifts bits out of shift-out register serially (here, 8 shifts in total):
    | . | 1 | 0 | 1 | 1 | 1 | 0 | 0 +--> 1
    | . | . | 1 | 0 | 1 | 1 | 1 | 0 +--> 0
    | . | . | . | 1 | 0 | 1 | 1 | 1 +--> 0
    | . | . | . | . | . | . | . | . +--> 1
5. All bits shifted out so TXCIF now happens.
You do not use TXCIF to know when it is OK to write to the data register. You are meant to use DREIF.
http://www.atmel.com/images/doc8...
confirms DREIF is first, still code doesn't work.
But back in post #3 you said that when using DREIF the code does work.
So what is the initial state of  DREIF and TXCIF? Because in your program you are waiting for the flags before sending any data. What is the initial state of "transmission complete" before you even sent anything?
reset sets both
GBaars wrote:
reset sets both
I thought that doesn't make sense, so I checked the datasheet.
Turns out TXCIF reset value is 0, as I expected.
THought I read reset sets both, I feel stupid.
Don't.
All is well that ends well.
If I am to assess my stupidity based on the misteaks I have made then I'm an amoeba.. :-)
These guys make me feel stupid all the time.  But they are nice about it.  They just like to help.
