Problem waking up from SLEEP_MODE_PWR_SAVE using Timer 2 overflow interrupt
9 posts / 0 new
#include <avr/io.h> //avr library
#include <avr/interrupt.h> // library for interrupt
#include <util/delay.h> //delay library
#include <avr/sleep.h> //library for sleep
volatile uint8_t count=0;
volatile uint16_t counter=0;
volatile uint8_t led_is_on=0;
int main(void) //main starts
	 //Initialize Counter
   TCNT2=0;
   //Enable Overflow Interrupt Enable
   TIMSK|=(1<<TOIE2);
	 // Prescaler = FCPU/1024
   TCCR2|=(1<<CS22)|(1<<CS21)|(1<<CS20);
    //wait to load
	//while (ASSR & ((1 << TCN2UB)|(1 << TCR2UB)));
	//	TIFR &=~((1<<TOV2)|(1<<OCF2));  //flags cleared
   //Initialize our varriable
   count=0;
   /*All port-pins are set to OUTPUT*/
  DDRB = 0xff;
  DDRC = 0xff;
  DDRD = 0xff;
  /*All port-pins are set to LOW*/
  PORTB = 0x00;
  PORTC =0x00;
  PORTD = 0x00;
	set_sleep_mode(SLEEP_MODE_PWR_SAVE);	 //Powersave mode
		ADCSRA = 0;
	 DDRC=0xff;
   //Enable Global Interrupts
	sei();
	while (1) //initialize while loop
		sleep_enable();
		//_SEI();
		//asm("sleep");
		//_SLEEP();
		//cli();
		sleep_cpu();
	//	sleep_disable();
		//sleep_mode();
	} // while loop ends
}//main end
ISR(TIMER2_OVF_vect)
   //This is the interrupt service routine for TIMER2 OVERFLOW Interrupt.
   //CPU automatically call this when TIMER2 overflows.
   //Increment our variable
   count++;
   if(count==230)     //setting count to 230 for 1 min delay
   {	count=0;
		counter++;
     if((counter==1) && (led_is_on==0)){
				led_is_on=1;
				counter=0;
				PORTC = PORTC | ( 1<<3) ;//pC4 of port C is high led
			if((counter==1)&&(led_is_on==1))
				led_is_on=0;
				counter=0;
				PORTC = PORTC & ~( 1<<3);
I am using Atmega8. I am trying to wake up mcu from power save mode using Timer 2 overflow interrupt.
I needed to introduce sleep in project for power optimization ,I read in datasheet that it can be woke up from sleep using either Timer2 overflow or compare interrupt.
I chose overflow interrupt But its not waking up.
Need your experienced insights in Atmega .
Riario wrote:
/*All port-pins are set to OUTPUT*/ DDRB = 0xff; DDRC = 0xff; DDRD = 0xff;
Kind of ... interesting.
So, you are using the system clock for Timer2?
What speed is your AVR running at?
What results do you get if you do not use sleep?
I might suggest, when working on this situation, to use your LED every overflow...
I am using Atmega Internal clock of 1 Mhz, and using led at Port C pin 3 to check overflow .
If I dont use sleep code is working as expected led is getting on for 1 min and then off for next one min.
Thing I did with setting all ports as output and making them low is related to setting pins to high impedance state .
Ummm--that is the opposite of high impedance.
Wakeup via timer2 in PowerSave mode is only when the timer is in asynchronous mode.
I read about ASSR  bit there is no need to set it if using internal 1 Mhz clock .
When AS2 is written to zero, Timer/Counter 2 is clocked from the I/O clock, clkI/O.
Riario wrote:
I read about ASSR bit there is no need to set it if using internal 1 Mhz clock . When AS2 is written to zero, Timer/Counter 2 is clocked from the I/O clock, clkI/O.
But the wakeup you are trying to use is only valid when timer2 is in asynchronous mode.  (most common is a "watch crystal" 32kHz)
When working with sleep modes and wake up sources I always start with idle sleep mode, once it is working with idle mode, move to lower sleep modes.
Yes, T2 as a wakeup source needs async mode and external watch xtal.
As for low power, drop the M8 and get a newer M88PA, much lower power draw!
Thanks I will try to start from idle sleep mode and then move to lower sleep modes.
As for Timer 2 as wake up I thought Internal clock could be set in async mode.
But now I am clear from Datasheet that "The Timer/Counter can be clocked by an internal synchronous or an external asynchronous
clock source. The clock source clkT2 is by default equal to the MCU clock, clkI/O. When the AS2
bit in the ASSR Register is written to logic one, the clock source is taken from the Timer/Counter
Oscillator connected to TOSC1 and TOSC2."
Can  you please give me details on M88PA power difference compared with M8 haven't used it yet.
Or should I go for watchdog timer in Power Down Mode.
Thanks now I understand that internal clock can't be used for Async mode and I have to use external 32khz clock for it.
