SD card library file naming limitation
5 posts / 0 new
Hello
I am trying to save data files on SD card using Arduino Uno and SD card library. I noticed that there is some limitation related to file maximum name length. If I make the name exceed 8 characters the file is not created.
why does this happen? and how can I save with longer file names?
See the "File Naming" section at https://www.arduino.cc/en/Reference/SDCardNotes.
thank you very much, this was very helpful
Note that the limitation has nothing to do with the SD card itself:  it is a limitation of the FAT filesystem - as explained in the link.
If you use switch to using FatFS you have two options. Either stick with 8.3 names (MYWORDS.TXT etc) or enable LFN (Long Filename Support). It does take quite a lot of flash space though as it needs character translation tables. LFN is a Microsoft thing and they famously sued TomTom for using it in a FAT system. So you may need to licence (or risk prosecution) but it then lets you use any name that is valid in the current Windows you are using.
