Software implementation of TWI Slave
13 posts / 0 new
Hi everyone,
Does anyone can provide me a library for Software implementation of TWI Slave? I'm currently using XMEGA A1U. I have checked Peter Fluery and and Pascal Stang, none of their work include such a library.
Can you clarify, are you looking for slave software using the h/w TWI module, or a pure software implementation of I2C protocol using any pair of port pins?
Keys to wealth:
Sorry ki0bk, I'm not sure I get you question. I'm new in i2c communication. But currently I'm using an xmega to play a role of slave in the I2C communication. However, I ran out of all my I2C hardware interfaces. And I am looking to use some other pins as SCL and SDA.
So I should be looking for a pure software implementation of i2c protocol using a pair of port pins.
Any software-only serial receiver needs a lot of system resources. They need to sit polling pins to capture all transitions.
What do you mean by 'ran out'? TWI can support multiple devices on a bus.
Each bus has two MPU sensors already. All the buses on the xmega are occupied and I'm looking to output the data through I2C to another device.
Ah, so you've run out of address space? Each sensor can only have two addresses?
You might want to consider an 'I2C multiplexer'.
Yes, each sensor can only have two addresses. I should take a look into "i2c Multiplexer". Thank you.
So this does sounds rather an ambitious first project, then?
Go to the NXP site to learn about I2C - they are the inventors of I2C.
The I2C Specification: https://www.nxp.com/docs/en/user-guide/UM10204.pdf
Again, see NXP for details & products.
Or eBay, lots of them on eBay.
Yea it is an ambitious project. I have been working on this for couple months.
Thank you.
Just anyone who might be interested, I am using peter fleury's software library to define my chip as master to spare one of my hardware bus to set up the chip as a slave.
