Atmel Studio 7.0.1645
79 posts / 0 new
Total votes: 2
It's that time of the year, the next release of Atmel Studio is finally done (yes, copy-paste from the previous post).
The readme/release note contains most of the info, so without further ado:
Most notable bugs that are fixed:
  • AVRSV-7798: Tiny817 fuse programming from ELF issue.
  • AVRSV-7903: Studio automatically sets GPNVM bits [7:8] thereby enabling TCM
  • AVRSV-7892: Writing SAML22 RWW flash fails
  • AVRSV-7883: Incorrect warning message for KB2978092 during installation of AS 7.0.1417
  • AVRSV-7854: NaN values not handled by atprogram
  • AVRSV-7911: Problems reading device ID on ATmega4809
Do note that if you use QTouch, you need to upgrade the QTouch Composer extension from the Extension Manager when upgrading to this version.
GCC Updates:
  • AVR 8-bit GCC Toolchain 3.6.1.
  • ARM GCC Toolchain 6.3.1 with upstream versions:
    • gcc (ARM/embedded-6-branch revision 249437), GNU ARM Embedded Toolchain: 6-2017-q2-update
:: Morten
Horray!
meolsen wrote:
GCC Updates:
Is there an update of the FOSS link in-work?
http://distribute.atmel.no/tools/opensource/Atmel-AVR-GNU-Toolchain/
Thanks!
Of course, but again this will take some more time (microchip.com will also be updated, eventuallysmiley)
:: Morten
Does that include the KB2999226 issue noted here: https://www.avrfreaks.net/comment...?
No, we still need that one...
:: Morten
Oh.. The I subtract at least the "Horr" from my "Horray"... ;-)
Awww, you're no fun anymore smiley
:: Morten
Nope. Typically Swedish. (Tråkiga jävlar - ikke noen Göy tilstede..)
Well, the installation succeeded.  The shortcut icon is a blank page on my toolbar.  It doesnt look like a Ladybug.  Now let's see if everything works.
I restarted my machine and now the icon looks like a Ladybug.
Un-pinning from the task bar then re-pinning to the task bar resolved that issue for me.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
Morten,
can you also add a link to the full download in your initial post, then with the copying that will be there for all future copy and paste updates.
thanks
Thanks motion,
but hope that Meolsen will add it to his initial post, so that when he does updates again, this link will also be "automatically" there.
First run had error opening project:
Value cannot be null. Parameter name: url
And only "Import Arduino sketch" was available in create new project.
Solution: Close AtmelStudio after first run after the install, reopen.
Should we expect some sort of notification from Microchip that there are updates to Atmel Studio, or do we just have to check the Microchip website around this time of year or hope we see a post here like this one from Morton?
Or do we really think this is the last update to Atmel Studio we will ever see?
What? The update notification in Studio is there... The websites are in the process of updating...Do you want a telegram as well?
:: Morten
I vote no though I'm Visual Studio centric.
  • Defect corrections
  • ASF3 is still alive
  • New features (one poster wants an off-line ASF4 for configuration control)
  • Updated GCC usually means new switches
  • (assumption) newer versions of Visual Studio Isolated Shell
https://docs.microsoft.com/en-us/visualstudio/extensibility/shell/visual-studio-isolated-shell
A telegram would be nice, or a notification of updates like I get from Window Updates, or an email to my Microchip account.  I went to the Atmel Studio download page on the Microchip website and build 1417 is the only one available.  I dont see where the new version is mentioned.  Sorry, I have a hard time with the Microchip website.
The page is not updated yet. There's a flag in the top right corner in studio telling you about the update...
:: Morten
I understand the website is being updated, so the new version not being on the download page is understandable.  But when I search on Atmel Studio 7 I cant find anything about a new version.  I dont know the web site very well.  Where would I find said notification?  A URL?
When I first downloaded AS7 from Atmel I had to log in to my account.  It would be cool if that account email address would get a notification of changes to AS.  I have signed up for weekly change notifications for several products on the Microchip site, but I couldn't seem to add Atmel Studio to the list I would like updates for.  I only saw hardware products.
Dont get mad at me, Morton.  I am not  one  of the geniuses here.  Just a typical experienced developer in C and C++.
mark
OH, OK i see the flag.  Was wondering what it was about.  I take back all my complaints.  Sorry Morton.
mark
The new Atmel Studio uses much less memory on my little 10" 2GB machine.  Maybe it is due to my not including the ASF plugin, but I am pleased it uses a reasonable amount of memory instead of almost all I have.  Good work Morton.
The upgrades notification flag in the previous AtmelStudio is lighting up and displaying it.
It is sensible to stagger a release anyway, rather than exposing everyone to a bug which may have to be patched with another version shortly after.
Phew, this one went smoothly, it only took me 3 reinstalls to get the new version workingcheeky I had to delete every last configuration file from the old version, or it would fail to open any projects, complaining about corrupt toolchains or whatever.
El Tangas, are you using Windows 10?
No, I use Windows 7, and will keep using it until I'm forced to change.
Yeah, me too.
Hi Morten, The installation was perfect on Windows 10 Pro Version 1709 OS Build 16299.19.  Seems to run faster and definitely uses less resources.  Good job.  Now if you guys make a Visual Studio Code extension you would make my day.
:: Morten
That was fast, thanks.  Does this allow calling up Visual Studio Code from within the IDE itself, say by double clicking on a source file name?
Concur
Different tack -
Another "make my day" is Atmel Studio in Microsoft Store.
Reasons :
  • Windows 10 Enterprise in S Mode
  • Windows 10 S
  • Microsoft Surface Laptop
  • Low price notebook PC for students, schools (secondary, post-secondary), and libraries
  • When Arduino via Microsoft Store is not enough (iow when need an Atmel-ICE)
https://www.avrfreaks.net/forum/atmel-studio-701416701417?page=1#comment-2295131
https://www.microsoft.com/en-us/surface/devices/surface-laptop/overview
https://www.microsoft.com/en-us/education/devices/default.aspx
https://www.avrfreaks.net/forum/arduino-windows-10-s
Never fixed the "Add as Link" bug introduced in AS 7.x :-((
Huh? No...? It's a debug extension that hooks onto the debug backend from Atmel Studio.
:: Morten
I realize that was the purpose of the extension that you provided.  I was hinting that you could give us an editor extension to Visual Studio Code from within the ASDE bypassing the internal editor altogether, wish list item.
Hehe, Pull Requests are always welcome...
:: Morten
Pull Requests
As in "pull the other leg"?
js wrote:
Pull Requests
Pull a rabbit out of a hat
M0+ debugging (at least SAMD20s) may be broken with this update. Refuses to write fuses or write memory in debug. Older version works fine :/
My D20 XPRO works fine in a quick test. Tried fuse writes from the prog dialog, and modifying flash while in debug.
Can you send me (PM)  %appdata%/Atmel/Studi/7.0/...ApplicationStatus.log  after a session where fuse write fails ? Same for memory write failure.
Best regards,
Dan (Studio team)
Sent PM. Might be related to using the SAM-ICE over other debuggers? The SAM-ICE was broken before in Studio updates early on :/
I have a second computer which never had studio on it encountering the same error with 1645.
I installed this thing (1645) from Microchip.  The good news is it only downloaded 80 megabytes, or so it seems.  Normally it downloads terabytes.
The bad news is, Microchip apparently embedded a Trojan. It won't load a project unless I give it admin privileges.  What do I do now?
I should mention I installed it on a backup/test machine.  My primary computer has 1417.  I can usually get that one to work although sometimes is likes to fool around with my files.  I use folders and I add files with links.  This new version seems to do a better job of that but I don't want to run it with admin privileges.
Could you share what is the error you are getting during project load?
Charles
Oh, I know this one, happened to me when I updated to the new version. I had to uninstall AS7, cleanup any remaining configuration and log files in programdata, appdata/local, appdata/roaming, clean the registry, well, you get the picture, leave no traces of the previous install.
I'm not sure exactly which "remains" are responsible, but after the cleanup, a fresh install worked.
edit: just to make that clear, you don't need to delete your projects (well, I didn't have to).
edit 2: I see you also have problems with admin privilege. I also had that problem. You need to install AS7 logged in the admin account, if you install from a user account, even if you give the admin password, it will not work properly in user mode.
edit 3: Ah, we already discussed these issues before: www.avrfreaks.net/forum/need-hel...
After upgrading to 1645, do you need to go into the Device Pack Manager and check all the ones you want to install/upgrade?  I opened a project and it prompted to update.  I did find where you could set the project to use the latest version.
It's weird.  It works okay with admin permissions.  It seems like Studio can't access something because it doesn't have permission.   Maybe I could go to the Atmel folders and give me permission for everything inside them.
I don't use any device packs.  I don't use ASF.  Basically all I need is the toolchain for AVR8.  I didn't have this problem with an earlier version of Studio 7.
Well maybe I do use device packs.  I have to specify a device but I was thinking that was for the debugger.
Yes you do when
so you need to install the device pack for the 8 bit AVR.
steve17 wrote:
1) Go To Run in Windows
2) Type %appdata%\Atmel\AtmelStudio\7.0
3) Delete the above folder
4)Type %localappdata%\Atmel\AtmelStudio\7.0
5) Delete the above folder
6) Start Studio and open the project.
Note: This will remove the existing settings for Atmel Studio like Windows Layout, Recent projects etc.
Charles
I am not sure whether you found it but for clarification. Right click on Project and go to Properties.
All part support is contained in the part packs (device packs). Header files, linker scripts, assembly include files, ... Not everybody is happy for this disconnect from the toolchain, but for us it gives the advantage of being able to distribute new part support and fix bugs without having to release a new toolchain. All our packs is available at http://packs.download.atmel.com/
Thanks, that fixed the problem.
Something strange happened to my computer shortly thereafter.  Some programs froze up and others worked okay.  Studio worked okay.  The start button didn't do anything.  Ctrl-alt-del worked but nothing on its menu did.  Trying to sign out or restart or shutdown was futile.  All that happened was a blank screen with those white balls chasing each other around a circle.  I had to pull the plug.  Well actually pressing and holding the power button.
This situation is very unusual.  I don't know if Studio did it, but deleting stuff in appdata is rather unusual also.
Since re-booting, everything seems to be normal.
Maybe not so normal.  Now my HyperTerminal doesn't work.  It can't read the session file.  It gives a pathlist in AppData.  It shows "Accessories" in the pathlist.  But I have "Windows Accessories" instead.  Maybe that folder name change in the error message is irrelevant because HyperTerminal hasn't changed since XP.
Well that wasn't so bad.  I just had to create a new port.
Really? I already said that in #47, but apparently step by step recipes are needed. Well, I'll keep that in mind for the future...
If I had installed Studio as an admin, would I have avoided this?
I don't want to go through this on my primary computer.
I found it, but everytime I change a project to "use the latest version", AS7 crashes.  At least when I reopen it, the project does have the change...
Funny UI issues after upgrades are almost always due to the caches in %LOCALAPPDATA%/AtmelStudio/7.0
I wish the studio installer just cleared them. (Because VS2015 isn't smart enough to regenerate them)
Done
Thank you!
Tried to update 7.0.594 to 7.0.1645, update failed. Then I removed 7.0.594 to install from scratch. The drivers install, but then "Atmel Development Environment" fails to install according to the installation log. Not too sure where in installation log to look for the problem. Any ideas?
Many Thanks
J.Clark
If you can share your log we can help you look.
Thanks for getting back to me. I attached the log. It seems that all goes well until:
MSI (s) (38:6C) [13:24:20:113]: Hello, I'm your 32bit
Impersonated custom action server.
Action start 13:24:19: ExtractContent.
SFXCA: Failed to create new CA process via RUNDLL32. Error code: 2
Then a list of Property (S) that refer to locations that did not exist when the installation started??
I attached the log. Many thanks.
Hello All,
after updating to 7.0.1645 on Windows 7 x64 the IDE is trying to update the EDBG firmware for a couple of SAM D21 and L21 boards (i.e. from revision 3.19 or 3.1f to 3.25). The progress bar is full instantaneously I get the message EDBG MSD firmware successfully upgraded. But it's not, and I cannot flash my software anymore!
I have tried also with atfw directly, but with no success, atfw crashes!
Do you have any idea what I can do to continue work?
Best regards,
Draghi
Take the kit out of MSD mode.
View-Available Tools, right click the edbg, kit mode settings, select DGI and make sure Persist is checked.
:: Morten
Hi, meolsen,
I have same problem to update the EDBG firmware from revision 3.22 to 3.25. After following your instructions, changed edbg to DGI mode with persist checked(before is AUTO mode) the update is still not sucessful from Atmelstudio or from command line. And I can no longer view the edbg in Atmelstudio even though the vitual port is visible. Could you give me some more details?
Edit: I solved the problem by try and error. Set to DGI but persist not checked->command line to update->some error message and can not go on->replug the device and update in studio(setting is back to "AUTO" and persist checked)->update sucess.
I was trying to install "as-installer-7.0.1645-full.exe" on win10, but this message was displayed. Does anyone have the same symptoms?
Cannot find one or more components. Please reinstall the application.
That worked for me! Tnx meolsen
draghi wrote:
Hello All,
Best regards,
Draghi
Could you try the following update http://studio.download.atmel.com/7.0.1652/as-installer-7.0.1652-web.exe and see whether it fixes the issue?
Charles
Any chance we can get Atmel Studio 7 to not overwrite the Arduino Bootloader when using the Atmel JTAGICE3 to program an Arduino via ISP?  Or, have an easy way (menu option?) to restore Arduino Bootloaders?  Is there a quick way to restore it via the JTAGICE3?  I programmed my Mega2560 via it's ISP (not the onboard ATmega16u2's ISP) but now when I try to program it via the USB/ATmega16u2 using the Arduino IDE I get "stk500v2_ReceiveMessage(): timeout" messages.  I don't understand what's going on.  I thought the Atmega16u2 programs the ATmega2560 via the Atmega2560's ISP also.  Guess I was wrong.
But that's a feature of the mega2560? ISP will start with a "chip erase" and 2560has no way to do "selective erases". It's always the case that doing ISP blows away bootloaders. It's only when you get to Xmega and some modern models of AVR that there are now mechanisms to prevent this. You'd have the same experience if you used avrdude in place of AS7. So it's not a deficiency of AS7 as such.
That just gives me the following error message:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/Christos/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
         User configuration file is "/Users/Christos/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done.  Thank you.
Error while burning bootloader.
My fuses and bits look like this:
BODLEVEL = 2V7
OCDEN = [ ]
JTAGEN = [ ]
SPIEN = [X]
WDTON = [ ]
EESAVE = [X]
BOOTSZ = 4096W_1F000
BOOTRST = [X]
CKDIV8 = [ ]
CKOUT = [ ]
SUT_CKSEL = EXTXOSC_8MHZ_XX_16KCK_65MS
EXTENDED = 0xFD (valid)
HIGH = 0xD0 (valid)
LOW = 0xFF (valid)
LB = NO_LOCK
BLB0 = NO_LOCK
BLB1 = LPM_SPM_DISABLE
LOCKBIT = 0xCF (valid)
I wish it was that simple... i'd not be here then.
Can you show us the command you used when running Avrdude?
And just to make it clear, you have a JTAGICE3 connected to target?
You need to also change the programmer on the line above.
Now it's set to use an avrisp2...
:: Morten
Yes, to connected via JTAGICE3.
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cjtag3isp -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : jtag3isp
avrdude: jtag3_open_common(): Did not find any device matching VID 0x03eb and PID list: 0x2110, 0x2140
