Working with 64 bit floats in atmega
11 posts / 0 new
Im am trying to get to work with a library that enables me to use 64bit-floats on a avr, because i need more accuracy in my calculations .
I included to lib and source file in the attachements.
When i use the function "f_long_to_float64" to convert my float32 to a float64 and print out the memory content , it is all zero.
Has anyone worked with this library before or knows how to solve my problem. I am using a atmega164pa
My code:
int main(void){
	radius= 6371000.00;
	init_board();
	stdout = &mystdout;
	printf_P(PSTR("Start1 \n"));
	printf_P(PSTR("test\n"));
	long test1 = 52.141390 * PI * 1./180;
	float64_t test = f_long_to_float64(test1);
	 uint8_t *P;
	P=&test;
	 int i;
	for(i=0;i<sizeof(test);i++) {
		printf_P(PSTR("0x%x "),*(P+i));
		return 1;
The output is :
Start1
test
0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0
I hope someone can help me, thanks in advance.
thorb3n
If you switch to using either the IAR compiler or the Imagecraft "Pro" compiler they already have "double" support.
BTW you do know that by using "long" here it will be truncated. I can tell you now that the result of this line is that test1 will hold 0.
52.141390 * 3.141592 * 1 is 163.80697
163.80697 / 180 is 0.9100387427
0.9100387427 stored in a long is 0.
What library?
Where did you get it?
Have you followed the documetation?
Have you contacted the author for support?
// avr_f64.c
// Original Code by Detlef_a (Nickname in the www.mikrocontroller.net forum).
// Extensions (trigonometric functions et al.) und changes by Florian Königstein, mail@virgusta.eu .
Floating point is not (necessarily) going to give you any more accuracy.
In fact, floating-point introduces a number of inherent in-accuracies!
When i use the function "f_long_to_float64" to convert my float32 (sic) to a float64 and print out the memory content , it is all zero.
Eh??
Surely, if the name is correct,  "f_long_to_float64"  converts a long - an integral type - to "float64" ?
And, in your code, the paramter you pass is a long - not a float:
In that calculation, the value of test1 will be zero -so your code seems to be working perfectly well as written!
EDIT
Cliff beat me to it.
You are right. I forgot to edit it, it should be a float.
But it doesnt change the output.
thorb3n wrote:
You are right. I forgot to edit it, it should be a float. But it doesnt change the output.
No. Look at the function:
float64_t f_long_to_float64(long n); // Converts a long to the float64_t representing the same number
That takes long so even if you pass float it will be truncated to long and 0.9 will become 0.
Go on - show the actual, complete  code.
clawson wrote:
That takes long
The clue is in the name - see #3 !
Which has on-chip debug - so you could have seen clearly what was happening by simply stepping through the code!
In fact, as it doesn't depend on any hardware, you could have seen it in the simulator.
In fact, it's all standard 'C' behaviour - so you could've seen it in a 'C' program on a PC ...
Oh, now i get it. i was always so centered on the double to float thing, that i somehow thought it represents double.
Thanks for your help and taking your time to answer my stupid question.
I think it can be closed now
BTW thanks for posting this library code! That is quite a piece of work the author has done there.
Wonder why the author didn't go the whole hog and add the support to the compiler?
"Read a lot.  Write a lot."
