Problem with variables
17 posts / 0 new
Hi guys.
I'm using ATMEGA8,SIM800 and I'm working with AtmelStudio
Sometime I should send constant strings with SIM800. This is the definition of this strings for example:
const char SMS_MSG[2][10] PROGMEM =
	"Done!",
	"Cancel"
And this is my main while's code:
while (1)
    wdt_reset();
    _delay_ms(1000);
    if (Msg_Received_f)
        Msg_Received_f=0;
        Phone_Num_Detect();
    if (P_MSG_f)
        P_MSG_f=0;
        Process_SMS();
    MSG_Buff_C=0;
    while (SMS_MSG[0][MSG_Buff_C])
        wdt_reset();
        UART_TX(SMS_MSG[0][MSG_Buff_C]);
        MSG_Buff_C++;
        _delay_ms(1000);
I defined "MSG_Buff_C" as "unsigned char" and it's a global variable.
the problem is that MSG_Buff_C doesn't change...
please help me about this..
How do you determine that?
As an aside, what is the name "MSG_Buff_C" supposed to convey?
The name suggests it might be a buffer - but you're using it as an index.
So why not call it Msg_Index ?
Actually I ment "Message Buffer Counter" and it should count the parts of Message Buffer to the last part..
for example if MSG_Buff_C changes, in first time it should send character 'D' and in second time (I mean in while loop) it should send 'O' and so on... but it just sends 'D'
You have no SPM dereferencing in that?
If you are going to stick to PROGMEM then to read the characters in the array you must use pgm_read_byte().
As this looks like new code you are writing then unless your compiler is out of date or unless you are writing C++ rather than C I would highly recommend you replace PROGEM with __flash. (in which case the dereference will be implicit.
I don't know what that is indecision
yes I'm writing GCC with atmel studio.. but when i wrote __flash , atmel studio didn't recognise this expression!..
Will you tell me how should i use pgm_read_byte() ??
What is watchdog period?
http://www.atmel.com/webdoc/avrlibcreferencemanual/pgmspace_1pgmspace_data.html
explains how to read a value stored in flash using PROGMEM -consistent with Clawson's help).
What is your version of gcc + atmel studio?
Either you made a mistake or you're running an old Atmel Studio.
If you use PROGMEM to store constant data in flash memory then you need to access it in special ways. Here's a few pages from the documentation:
There's a tutorial here at AVRfreaks: https://www.avrfreaks.net/forum/t...
Don't tell us what you did. Always show us what you did. Post a minimal but complete program that compiles and runs and demonstrates the problem. (Yes, it is your job to isolate the problem to such a small program that it is fit to post here.)
This is how i initialed watchdog timer, my clock source is 8MHz internal source
	// Watchdog Timer initialization
	// Watchdog Timer Prescaler: OSC/2048k
	WDTCR=(1<<WDCE) | (1<<WDE) | (1<<WDP2) | (1<<WDP1) | (1<<WDP0);
	WDTCR=(0<<WDCE) | (1<<WDE) | (1<<WDP2) | (1<<WDP1) | (1<<WDP0);
JohanEkdahl wrote:
Either you made a mistake or you're running a n old Atmel Studio.
Or he is using C++.
while (1)
    wdt_reset();               // why watchdog
    _delay_ms(1000);	       // then delay 1000ms - the watchdog may trigger !!?
    if (Msg_Received_f)
        Msg_Received_f=0;
        Phone_Num_Detect();
    if (P_MSG_f)
        P_MSG_f=0;
        Process_SMS();
    MSG_Buff_C=0;
    char c = pgm_read_byte(&SMS_MSG[0][MSG_Buff_C]);
    while (c)
        wdt_reset();
        UART_TX(c);
        MSG_Buff_C++;
        _delay_ms(1000);  // again WHY delays when the watchdog is being used??
The point is that you cannot just access SMS_MSG[0][MSG_Buff_C] because it is in flash not RAM. So you need to use pgm_read_byte(&SMS_MSG[0][MSG_Buff_C]) to get a character from the flash based data.
I also hate the fact that you use upper case names for variables and functions. Most C programmers would only ever use upper case for one thing and that is the name of #define'd macros. So they will immediately see anything in uper case as being a macro (I do!)
What is the delay between the 'D'-s? One second or two seconds or something different? I mean the actual delay, not 1 second you wrote in your code.
Thank's all..
I used pgm_read_byte(&SMS_MSG[0][MSG_Buff_C]) and it works now..
Oklaugh I will edit my code , by the way thank you so much
It's actually one second
Why are you using the the watchdog AND delays? It's a VERY dangerous practice (and if you don't know why you clearly don't understand enough about the watchdog just yet).
a) Well, are defined macro s necessary except for giving array some dimensions,  and to make some kinds of functions (without allowing compiler checks?)
b) Were can one find reasonable  stylistic rules to write good/good looking  C, once algorithms are not too absurd  (I used pylint for python, and I was very surprised : by default, without configuration file,  oNlY UPPERCASE variables were tolerated in python by pylint).
I know I must not use delay in my code..
I'm just trying to make some sample codes for my future jobs and testing my project's features..
in final version i will use counters that are increased in timer interrupt routine and flags instead of delay in my functions...
